OME "2885"
Discussion in 'Suspension' started by MateoTorgy, Oct 9, 2014.
  1. Oct 9, 2014 at 9:34 PM
    MateoTorgy
    MateoTorgy [OP] Well-Known Member
    Mateo
    Minnesota
    2014 TRD OR AC 6 Cyl
    OME recommends "2885" coils for my truck. Is that the "885" members talk about on TW or is the 2885 a newer coil?
    OME also recommends the nitro charger sport strut 90021. They say this combo yields a lift of 1 31/32" of lift up front.
    The kit comes with a "driveline spacer kit." I'm assuming this is Australia's way of saying diff drop kit? It was my understanding that wasn't necessary for lifts under 2 1/2 or even 3 inches.
    Many stupid questions here.
    Thanks.
  2. Oct 9, 2014 at 9:50 PM
    MateoTorgy
    Mateo
    Minnesota
    Thank you!
  3. Oct 9, 2014 at 9:53 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    wut?
  4. Oct 9, 2014 at 9:59 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  5. Oct 9, 2014 at 10:03 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    by 'strut' i thought you meant the shock + spring assembly. I see Mateo was using the same terminology, so consistency less confusing :thumbsup:
  6. Oct 9, 2014 at 10:09 PM
    MateoTorgy
    Mateo
    Minnesota
    Thanks guys. Appreciated.
  7. Oct 9, 2014 at 10:20 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  8. Oct 10, 2014 at 5:54 AM
    MateoTorgy
    Mateo
    Minnesota
