Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Sep 20, 2018 at 8:26 AM
    #4081
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Thank you. I decided to go a different route. Ordered a couple 3/8" spacers. Going to throw them in and call it a day.
    jjsul and Jiveydude like this.
  2. Sep 22, 2018 at 12:24 PM
    #4082
    Dirty White
    Dirty White Well-Known Member
    02 DC Prerunner and 03 ext can prerunner
    2002: 2.5" ome lift springs, 2.5" lift bilstein 5100 front shocks on oe coils and 5100 rear shocks. Topper. 285 75 16 toyo at2s. K&N intake. 2003: super spring progressive aal. Slide master 1000lb bed slide. Custom utility bed with lumber rack. Diamond aluminum 6ft boxes.
    What does vvv mean?
  3. Sep 23, 2018 at 6:46 AM
    #4083
    MY1STGENTACO
    MY1STGENTACO Well-Known Member
    MORA
    NEW MEXICO
    2001 Toyota Tacoma
    OME 3" LIFT 882'S NITROCHARGERS ALL AROUND
    VVV stands for, “Referring to comment below”.
  4. Sep 23, 2018 at 3:28 PM
    #4084
    Burro
    Burro Well-Known Member
    SoCal
    98 v6 4x4 xtracab
    What length shocks are everyone running with their Dakars in the rear stock location? I'm thinking of going with the 5125's for now, I just want to get as much flex out of these leafs as possible.
  5. Sep 23, 2018 at 6:03 PM
    #4085
    49erfan
    49erfan Well-Known Member
    Kevin
    Dallas
    04 DC Prerunner Lunar Mist
    Nitrochargers with my dakars
  6. Sep 24, 2018 at 1:33 PM
    #4086
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Same here. Also is your rear suspension a little more stiff than the front or just me?
  7. Sep 24, 2018 at 1:50 PM
    #4087
    49erfan
    Kevin
    Dallas
    id say my front is stiffer than rear
  8. Sep 24, 2018 at 1:51 PM
    #4088
    DashMaple
    Louisiana
    What coils do you have in the front? and any weight in the bed?
  9. Sep 24, 2018 at 2:06 PM
    #4089
    49erfan
    Kevin
    Dallas
    883's, have camper shell but rarely carry much weight
  10. Sep 24, 2018 at 2:19 PM
    #4090
    MY1STGENTACO
    MORA
    NEW MEXICO
    2001 Toyota Tacoma
    I ordered 882's hopefully they ain't that stiff
  11. Sep 24, 2018 at 6:24 PM
    #4091
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    There are not they have a lower spring rate so they compress easier.
    Or you were being sarcastic and all ready knew that.:thumbsup:
  12. Sep 25, 2018 at 6:43 PM
    #4092
    MY1STGENTACO
    MORA
    NEW MEXICO
    2001 Toyota Tacoma
    Happy birthday to me :mudding:
  13. Sep 27, 2018 at 8:35 AM
    #4093
    TheDamaso
    TheDamaso Well-Known Member
    Damaso
    Baytown TX
    98 2.7 4x4 5sp, 2014 TRD OR
    Will OME leafs really do 3” of lift? Im trynna replace my OEM ones with new ones and I’m Comparing with J59 leafs from deaver. I want to pair them with 881s and 5100s and would like to stay under those 3 inches because I’m not trynna do any off roading and I’m not gonna add any weight to it other than the fiberglass tonoue I have already. It’s a 98 2.7 4x4.
    Thanks guys
  14. Sep 28, 2018 at 7:05 PM
    #4094
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You’ll probably get about 2 1/2” of lift, @TheDamaso. I got about 2 1/4” with a camper shell on. You can also remove a leaf on each side if you want.
  15. Sep 28, 2018 at 8:37 PM
    #4095
    MY1STGENTACO
    MORA
    NEW MEXICO
    2001 Toyota Tacoma
    Captainkyro and Area51Runner like this.
  16. Oct 23, 2018 at 8:05 PM
    #4096
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    New UCAs gonna be necessary on 881 with 3/8 spacer?
    Thoughts?
    What have you noticed with similar setup.
  17. Oct 23, 2018 at 8:21 PM
    #4097
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've got the J-59's on my 2004 RC 2.7 4X4. You'll get some lift. They say 1.5". My stock leaves were really shot and I never measured height before or after. I'll say this, with 880's up front and Nitrochargers all around mine has a slight rake with the shell and an empty bed. It needs at least 300 lbs to sit level with the front. I've got 880's up front. I got quite bit of lift compared to the stock (I'd say at least 2"), worn out stuff but have zero drive line vibrations and zero CV problems after 2 years.
    DJB1 likes this.
  18. Oct 23, 2018 at 8:42 PM
    #4098
    Adude
    Pnw
    04 Double cab
    You shouldn't but not knowing your motor rig is hard to say. On my 04 double cab v6 I have never had any issues with it.
  19. Oct 23, 2018 at 10:46 PM
    #4099
    butters_
    butters_ Well-Known Member
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    My rear heavy duty Dakar’s feel a bit soft when coming into ditches etc. . I’ve got a shell, steel rear bumper, tire swing and full size spare as well as roof rack and awning so it’s got a 300 pound constant load without gear. Feel like I bottom out in he rear quite a bit. Not sure how old the ome suspension is.. looks to be at least a few years old.. other than that it’ handles well
  20. Oct 29, 2018 at 10:06 AM
    #4100
    Nevin
    Washington
    I have the v6 as well.
