OME 880 OR 881
Discussion in '4 Cylinder' started by 2000SIG, Nov 20, 2010.
  1. Nov 20, 2010 at 7:25 PM
    2000SIG
    2000SIG [OP] Well-Known Member
    Just got my bilstein last week and looking at the ome 880 and 881.
    I have a 2004 ext cab with the 2.7l.Will the 881 be too high for my 4cyl?
    I'm going to order the wheelers progressive aal at the same time so I'm trying to get some info before I get everything together.I want to leave the 5100 at zero and add the coils+ the wheelers aal(1.5" lift) and hoping tha the truck is level.
    thanks
  2. Nov 21, 2010 at 6:22 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    881 will give you 2 inches of lift with bilstiens are 0"
  3. Nov 21, 2010 at 6:25 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    You might be a tad low. 881's should give you 2.75 of lift with the provided .5 spacer from toytech anyway. Thats with stock shocks.
  4. Nov 21, 2010 at 6:29 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    I have the 2.7 and I went with the OME 880. I was told that unless you had like a heavy winch on the front of your vehicle the OME 881 would be too much. Here is a link to a nice page that lists the lift amounts from using the OME coils: http://fresh.tacomaterritory.com/wiki/index.php/OME
  5. Nov 21, 2010 at 6:35 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So did the 880 coils give you any lift?
    So without the .5 inch spacer just coils alone after settling in will give you 2" of lift maybe like 2.1" and the spacers is not provided its optional and cost extra $
  6. Nov 21, 2010 at 6:37 PM
    Matic
    Rich
    Greenville,sc
    6 Cylinder 4x4 (lift amounts will be higher for prerunners)
    ooops. my bad. he has a 4 cyl.
    4 Cylinder 4x4 (lift amounts will be higher for prerunners)
    • Regular Cab
      • 880: 1.0"
      • 881: 2.5"
      • 882: 3.5"
    • Extra Cab
      • 880: 0.75"
      • 881: 2.0"
      • 882: 3.5"
    • Double Cab
      • 880: 0.5"
      • 881: 2.0"
      • 882: 3.0"
  7. Nov 21, 2010 at 6:40 PM
    Matic
    Rich
    Greenville,sc
    Well, the only way to tell is to have him measure from the center of the center cap to the bottom of the front fender. I could tell you exactly how much lift an 881 OME will give you with stock shocks. Providing he is a prerunner and not 4x4.
    I have 24 inches exactly.
  8. Nov 21, 2010 at 6:59 PM
    2000SIG
    Ok thanks guys .Gf doesn't now what to get me for xmas ,so I hace mentionned the coils.Can't wait now.
  9. Jun 17, 2011 at 2:49 PM
    04SilverTRD
    04SilverTRD Member
    Wisconsin
    04 Access cab 4x4 Silver - Stock
    None
    I've seen these numbers from the link above, but they don't make sense to me. There is a note below these numbers that says...
    880-882 specs: all are a 500# rated coil with the same # of coil wraps, only the length is different 880s are 365mm long; 881s, 375mm; 882s, 395mm
    Ok, so if these coils are the same save the length, then why doesn't the projected lift differ by the coil length difference?
    For example - look at the reg cab 880 vs. 881. - It says that there is a 1.5" (38 mm) difference in lift. (1" for 880's and 2.5" for 881's).
    If the 880 and 881 coils have the same # of wraps and spring rate, but one is just over 3/8" (10mm) longer, then why is the projected lift nearly 4 times that much at 1.5" (38mm)?
    It seems to me that if the 880 gave a reg cab truck 1" (25mm) then the 881 being 10mm longer would give 35mm and the 882 being 30mm longer would give 55mm of lift over stock.
    What am I missing here?
    thanks,
    Keith
  10. Dec 17, 2012 at 1:22 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    Per TTORA, 881's will be 2.5 but like someone else posted, it would probably be around 2.75"+ then settle.
    http://www.ttora.com/wiki/index.php/OME
    1st gen
      • Regular Cab
        • 880: 1.0"
        • 881: 2.5"
        • 882: 3.5"
      • Extra Cab
        • 880: 0.75"
        • 881: 2.0"
        • 882: 3.5"
      • Double Cab
        • 880: 0.5"
        • 881: 2.0"
        • 882: 3.0"
