OME 885 with Plate Bumper
Discussion in 'Suspension' started by Mickdizzle, Jan 30, 2012.
  1. Jan 30, 2012 at 12:07 PM
    Mickdizzle
    Mickdizzle [OP] Well-Known Member
    Montana
    12 TX Pro
    I am getting ready to order this week the suspension for my 12 tacoma. I ordered a plate bumper from relentless fabrication and should be here in about 4 months. I am going to be running a smittybuilt xrc-8 winch on there. I have read quite a bit on how rough the ride is with the 886's and i am thinking about going with the 885's instead. my tire size is 265/75/16 and i do not plan on going any bigger with these. has anyone run 885s with a plate bumper and winch and if so how was the ride? Did the front end sag with the added weight?
  2. Jan 30, 2012 at 8:51 PM
    Ermine
    Ermine Well-Known Member
    Colorado
    V6 Tacoma
    3 inch OME Lift
    not for sure but have heard if you are going to get a aftermarket bumper and winch go with the 886. If no then the 885
  3. Jan 30, 2012 at 8:56 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    886's are great, i run em with my ARB and i love them, you're gonna need them too for that relentless bumper
  4. Jan 31, 2012 at 9:11 AM
    Mickdizzle
    Montana
    12 TX Pro
    alright i just wanted to find out i guess if anyone has run the 885's with any luck. Have been hearing that even with the plate bumper the 886's are a rough ride.
  5. Jan 31, 2012 at 11:40 AM
    ross123
    ross123 Well-Known Member
    fort bragg
    im having my 886's installed tomorrow without a plate bumper. yet. more to follow
  6. Jan 31, 2012 at 11:47 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    I got TJM's made to support ARB bumper. Its in my build thread, a little cheaper to cause not a *name brand*.
  7. Jan 31, 2012 at 12:06 PM
    Mickdizzle
    Montana
    12 TX Pro
    your truck looks like it sets nice and level...what are you running in the rear. I am torn there whether i should go with the dakar leaf pack or an AAL and what size AAL to go if i do
  8. Jan 31, 2012 at 12:07 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I ran 885's with no winch. With a winch, you'll want the 886's for sure.
    libagui likes this.
  9. Jan 31, 2012 at 12:16 PM
    Mickdizzle
    Montana
    12 TX Pro
    Hey eric, just looking to get the suspension knocked out before the bumper shows. With the 886's what would you suggest running in the rear to make the truck sit level.
  10. Jan 31, 2012 at 12:23 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    1.5" AAL or 2" if you want a little rear rake
    :Edit:
    don't forget to get new U-Bolts too :)
  11. Jan 31, 2012 at 12:52 PM
    Mickdizzle
    Montana
    12 TX Pro
    alright i am going to order from wheelers off road. Just want to make sure that i am not missing anything.
    FRONT
    OME90000 Nitrocharger sport front shock set
    OME886 Front Coil Set
    OME 95pf5 5mm Trim packer (For DS Lean)
    REAR
    OME N182 Nitrocharger Rear Shock Set
    Wheelers 1.5-2" AAL Kit (Not sure which one i will go with yet)
    OME U-bolt set
    IS there anything else that is neccessary to get this done? Should i throw a new bushing set in my order? What about a driveline drop kit?
  12. Jan 31, 2012 at 12:55 PM
    RelentlessFab
    Eric
    Might want to add in a rear driveshaft carrier drop kit too. It'll help with the take-off shudder thats common with lifting
  13. Jan 31, 2012 at 1:08 PM
    Mickdizzle
    Montana
    12 TX Pro
    I will do that. The part is only 12 bucks. I am contemplating just ordering the whole kit that comes with the Dakar leaf pack. I don't know if that will be enough lift in the rear with the 886's. I don't want the front end higher than the rear. honestly would rather have a little rake in the rear.
  14. Jan 31, 2012 at 1:10 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I know you're already getting the 886s, but just to throw some more experience with those who have that set up. With that weight up front, if you hit larger bumps on and off road, you're going to want beefier springs to take the hit versus your bump stops.
    I've run the 886s, with the ARB and with the ARB/Winch. Harsh is not the word I'd use to describe it. More like Solid. And when you take larger obstacles it's cushy.
  15. Jan 31, 2012 at 1:11 PM
    RelentlessFab
    Eric
    The dakars give about 2.75" lift in the rear, more than enough. It will give you a similar rake to a stock truck, just with the higher lifted stance. The dakars ride pretty rough though, they're designed as an all around pack for hauling loads often without sagging, so unloaded over speed bumps is pretty harsh
    How much do you tow/haul?
  16. Jan 31, 2012 at 1:18 PM
    Mickdizzle
    Montana
    12 TX Pro
    I honestly don't tow a ton and when i do it is either a 2 place snowmobile trailer or a jumping jack with 2 four wheelers on it. So do you think that i would be better off just getting an AAL? I am looking for a comfortable ride too.
  17. Jan 31, 2012 at 1:19 PM
    Mickdizzle
    Montana
    12 TX Pro
    thank you for the input...that was exactly what i was looking for. what are you running in the rear if you don't mind me asking
  18. Jan 31, 2012 at 1:28 PM
    Toy Yoda
    Garrett
    06 DCLB
    my truck sits high in the front as i only have 2" blocks in the rear with OME N182 shocks, I'm going to switch out the blocks eventually, but right now I'm looking at 1" blocks with 2" aal to restore the factory "rake"
  19. Jan 31, 2012 at 1:29 PM
    RelentlessFab
    Eric
    The wheeler's 3 leaf mini pack AAL kit would probably be good for your uses and have a better ride than single leaf AAL would.
  20. Jan 31, 2012 at 1:32 PM
    Toy Yoda
    Garrett
    06 DCLB
    i wouldn't say you're paying for the name of OME when you buy their components, not that I'm dissing TJM, I'm just saying i think the level of quality of OME is priced very competitively considering the quality of ARB's suspension
