OME 883 or Eibach
Discussion in 'Suspension' started by DoubleTake, Mar 4, 2013.
  1. Mar 4, 2013 at 8:24 AM
    DoubleTake
    DoubleTake [OP] Well-Known Member
    I have a 98 Tacoma ext cab 3.4l 4x4. I currently have the OME Nitro front shocks with 881 coils. I am wanting to add an ARB bumper with a warn m8000 winch in the near future. I was originally thinking of going with bilstein/Eibach combo. I like the height I am sitting at right now with the 881. Would it be better to just add 883 up front? What is the spring rate difference between the Eibachs and OME 883? I just dont want a lot of sagging with the added weight. Thanks
  2. Mar 4, 2013 at 12:40 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  3. Mar 5, 2013 at 5:42 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I would think you should be comparing 882's vs Eibach since 882's are taller springs vs 883's which is the same height just 881 500lbs vs 883 590lbs.
  4. Mar 5, 2013 at 6:39 AM
    DoubleTake
    That's the thing, wouldn't I need stronger rate coils rather than just taller coils? I would rather have stronger rate coils (883) that hold their height over time than having some sag in no time (882). I am fine with the heighth I am at with my 881 right now, but I will go higher with the Eibachs if I need to if they would be the better option with an ARB bumper/winch.
  5. Mar 8, 2013 at 5:54 AM
    DoubleTake
    Here is my dilemma, I have the OME shocks w/ 881 on my truck right now. Would I better off swapping to Bilstein/Eibach or just swapping from 881 to 883 for a bumper and winch? I want to know which combo will hold up my bumper and winch better over time. I am not concerned about the lift difference between the two, just their ability to hold up the extra weight. I would probably get a top plate spacer for an extra 1/2" or so with the 883 if I went that route.
