Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 24, 2014 at 8:39 AM
    #941
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The Toytech shims comes with an extra/longer pin. Just not sure what the "collar" was OZ-T was refering to :notsure:
    Ill probably PM him...
  2. Apr 24, 2014 at 9:00 AM
    #942
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    This
  3. Apr 24, 2014 at 9:45 AM
    #943
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Hmm, maybe Im missing something but I dont see what the "collar" is... Am I overcomplicating this?
    The shims come with an extended center pin which I understand needs to be installed on the leafs. But what is the "collar?"
  4. Apr 24, 2014 at 10:19 AM
    #944
    Jiveydude
    Micah
    OH
    04Taco
  5. Apr 24, 2014 at 10:41 AM
    #945
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  6. Apr 24, 2014 at 11:01 AM
    #946
    Jiveydude
    Micah
    OH
    04Taco
    2 is good, you might be able to find them at home depot, just make sure they are 3/8ths.
  7. Apr 24, 2014 at 3:53 PM
    #947
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Pretty sure it will be hand tools :( I have a compressor but no gun. Lol. And I read on ttora that the center pin in the Dakars are long enough for the AAL Edit: good news. Found out Sunbelt rents air guns :)
  8. Apr 24, 2014 at 5:38 PM
    #948
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Center pin is long enough for the AAL. I had to drill out the bumpstops a little to fit the pin in it though. No biggie, took 10 seconds on each one.
  9. Apr 24, 2014 at 5:40 PM
    #949
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    This. Also, I have yet to find a nut on the truck my hf electric impact can't handle, fwiw. Some things are a bit tight for anything but a right angle air wrench tho...
  10. Apr 24, 2014 at 5:41 PM
    #950
    NoTown98Yota
    NoTown98Yota Whiskey Throttle FTW!
    Scott
    Reno, NV
    '98 Tacoma 3.4L V6 W/E-Locker
    -Leer shell with Yakima MegaWarrior -K&N FIPK -18" Magnaflow dumped after axle -Clear headlights -Blacked out bumpers, wheels, badges, mirrors, fuel door, door handles, tail lights, corner markers and turn signals -White LED gauge lights -SpiderTrax 1.5" Spacers -Pinch Weld Mod -Ultra Gauge -6 Switch Plate under single din stereo -Custom Battle Born bedside decals -Eibach 620# coils -Bilstein 5100's -Dakars -Toytec 1" Lift Shackles
    Did the same
  11. Apr 24, 2014 at 6:35 PM
    #951
    Scenekyd
    Jay
    Hendersonville, NC
    Thanks everyone for all the useful tips! :thumbsup: Wish it was next Friday already! Haha just wanna make sure, but the AAL will be the new 3rd leaf down from the top? Go in order by length, is what I have read somewhere. Longer part goes towards the rear. I will just rent in air gun from Sunbelt, only like 40$ for the day lol. To cheap to go by one. Plus just spent $530 on a crown today :(
  12. Apr 24, 2014 at 6:43 PM
    #952
    NoTown98Yota
    Scott
    Reno, NV
    Yes, 3rd down and longer to the rear.
  13. Apr 24, 2014 at 6:44 PM
    #953
    Scenekyd
    Jay
    Hendersonville, NC
    10-4. Appreciate man!
  14. Apr 24, 2014 at 6:45 PM
    #954
    NoTown98Yota
    Scott
    Reno, NV
    :thumbsup: Np
  15. Apr 25, 2014 at 7:37 PM
    #955
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Is that collar thing necessary when adding axle relocation plates?
    This is the firs I've heard of this little collar thing
  16. Apr 26, 2014 at 10:09 AM
    #956
    Jiveydude
    Micah
    OH
    04Taco
    They're not required for relocation plates, only if your adding shims.
  17. Apr 27, 2014 at 10:49 AM
    #957
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    31X10.5x15 Tires
    Old Man Emu Kit from Wheelers Off Road with Dakars, 881's and Nitro Sports.
    37 in the front and 39 at the rear.
  18. Apr 27, 2014 at 11:47 AM
    #958
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    What were the before measurements? Can you raise the front with the equipment you just installed or would you need to buy a spacer for the front? Did you have to relocate the valve in the back for the brakes?
  19. Apr 27, 2014 at 12:03 PM
    #959
    Monkeysuncle
    Kevin
    Florida
    The fronts were around 35 with dead shocks, factory springs and 170K on the clock.
    The rears were about 36ish with flat leaf springs and more dead shocks.
    The lift is not adjustable like say, an adjustable coil over set up. But with an adjustable set up all you are really doing is adding a pre load to the spring to achieve a desired lift.
    This kit is a stronger spring rate than the factory front springs. The rear have more leafs, are new and don't sag like the factory ones.
    I didn't do the brake valve relocate yet but I will have to do that ASAP just so I can sleep better at night.
    All that said, I have read many peoples comments about their set ups using OME parts, and they will settle a bit, so the final measurements will be less once the system finds out where it wants to be.
    Overall I am extremely pleased with the kit from Wheeler's Offroad thus far.
  20. Apr 27, 2014 at 12:12 PM
    #960
    johnboyTRD
    South SF bay
    Looks nice! Wheelers is def good to deal with :) I'm needing a bpv bracket too...
