OME 885s + Rear TSB
Discussion in 'Suspension' started by brandob9, Jan 15, 2010.
  1. Jan 15, 2010 at 9:44 AM
    brandob9
    brandob9 [OP] Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Has anyone tried this combo? Does the rear just let the whole party down?
  2. Jan 15, 2010 at 9:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That rear TSB isn't a full lift perse- It'll raise the rear a bit but if you want to keep the truck rake you'll need an AAL. You might end up level you might not if you just go with the TSB.
  3. Jan 15, 2010 at 9:51 AM
    brandob9
    Brandon
    Portland, OR
    09 DC Long Bed
    Actually, what I was trying to get at is this: Is the combo going to handle in weird ways? What if I use a block or AAL?
  4. Jan 15, 2010 at 9:53 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I got the 885's with 5100's all around and just a 2" rear AAL. I didnt get the rear TSB done.;) Truck leveled out just fine!!
  5. Jan 15, 2010 at 9:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Won't handle weird as long as you get a good alignment...People drive trucks with the nose higher, lower, and level with the rear...so it can be done.
    Don't use blocks...AALs are cheap and again...as long as they are properly installed...No issues.
  6. Jan 15, 2010 at 10:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And I have the 885's (OME shocks), and the TSB, and a 1.25" AAL, and Im pretty much level. The rear is .5" or so higher than the front.
  7. Jan 15, 2010 at 10:46 AM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    Yeah, proper alignment is certainly important. But if you're doing any hauling or towing and the front of your truck is higher, you might serious screw up your front suspension or brakes. I've seen it happen. Pricey fix, too.
  8. Jan 15, 2010 at 1:28 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I thought the 885's only gave 2 inches of lift, wouldn't that plus the tsb be pretty level?
  9. Jan 15, 2010 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They give 3"
  10. Jan 15, 2010 at 5:42 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I was running 885's and rear tsb. Sat just about level. You can fit 33's. But if you dont raise the rear and you get 33's, when your flexing hard offroad, the rear tires will rub you inner fender.
  11. Jan 15, 2010 at 5:44 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I thought you needed 885 + the top spacer for 3".:notsure:
  12. Jan 15, 2010 at 5:47 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Most cases yes.
    That spacer is only 1/4" thick and gives 1/2" of lift. So the minimum amount of lift you should get is 2.5".
