Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. May 4, 2015 at 2:44 PM
    #1921
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Not unless you wheel hard - I ran that size on stock rims w/o any problems, well I did tear off a front mud flap....
  2. May 4, 2015 at 7:04 PM
    #1922
    WeeBrain
    WeeBrain Well-Known Member
    Erik
    PA
    22 TRDOR
    Well got it all together this weekend. Ill make myself useful this time and post a pic.20150504_160503.jpg
    OME 882's/Dakar Leaf kit from Wheelers w/ rear axle pin relocate plates (3/4" forward)
    16x8 Vision Soft 8 style (4.5 BS)
    255/85r16 Cooper ST MAXX
    Have yet to get it articulated. Might remove the rear axle pin relocate. It was recommended to move the axle forward .5" to get full articulation with that size tire (http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html) I couldn't find .5" ones so i got .75" ones from Skyy Manufacturing. Not sure but it seems like the wheel is too far forward now. I guess we will see when I get to twist it up.
    T@codawg likes this.
  3. May 4, 2015 at 9:02 PM
    #1923
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    IMO, the fact that the boots have started to seep is not necessarily a failure. Whether or not it leads to a tear, only time will tell. The seep is caused by the increased axle angle. The grease is being forced out.
    The more axle angle you have the more likely this will occur. FWIW, mine have been seeping for almost 3 years without tearing and without running out of grease. They are the original axles with almost 150K. I do have adjustable COs tho and try to limit the lift to 2.5" over stock. I have also run a diff drop since I first put a lift on it and no swaybar.
  4. May 4, 2015 at 9:20 PM
    #1924
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    I got a 3 cartridge pack of Mobil, I don't remember where I bought it but I'm sure it's sold at multiple locations.
  5. May 4, 2015 at 9:39 PM
    #1925
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Looks fantastic love these tires too!
  6. May 4, 2015 at 9:42 PM
    #1926
    TacoVio
    Kolton
    CO/WY
    Mobile 1 Synthetic right? Sorry for all the questions too :(
  7. May 4, 2015 at 9:51 PM
    #1927
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    That was my assumption, as the angle is rather extreme at the moment. I was hoping the diff drop would relax the angle just enough to eliminate the seep until I can get a heavier bumper up front. I guess I just wasn't expecting them to seep almost as soon as I removed the sway bar. The seep is very minor, I just hate seeing a few grease spots sprayed on the frame and wheel well.
  8. May 4, 2015 at 9:53 PM
    #1928
    alee891
    Austin
    Black Hills
    Tacomaless
    Oh hell yeah!:thumbsup:
    WeeBrain[QUOTED] likes this.
  9. May 4, 2015 at 10:15 PM
    #1929
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Don't you want to move the axle back, not forward? Never heard of anyone having a problem with axle being too far back with dakars.
    Edit: I know you are stoked to be done, but... I think you are gonna need to turn the axle shims around. Just my thoughts...
  10. May 4, 2015 at 10:18 PM
    #1930
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I agree, front axle look way to far forward.
    Truck looks great though!
    WeeBrain likes this.
  11. May 5, 2015 at 12:31 AM
    #1931
    Twitch.
    Twitch. Well-Known Member
    delta what are your thoughts on he axle relocation plate? specifically the one you had listed in your build.
    I didn't get that, the 10 mm spacers or the 10 mm trim packer for the driver side.
    I don't see the taco "lean" on my 4dr and the 10mm spacers I some times pull a trailer with motorcycles.
  12. May 5, 2015 at 12:56 AM
    #1932
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    With my 265 sized tires I do not need to run the axle relocation plates yet. When I step up to 255 I plan to move the axle back to center the axle more with the relocation plates.
    That's fine with the spacer and trim packer. I don't have a need to run that yet either.
  13. May 5, 2015 at 1:56 AM
    #1933
    2000tacobro
    2000tacobro Well-Known Member
    Houston , texas
    2014 Trd OR 4x4
    trd pro grill
  14. May 5, 2015 at 1:58 AM
    #1934
    2000tacobro
    Houston , texas
    2014 Trd OR 4x4
    trd pro grill
    Dakar leafs, ome shackles , ome rear shocks, rear brake line , lspv extension , ome u bolts . Got installed in redding at fearless off-road , great shop
  15. May 5, 2015 at 6:58 AM
    #1935
    Jiveydude
    Micah
    OH
    04Taco
  16. May 5, 2015 at 7:20 AM
    #1936
    TacoVio
    Kolton
    CO/WY
  17. May 5, 2015 at 8:41 AM
    #1937
    WeeBrain
    Erik
    PA
    22 TRDOR
    The Expeditions West post suggests the axle needs to go forward with these size tires so that it will not destroy the rear of the fender under compression. It makes sense that the axle will move back as the spring is compressed because it is anchored solid at the front mount and the rear mount can move forward and back by the way of the shackles. Therefore as the spring compresses and essentially straightens out and gets slightly longer, the axle will move back as it goes up. How much? Im not sure. Most likely a very small amount. I would like to get it on something to compress the rear and see how it goes. Might have to remove the pin relocates at most but I dont believe it should be moved back any from the stock position. The tires were close to the rear of the fender when installed without the lift.
    From the Expeditions West post:
    - Rear: Deaver custom 10 leaf pack with .5" center pin adjustment to midline of truck. Expedition load height: 1.75-2.00". The rear suspension is critical to fitting these tires, as the center pin MUST be moved forward .5" to allow full compression or the tire will destroy the rear of the wheelwell. -
  18. May 5, 2015 at 2:42 PM
    #1938
    johnboyTRD
    South SF bay
    Yeah you def don't need it, that's for sure :)
  19. May 5, 2015 at 2:53 PM
    #1939
    Twitch.
    I want my parts in so they can be on and I can post pictures.......
  20. May 10, 2015 at 10:09 AM
    #1940
    TotesMagotes
    TotesMagotes Too Drunk To Taste This Chicken
    British Columbia
    '01 Double Cab 4x4 V6
    OME Lift, 285's
    Question for anyone running the dakar leafs, how do they handle a heavy load in the bed? Is there much sag? I'm looking to haul a couple dirt bikes and I want the right leafs to do the job. If any of you could do it again, would you go with the dakars or something different? Thanks!
    100 pages of OME!!!! Awesome.
