Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 28, 2014 at 8:23 PM
    #981
    samwell6969
    samwell6969 Well-Known Member
    How does the spacer affect your ride, I've heard a lot of people say they don't like them cause it makes it stiffer?
  2. Apr 28, 2014 at 8:33 PM
    #982
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Doesn't affect it at all. It sits between the top of the strut assembly and the strut mount basket on the frame. No pre-compression of the spring.
    I don't use a very tall one, 1/2", and won't be going any taller. I'll be glad when I get the winch mounted and drop the nose a little more, lessen the steepness on the CV axles. IFS's are a bitch to lift properly.
  3. Apr 28, 2014 at 8:34 PM
    #983
    samwell6969
    I can imagine lol! But how much did urs run you, the cheapest I think I've found is 1200
  4. Apr 28, 2014 at 8:35 PM
    #984
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    Do you automotive sages feel that the trim packer is necessary? What about the 10mm lift enhancer kit? Do either affect ride? Positives/negatives? I'm running the OME kit from Wheelers with 883s in the front. I plan on adding an ARB Bull bar and Warn XRC 8. I already replaced my CV axles, as well as the inner/outer tie rod ends. In addition, I have Camburg Uniball UCAs in route to help out with things. Thoughts? I've been reading this massive thread in bits & pieces, but it's out of control lol.
    Thanks, gents!!
  5. Apr 28, 2014 at 8:39 PM
    #985
    Griff 99 TRD
    Wheelers Offroad is where I got mine. Currently, they are selling the entire kit for $1180
  6. Apr 28, 2014 at 8:43 PM
    #986
    GoForBroke
    GoForBroke Well-Known Member
    The Great Northwest
    3.4L 4X4 SR5
    How many of y'all had torn cv boots right after or shortly after install?
  7. Apr 28, 2014 at 8:46 PM
    #987
    tomtom
    The Desert SW
    2012 FJ
    I don't know. I bought the original lift over 4 years ago through 4WheelParts. I seem to recall it was around $1100. The front-end I've had to experiment with to get it right and I've bought all the springs and struts through Wheeler's. I'm still finding out that the kit I got from 4WheelerParts wasn't all that it was made out to be (Just front C/Os and Dakars leaf packs). No BPV relocation, no greasable shackles, no rear axle relocation plates, etc.
    That reminds me. The 882s were so tall, I had to go to aftermarket UCAs with Uniballs to account for the angles. The passenger side stock UCA was forcing the spindle top into the spring.
    The trim packer is pretty close to a must, with the Taco lean. It is only 8 bucks after all. Mine still has it but think my fat-ass has squished the body mounts on the driver side and with the location of the gas tank, the leaf pack needs to be adjusted somehow to account for the weight on that side.
    I started out with no top plate spacer then went to 10mm when I added the bumper, then 1/2" when I added the IFS skid. I've noticed no degradation in ride quality. After researching things and experimenting with my own truck, I don't recommend going over 1/2" and I'd wait to install them until you have the added weight. Having the extended studs installed and not using the spacer shouldn't be a problem.
  8. Apr 28, 2014 at 8:46 PM
    #988
    Griff 99 TRD
    I definitely did! Although, it should be noted that I put my lift on with 145k miles. I went ahead and bought some new CV axles with lifetime warranties in the event something happens to them, I'll go to O'Reilly's Auto and get new ones.
  9. Apr 28, 2014 at 8:48 PM
    #989
    tomtom
    The Desert SW
    2012 FJ
    My inners went out about 40k miles after installing the lift. This was with already having 80k miles on the boots. Fairly simple to replace and do the boot slide mod to keep them from tearing.
    My outers were just fine.
  10. Apr 28, 2014 at 8:51 PM
    #990
    Griff 99 TRD
    TomTom,
    Thanks for your input!! I had the same thoughts, but I've found it's always good to check, re-check and check again with folks with similar set ups. I'm supposed to install the bumper and winch this weekend with a buddy of mine; so, I'll order the 10mm lift enhancer shortly thereafter. The trim packer is in route with my UCAs, which should be arriving next week...I hope!!!
  11. Apr 29, 2014 at 10:41 AM
    #991
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    I've been looking at the OME parts and was wondering if the 880 coils with OME Nitro shocks with a 1.5" AAL in the rear would be good on my truck? Its an 03 4wd extended cab 2.7l with 31x1050x15 tires. Or would I be better off with the 881s without the top plate? I don't want a full 3", closer to 1.5-2.5 max.
  12. Apr 30, 2014 at 3:45 AM
    #992
    EngRWW33
    EngRWW33 Well-Known Member
    In my opinion, you'd be better off with the 881s. Take that with a grain of salt as I don't have them myself.
  13. Apr 30, 2014 at 5:36 AM
    #993
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    For a 2.7 the 880 should be fine imo. Its already a few hundred pounds less than the v6
  14. Apr 30, 2014 at 6:32 AM
    #994
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I agree. I have both top .5 spacers on mine, going to take the passenger side out. Better to be safe than sorry. Love my 881's.
  15. Apr 30, 2014 at 7:18 AM
    #995
    LoneWanderer
    Randy
    Ohio
    Is anyone running the 881s on a 4cyl without the top spacer with a 1.5" aal? From the things I'm reading I should get 2.25" or slightly more with either a level truck or a small rake which I would like. I'm looking at either that or the 880s with no rear lift but I'm afraid with my worn leafs I might get more of a bro lift than a level truck. My springs still look good and they're not sagging but they're of course far from new. I really need to keep this job under $1000 including labor but I have a buddy that will do the install for no more than half what a normal shop would charge and he can get me an alignment done for cheap too.
  16. Apr 30, 2014 at 7:31 AM
    #996
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I would like some info in general about lift heights with the various ome springs, helping a friend out with his 4banger
  17. Apr 30, 2014 at 7:43 AM
    #997
    Madjik_Man
    Colorado Front Range
    http://www.cruiseroutfitters.com/tech_OME_coils.html
    The springs are 2880, 2881, etc
    FWIW Kurt from Cruiser Outfitters said that the 881s + Dakars will settle to 2.25" of lift.
    And that the 6DXL AALs will add 3/4" of additional lift.
    I highly recommend you, or your buddy, call Kurt, Dan from Wheelers and/or Dylan from Toytec. They are all incredibly helpful.
  18. Apr 30, 2014 at 7:48 AM
    #998
    johnboyTRD
    South SF bay
    Thanks man, I'll def let him know. Bought my setup from wheelers, and had a great experience working with dan!
  19. Apr 30, 2014 at 7:50 AM
    #999
    Matic
    Tricky Dick
    Easley, SC
    And dakkars are still on backorder correct? Anyone have them in stock? I need to order this weekend or going for the all pro 3".
  20. Apr 30, 2014 at 8:15 AM
    #1000
    Madjik_Man
    In the past week mine (from Cruisers) and someone else's (from Wheeler's) just shipped.
