Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Apr 30, 2015 at 4:32 PM
    #1881
    WeeBrain
    WeeBrain Well-Known Member
    Erik
    PA
    22 TRDOR
    So I put my tires on tonight just to take a look and I'm rubbing somewhere. Even going straight it sounds like its rubbing. Did my pinch welds and fender screws and they clear at full lock both sides. I have no idea why it sounds like its rubbing going straight. Checked the UCA's, wheels, wheel weights, calipers, and drums and everything has clearance. Im lost.
  2. Apr 30, 2015 at 4:41 PM
    #1882
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I didn't have an impact, but I had to do this, too. Ended up cutting the bolt on the driver's side. Then got some new ones to put in there.
  3. Apr 30, 2015 at 4:48 PM
    #1883
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Here you go sir! https://www.tacomaworld.com/threads/1st-gen-suspension-install.55486/
  4. Apr 30, 2015 at 6:06 PM
    #1884
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Really!? Weird! Have you jacked it up and spun a wheel by hand? If its rubbing it'll be 100% obvious! If its rubbing you should be able to feel it along with hearing it. Its not the new tires rumbling down the road is it?
  5. Apr 30, 2015 at 6:11 PM
    #1885
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    How's your caster alignment
  6. Apr 30, 2015 at 10:44 PM
    #1886
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I wouldn't worry about it til you get the lift on and aligned. Then start diagnosing rub. You will have to trim a bit with tall tires like those.
  7. Apr 30, 2015 at 10:45 PM
    #1887
    johnboyTRD
    South SF bay
    Is it one of those engine aprons maybe hanging in the way?
  8. May 1, 2015 at 6:52 AM
    #1888
    WeeBrain
    Erik
    PA
    22 TRDOR
    Found out the cutouts on the wheels (the holes) were flared on the backside and contacting the inside of the caliper. A couple 5mm spacers will do the trick.
    alee891 likes this.
  9. May 1, 2015 at 9:59 AM
    #1889
    tarbellb
    tarbellb Member
    Denver
    03 v6 4wd ext cab
    Seriously. Im almost positive that Toyota designed these to be cut off only. I had a 5' breaker bar on it and nothing. Plan on buying the front hanger bolts beforehand.
  10. May 1, 2015 at 10:12 AM
    #1890
    Brake Weight
    Stamped steel Soft 8? Just the small hub spacer from any parts house will do.
    You may want to swap studs out, too. '04 Matrix rear studs will work. They have the same knurl as the Tacoma but are longer. The shoulder is longer, too.
    I made a thread 'OEM+' in the 1st Gen forum somewhere with more info if you're curious.
    WeeBrain[QUOTED] likes this.
  11. May 1, 2015 at 10:50 AM
    #1891
    WeeBrain
    Erik
    PA
    22 TRDOR
    Well that puts a damper on things. Finding replacement bolts today or tomorrow morning so I can do the swap is looking pretty slim. My local Toyota dealer closes their parts department on Friday and isn't back until Monday.
  12. May 1, 2015 at 11:08 AM
    #1892
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    May not be seized, at the very least crawl under and put a wrench on the bolt and nut, loosen the nut and see if the bolt itself will turn. If it does, you should be okay.
  13. May 1, 2015 at 1:01 PM
    #1893
    WeeBrain
    Erik
    PA
    22 TRDOR
    Fingers crossed
  14. May 1, 2015 at 1:47 PM
    #1894
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Grade 8 bolts will fit as a replacement for your leafs. I can't remember the size off hand, but I think it was 1/2" bolt 5" in length. I'd recommend getting greasable bolts though, or you will end up in the same predicament you are in now.
  15. May 1, 2015 at 3:24 PM
    #1895
    scocar
    scocar Patron of the Farts
    Somone recently provided the size. I think it is about 100mm long. I know when I looked around, this was right bewteen the 4 and 5 inch bolts I found...and it has to be just right, especially on the gas tank/driver side.
  16. May 1, 2015 at 4:02 PM
    #1896
    tarbellb
    tarbellb Member
    Denver
    03 v6 4wd ext cab
    Someone wrote this "The bolt size is M14 x 1.5 x 100mm long grade 8. I think the dealership charges around 17 bucks a pop"
    _ front spring hanger bolt - #901-05-14025 ------- dealer ~$8 / online ~$4
    _ accompanying nut - #901-79-14039 ---------------------------/ online ~$1.50
    _ accompanying washer - # 902-01-14005 ----------------------/ online ~$1.50
    My dealer only charged $8 each, maybe $10 w/ the nut. -
    Anyways, you only have one dealer ship? Start calling your local Metric fastener supply house, they likely aren't open on weekends?
    Try to find ones that are not fully threaded, having the shoulder will be nice, but not a biggie. You can likely find a close SAE bolt
    to fit.
    Good luck.
  17. May 1, 2015 at 4:58 PM
    #1897
    Brake Weight
    I've had luck at NAPA and CarQuest for random bolts on Saturdays. Catch them before noon though.
  18. May 2, 2015 at 4:38 PM
    #1898
    WeeBrain
    Erik
    PA
    22 TRDOR
    Well, after a painstaking rear spring removal (cut everything but the kitchen sink), I started assembling. One of the OME shackle nuts stripped while torquing to spec. Not that big of a deal, just another shit to add to the shit pile. Then, I go to put the shocks on and the leafs won't let the axle compress enough to get the shock on its mount. Only shy by like....3" HA!. I put 5 spare wheels and tires in the bed as well as the old leaf springs to give her some weight and still won't let me compress them enough to mount. So I gave up for tonight. Exhausted, full of band-aids, and covered in rust/dirt/grease..... time to unwind.:cheers:
  19. May 2, 2015 at 4:40 PM
    #1899
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Beer-30 my friend :cheers: it'll be easier tomorrow once you walk away. That's what I've always found when I'm working on the truck. Walk away for a few hours come back and boom. Smooth like butter. Haha
    WeeBrain likes this.
  20. May 2, 2015 at 5:31 PM
    #1900
    johnboyTRD
    South SF bay
    I don't understand why your shock won't reach, doesn't make sense to me. Basically your saying it's like you are fully drooped past the reach of shock right? Are you trying to reuse the oem shock or something? Sorry about your shackle bolt that sucks.
