OME 885, 5100's, LR UCA Topping out?!
Discussion in 'Suspension' started by steezinstangl, Mar 5, 2013.
  1. Mar 8, 2013 at 10:57 PM
    #61
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    I'm at 24" with 884's on a regular cab prerunner, aren't 885's a little longer but same spring rate?
  2. Mar 8, 2013 at 10:57 PM
    #62
    steezinstangl
    steezinstangl [OP] Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    i mean i have pretty big tires on it i think.. 265/70/17 BFG Rugged Terrain's on a 17x9 rim so spreads the tire out pretty good. theres a few people on here i've also seen that got a big lift out of nowhere with the 885's.. i think its strange too
  3. Mar 8, 2013 at 10:57 PM
    #63
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    yep, 10mm longer
  4. Mar 8, 2013 at 11:01 PM
    #64
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Hub to fender measurement is not effected by tire size
  5. Mar 8, 2013 at 11:02 PM
    #65
    OZ-T
    Peter North
    British Columbia
  6. Mar 9, 2013 at 12:11 AM
    #66
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Tomorrow I'm tearing it apart so when I do, I'll measure the center hub to bottom of the fender.
  7. Mar 9, 2013 at 12:13 AM
    #67
    OZ-T
    Peter North
    British Columbia
    You don't have to rip it apart to measure that and I thought you said you did and it was 24" ?
  8. Mar 9, 2013 at 12:21 AM
    #68
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Hahaha I'm so dumb that won't work because then my suspension wouldn't be compressed since its jacked up! My bad lol
  9. Mar 9, 2013 at 12:22 AM
    #69
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    But yeah it was about 24. Give or take 1/8th inch or so.
  10. Mar 11, 2013 at 2:34 PM
    #70
    SnowmanFX
    SnowmanFX Well-Known Member
    San Antonio, TX
    TX Pinstriped 08 Tacoma
    3" Lift w/small goodies
    Do you have the rubber ring that goes between the spring and tophat? I can't tell if yours is there. Mine kinda laps over and is easy to see.
    If it is not there you will have noise from the spring rubbing on the stud bolts.
  11. Mar 11, 2013 at 2:43 PM
    #71
    Geo Taco
    Geo Taco Well-Known Member
    Justin
    Lafayette, CO
    2012 Subie Impreza
    Black Softopper
  12. Mar 12, 2013 at 6:16 AM
    #72
    SnowmanFX
    San Antonio, TX
    It is a long shot but, did you have your springs installed at a shop? Did they use an impact to tighten the top plate spacer down?
    If so and they spun the shaft of the shock, they could have damaged the strut. I remember reading that you are not supposed to use an impact to put on the nut and that is can damage the strut.
  13. Mar 12, 2013 at 6:49 AM
    #73
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I have 885 with nitros. Same speed bump clunk. Weight down the front and the clunk reduces or goes away. The 885 is meant to counter the weight of ARB bumper. I read that on the ome/arb Australian site. When you jack the truck I bet your wheel hardly drops any before tires are off the ground. Same thing happens on bumps only faster. Slamming to full extension. That's what I think it was on mine anyway.
  14. Mar 12, 2013 at 6:54 AM
    #74
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    how about trying a set of limit straps? :crapstorm:
  15. Mar 12, 2013 at 7:48 AM
    #75
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I thought 885s were for 0-100lbs extra weight and 886s are for 100lbs+. Ive never had the when goes over speed bump clank, but i do think my sway bar hit my coil once when i was wheeling. I still have close to 2" of downtravel with 885s and nitrochargers. I have a little added weight tho from my sliders. I agree tho about the shock reaching full extension, when all other factors are rulled out it seems like that is the most logical reason the clank happens.
  16. Mar 12, 2013 at 7:52 AM
    #76
    prerantaco
    prerantaco Well-Known Member
    mesa, az
    prerunner
    my first gen did this same thing you guys are describing, and it was because my shock was almost all the way extended. hitting a speed bump would make the tire come off the ground easy and fast, kind of causing "speed bump clank"
  17. Mar 12, 2013 at 8:04 AM
    #77
    OZ-T
    Peter North
    British Columbia
    886's are for an ARB and winch
  18. Mar 12, 2013 at 8:04 AM
    #78
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Easy check. Get 2 or 3 passengers in the cab. Then see if you notice an improvement on speed bumps. Heavy people are great for testing suspensions. :D
  19. Mar 12, 2013 at 8:18 AM
    #79
    SnowmanFX
    San Antonio, TX
    I like easy free test!
  20. Mar 12, 2013 at 8:19 AM
    #80
    disc0monkey
    Im serious though.
