Old Model Marlin 80
Discussion in 'Guns & Hunting' started by beastlytaco, Dec 21, 2008.
  1. Dec 22, 2008 at 7:21 PM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    cool. Im gonna try and get it all cleaned and back to its original functioning condition
  2. Dec 22, 2008 at 7:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    post pics after the resto bro!!
  3. Dec 22, 2008 at 7:24 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    i plan on doing that
  4. Dec 23, 2008 at 9:56 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Am late in posting this but will throw my two cents in.
    Just finished a few Reising's but they did not want them re-blued. I used 0000 steel wool and a gal of WD-40, made sure the metal and wool was soaked and went over it a few times, since the finish was about gone no biggie. Also hit the wood, in the pistol area and cheek area to get years of grime off.
    Check the metal for heavy pitting, if to bad only a buff will remove. Check the bore if you want to fire it again, I know in most cases old .22's the bores are shot, from years of great service, only a sleeve can fix this problem. For I piece that was handed down in the family......for me, clean it up, and sit back and think of all the fond memories it had.
  5. Dec 23, 2008 at 10:18 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah i guess, bu ti was wanting to pass it down to the next generation in my family when i can. and i would like for t to be functional. My buddy also recently inhereited a 1913 Winchester leveraction .22 from his father. and i would like to pass my .22 down as well.
  6. Dec 23, 2008 at 11:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Since it is a .22, I highly recommend de-leading the barrel. I can't remember the product name at this moment. Simply run a soaked cloth through the barrel a few times. Then plug a wet cloth in one end and a saturated one in the other. Stand it up in the corner with the saturated cloth up for a couple of days. This will allow the de-leading chemical to run down the barrel and absorb into the bottom cloth. The fumes then fill the barrel and remove further lead. Take care of the rust first though. Good Luck!!
    EDIT: Here it is. Highly recommended!
  7. Dec 23, 2008 at 11:20 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    thanks. where can i get this stuff
  8. Dec 23, 2008 at 11:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    You should be to get it where ever gun cleaning supplies are sold.
  9. Dec 31, 2008 at 8:42 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    allright, well i got the gun all cleaned up ( except for the outside of the barrel) and I ran about 50 rounds through it. for an old bolt action it did surprisingly well at 50 yds. my spread was pretty well close together. and that was with iron sights
