Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 21, 2015 at 6:46 PM
    #1781
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Awesome, good to hear.
    I'll probably PM you this weekend about the bumper kit, a fellow student in my welding class is going to come over and we are going to piece together my bumper.
    I don't have any teeth to lose :D
    It's not as dangerous as people make it out to be.
  2. Apr 21, 2015 at 6:46 PM
    #1782
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I had no fear for my teeth when I did the lca method. Haha
  3. Apr 21, 2015 at 6:48 PM
    #1783
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    For the DIY bumper I might not be as much help.. I just did the rear DIY wrap around, not the front...
    I was confused about which bumper you got.. sorry.
  4. Apr 21, 2015 at 6:58 PM
    #1784
    95 taco
    95 taco Battle Born
    Ok :thumbsup:
    I'll try to get a decent amount of pictures so I can do a mini write up or something.
  5. Apr 21, 2015 at 7:03 PM
    #1785
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    A write up for a DIY bumper? Isn't it just a big puzzle?
  6. Apr 21, 2015 at 7:09 PM
    #1786
    95 taco
    95 taco Battle Born
    Yep
    I don't know, I assume so.
    I think im going to set it up for 1/4" gap between the fenders and the wings.
  7. Apr 21, 2015 at 7:15 PM
    #1787
    MatthewMay1
    Matthew
    Lone Star Republic
    Sounds like a good amount
  8. Apr 21, 2015 at 7:57 PM
    #1788
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    If you have any questions, cbechtold on here did a front diy bumper.
  9. Apr 21, 2015 at 8:00 PM
    #1789
    95 taco
    95 taco Battle Born
    I thought so to, I think that's what Pelfreybilt tells it's customers to gap it at also.
    Thanks, I'll have to remember that.
  10. Apr 22, 2015 at 8:24 PM
    #1790
    Maestro
    Maestro Well-Known Member
    The Master
    Does the full OME for gen1 eliminate axle wrap?
    Dakar rear pack with nitros.
    Thanks
  11. Apr 22, 2015 at 8:28 PM
    #1791
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    No.
  12. Apr 22, 2015 at 8:29 PM
    #1792
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I am planning to get the relentless front plate bumper and i am on 882's. How much do you think they will settle with that bumper because i want more rake. I was thinking about aal with my dakars but that would be too much without my camper shell on. Thinking about lift shackles. Do you think It will settle enough to get some better rake. Is adding the aal hard to do? Does anyone know of a write up on it?
  13. Apr 22, 2015 at 8:30 PM
    #1793
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Wouldn't it make it better though??
  14. Apr 22, 2015 at 8:33 PM
    #1794
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Better, yes...but eliminate, no. Frame plate mod was the single best mod to date for axle wrap and wheel hop.
  15. Apr 22, 2015 at 8:35 PM
    #1795
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    With 882 coils you will probably get some good rake. johnboyTRD can comment on that because he has 882 coils :D
    I added the AAL and then took it off. Its pretty straight forward.
    - Take leaf pack off
    - Remove those bolt things that clamp the leafs sideways
    - Put C clamps on either side of the center pin
    - Remove center pin
    - Slowly remove C clamp
    - Put AAL in where it is longer then the bottom leaf but shorter then the top
    - To put it back together do in reverse order.
  16. Apr 22, 2015 at 8:42 PM
    #1796
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You're suggesting that frame flex is the cause of axle wrap? Not worn leaf springs torquing and then releasing?
  17. Apr 22, 2015 at 8:51 PM
    #1797
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    No I'm saying it contributes.
    I still had axle wrap after the Dakar springs. It was after I did the frame plate mod that the axle wrap stopped. I can't say for sure if it was axle wrap i guess, but the bed would hop around and the canopy would smack the back of the cab before and after the Dakars. The frame plates stopped that.
  18. Apr 22, 2015 at 8:51 PM
    #1798
    Digiratus
    Roaming the PNW
    The RedHead
    The key word in this is 'eliminate'. Nothing will totally eliminate the torquing action of loaded leaf springs. Eliminating all flex will eliminate that but who wants that.
    Excessive axle wrap in our trucks is a direct result of worn out leaf springs. Replacing the springs will minimize that feeling of being hit from behind when you release the brakes. At least until those springs wear out.
    Are you lifted? Are you using blocks to attain that lift?
  19. Apr 22, 2015 at 9:00 PM
    #1799
    Digiratus
    Roaming the PNW
    The RedHead
    I see what you are saying. I agree, we do have a lot of frame flex and stiffening the frame by either boxing it or adding frame reinforcement plates definitely helps keeps the bed from smacking the cab.
    I wouldn't call the bed moving around, axle wrap. Here is a graphic description of axle wrap:
  20. Apr 22, 2015 at 9:07 PM
    #1800
    Maestro
    The Master
    That wrap graphic is helpful.
    No blocks, just OME coils and Dakar rear. Fully stock prerunner now - no lift.
