Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 26, 2015 at 8:33 PM
    #1841
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Here, even when those stations along the highway are closed, the scales are still on. I drive onto the scale then peer into the window to see the readout. I've done that a few times.
    Most regular truck stops will have a scale as well tho at those you might have to pay a fee.
  2. Apr 26, 2015 at 8:38 PM
    #1842
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    It would help if I knew the statistics of my current shocks...
  3. Apr 26, 2015 at 9:39 PM
    #1843
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Probably not a bad thing to look up, should be easy enough!
    Here is the truck from side. I currently have OME Nitros on all 4 corners, 882 springs up front, Dakars with AAL in back, and 1" lift shackles. There is a fair amount of weight in the back for this photo. Probably several hundred pounds on top of the RTT, rack, and bumper. damn near level all the way around, maybe a slight lean to the rear.
  4. Apr 26, 2015 at 9:42 PM
    #1844
    MatthewMay1
    Matthew
    Lone Star Republic
    Nice. Looks to be leaning slightly lower in the rear.
  5. Apr 27, 2015 at 7:14 AM
    #1845
    Maestro
    Maestro Well-Known Member
    The Master
    I may be one of the few people here who don't have ANY problem with rake - especially .5 inches!
    Maybe its generational? Truck looks great...
  6. Apr 27, 2015 at 8:19 AM
    #1846
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Rake does serve a purpose. When the bed is loaded the nose isn't pointing into the air cali bro style blinding passing motorists with your headlights
  7. Apr 27, 2015 at 10:57 AM
    #1847
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    washed & waxed
    T@codawg likes this.
  8. Apr 27, 2015 at 1:09 PM
    #1848
    buzzhead8189
    buzzhead8189 Well-Known Member
    Matthew
    TEXAS!
    04 V6 4x4 Manual Everything
    Icon Coilovers and Rear Resi, Dakar Springs, CBI Sliders, Homemade Rear Bumper
    I too thought I was the only one on here who was pro rake.
  9. Apr 28, 2015 at 8:44 PM
    #1849
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Got my candy...
  10. Apr 28, 2015 at 8:47 PM
    #1850
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You definitely aren't, I'm at about 1.5in of rake.
  11. Apr 28, 2015 at 8:48 PM
    #1851
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Do you have the dakar with AAL?
  12. Apr 28, 2015 at 8:55 PM
    #1852
    Speedytech7
    Nope, I have a 95.5 model Taco, which means my spring hangers are in different locations than 98-2004. My truck uses the same hanger positions as the 89-95 Toyota Pickup. OME doesn't make Dakars for the 95-97 models of Taco so I bought Dakars for the 89-95 Pickup instead. These springs lift a pickup 1.75-2.25in, but on a Taco they give 3.75-4.25in. I happened to get 4.15in out of em and liked the look and function. SnowroxKT and Presto are running the same springs as me, I think SnowroxKT took a leaf out though to make it more even. I am at 3.25in in the front and think it looks pretty slick, plus it is super hard to overload these springs. I have loaded it up good and they take some good weight while staying nice and flexy.
  13. Apr 28, 2015 at 8:57 PM
    #1853
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Nice, that is quite a bit of rake haha.
    Im sitting at about 1.5 inches of rake.
  14. Apr 28, 2015 at 10:10 PM
    #1854
    johnboyTRD
    South SF bay
    Rake is nice, especially if ya load it up. I miss having rake.. it's on my list of things to address.
  15. Apr 29, 2015 at 8:10 AM
    #1855
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Question for the group...going through my parts list and noticed that there is only one extended brake line included. Is this normal?
  16. Apr 29, 2015 at 8:11 AM
    #1856
    MatthewMay1
    Matthew
    Lone Star Republic
    The one for the rear I assume
  17. Apr 29, 2015 at 8:17 AM
    #1857
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Correct...and that answers my question. Thanks!
    MatthewMay1[QUOTED] likes this.
  18. Apr 29, 2015 at 9:21 AM
    #1858
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    Sorry...had to. ;)
    MatthewMay1 likes this.
  19. Apr 29, 2015 at 9:22 AM
    #1859
    MatthewMay1
    Matthew
    Lone Star Republic
  20. Apr 29, 2015 at 10:04 AM
    #1860
    scocar
    scocar hypotenoper
    Actually, if you put that into profile view, I think that amount of rake would be pretty good...
    buzzhead8189 likes this.
