OME 881s or Bilstein 5100s?
Discussion in 'Suspension' started by cmm275, Apr 13, 2012.
  1. Apr 23, 2012 at 1:06 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Go ICON or Fox even Camburg and Sway 2.5 then.
  2. Apr 23, 2012 at 1:19 PM
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    yea i have been looking at the icons, fox's, and SAW's and it seems like the SAW's are the cheapest so thats what im looking for. i havent heard anything bout the camburgs, do you know if there good?
  3. Apr 23, 2012 at 6:06 PM
    sirsaechao
    Tim
    CA
  4. Apr 23, 2012 at 6:54 PM
    white toy taco
    Albuquerque, NM
    cool thanks for the info
  5. Jun 7, 2012 at 10:16 AM
    cmm275
    cmm275 [OP] Well-Known Member
    Northern California
    2019 TRD Off-Road
    So I don't really know if anyone will see that I am making a post to this thread this much later... however, this is what I ended up doing.
    Since the 5100s were out of stock for the longest time I first installed some Daystar 1.25 inch spacers. No pictures of this but they got the truck almost level. Maybe like .5 inch still of rake.
    The 5100s finally came in and at this point I wanted to go a little higher with the ride height and get the rear 5100s since my shocks were shot. This is what it looks like now with the front set to 2.5 and a wheelers aal in the rear.
    The 5100s ride amazing and I am really happy with it, however there is even more rake now than with the spacers. I expected some rake since I didn't get the eibachs but thought it would only be like .5 inch.(it looks level because of the slanted driveway but its not)
    I really just like the look of a level truck so this is my problem now. What do I do?
    1. wait and hope the leafs settle a bit and not have to deal with anything else
    2. look into the eibachs and have to deal with cv problems and UCA problems
    here is my cv angle now
  6. Jun 7, 2012 at 10:23 AM
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    Nevermind I see now you said rake lol
  7. Jun 7, 2012 at 10:38 AM
    white toy taco
    Albuquerque, NM
    if you get the eibach lift springs, im 95% sure you will have to get longer shocks. so that will equal a whole new shock/coil set up, not cheap.
    i would just wait for the leafs to settle. just put as much weight on top of the axle as often as you can. if this doesnt work, i would take out the aal and get a smaller one (idk much about aal so im assuming you can get a smaller one). if not, take out the aal and get extended shackles which will add a bit of lift
    also, i have the daystar 2.5 coil spacer lift with stock rear suspension and that gives it a little bro lean but pretty close to level. hope this helps
  8. Jun 7, 2012 at 10:50 AM
    cmm275
    Northern California
    2019 TRD Off-Road
    There are like 8,000 people on this website that run eibachs on 5100's...
    As far as the rear goes, I got the 1.5 inch aal which as far as I know is the lowest. I don't want to downgrade to a block or shackles because before I installed the aal my leaf pack was shot(pretty much had no arc to it). If I take it out I will be back to square one, not to mention the rear 5100s needing the extra height so that they don't bottom out.
  9. Jun 7, 2012 at 11:17 AM
    white toy taco
    Albuquerque, NM
    yea a lot of people do run eibachs/5100's, but that wasnt my point. i was trying to say that if you get the lift springs, you have to get longer shocks... heres what toytec says about the 3 in lift springs "95-04 Tacoma 3" lift (Will not work on stock length shocks)" which can be found about 5 lines under the price at
    as for the aal, ive read that they actually decrease axle flex and stiffens the ride but idk how much wheeling you do to care about flex.
    also, i believe you can actually put a coil spacer on top of your billies (they do it on the OME set up) for some more lift. check out this lift info guide http://www.customtacos.com/tech/index.php?article=137
  10. Jun 8, 2012 at 10:48 AM
    cmm275
    Northern California
    2019 TRD Off-Road
    Yeah I have thought about the spacer but don't want anymore preload than I already have with the 5100s set at 2.5. If I were to go higher I would just spend the money and get the eibachs. Just don't know if I want to deal with all the cv and Uca problems that come along with that much front lift.
    Does anyone that actually has 5100s/eibachs have any input as far as whether it's worth it to get the coils?
  11. Jun 8, 2012 at 11:50 AM
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I just installed the 5100's set at 1.75 and my UCA is already less than 2 inches from the tire. I am not sure if its supposed to be like that. Based upon this if I get new coils new UCA's are a must.
  12. Jun 28, 2012 at 1:08 PM
    cmm275
    Northern California
    2019 TRD Off-Road
    Norton, how are you liking your setup with the OME 881s? Have they settled at all? How close is it to level with your 5 leaf packs? Have you run into any cv axle problems?
    I have my 5100's set at 2.5 (w/1.5 aal in back) at the moment and am over 2 inches high in the rear due to sagging coils. Considering getting the OME 881s like you. Also considering getting the 10mm top plate to get a little extra lift but not sure if I will need it.
  13. Jul 1, 2012 at 2:50 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I remain very pleased with my OME 881 / Bilstein 5100 / Wheelers 5-leaf combo. I've experienced minimal settling - perhaps 1/2" or so. My truck sits level with the camper top installed and has a slight rake without it. No CV problems yet (keeps fingers crossed), but I don't think my angles are too extreme.
  14. Jul 2, 2012 at 1:05 PM
    grahamslam
    grahamslam New Member
    '02 4x4 DLX
    Do new tires count?
    I'm planning on lifting my truck one step at a time, since money is tight. My plan is to start with 5100's all around, then eibachs when I can afford it. Also AAL's at first, then maybe new spring packs later.
    Will it be a problem to put 1500's on the rear without any lift? If I get AAL's now, which ones? I was thinking toytec but I don't want 2" in the rear and have to max out the front shocks...maybe 1" shackles for now? Any thoughts?
    What other misc parts will I need? Front shock bushings? Diff drop? Exhaust hanger? BPV extension? I also plan to get poly bushings for the rear springs, even if I keep the stock shackles.
    Any feedback is greatly appreciated.
  15. Jul 2, 2012 at 6:49 PM
    #35
    Norton
    Welcome to TW!
    Based on DSM's recommendations, you may encounter problems using 5100s without any rear lift. Details are posted here and here but, the bottom line is that they've found 5100s to be "too long for no lift". Instead, they recommend 5125s for "stock" height applications. I highly recommend a BPV bracket extension, but haven't found a diff drop to be required.
    For the rest of your questions, I recommend you spend some time perusing the Tacoma Lift FAQ/Guide and Suspension Lift Info stickies.
  16. Aug 5, 2012 at 2:06 PM
    #36
    cmm275
    Northern California
    2019 TRD Off-Road
    If anyone is curious, I am now running 5100s all around with OME 883s up front and the wheelers 1.5 inch aal in the rear. I would highly recommend the 5100s over the stock shocks and would also highly recommend getting a lift spring as opposed to preloading the 5100s. The aal also put a lot of life back into my leaf packs.
