OME, Bilstein 5100 285/70/17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MastaN8, Mar 2, 2017.
  1. Mar 2, 2017 at 1:41 PM
    MastaN8
    MastaN8 [OP] Member
    2011 Tacoma 4WD TRD Auto
    Hey, sorry if a million posts exist of this already (have been researching for some time) but I am looking for a bit of advice. I found a local dealership that will do the OME or Bilstein 5100 3" lift kit installed for 2k which includes an AAL or they can do Dakar leafs for an extra $700 ( I live in Canada). I asked about UCA as there seems to be a lot of discussion on here about them and they advised I wouldn't need them as long as I am not off-roading all the time, they did however say a LCA seizure is common and that may need to be done. I would like to get new tires as well and was thinking somewhere in the range of 285/70/17-265/70/17.
    Just looking for opinions as to if I will need an UCA for these tire sizes and just general opinions of which options people liked the most.
    Thanks!
    DavesTaco68 likes this.
  2. Mar 2, 2017 at 1:50 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I just did 5100s with Eibach coils (112-620), you get 1.6 inchs of lift, and Icon AAL and my tires 265 70 17 rub just a bit on my mudflaps. If I had aftermarket UCAs they could adjust them to allow for more caster and my tires wouldn't rub then. My caster is 1.8 at the moment and if you can get closer to 3 that helps a lot avoiding rubbing. The rims I have are -10 offset, 4.3 for backspacing.
    MastaN8[OP] likes this.
  3. Mar 2, 2017 at 1:58 PM
    la0d0g
    running for the hills
    For crawling not hauling
    What springs?
  4. Mar 2, 2017 at 2:00 PM
    la0d0g
  5. Mar 2, 2017 at 2:48 PM
    MastaN8
    MastaN8 [OP] Member
    The OME kit includes the following:
    OME 885 front coils, as well as an add a leaf for the rear suspension to go along with OME 90000 and 60091 shocks. Trim packer included with kit.
  6. Mar 2, 2017 at 3:40 PM
    la0d0g
    With 885s you'll probably want new UCAs. And to correct the shop, UCAs aren't needed for offroading, they're needed to get your alignment back in spec after lifting your truck.
  7. Mar 2, 2017 at 4:15 PM
    EricU
    EricU Well-Known Member
    Englewood, CO
    i have 5100 with 886 coils and Built Right uniball UCA's, No mud flaps. I rubbed/popped off the fender flare once offroad. Did the Cab mount chop, Trimmed the lower part of the fender flare at the bottom, Wheelers Super bumps with 3/8" spacer, and realigned to push the tires forward. now i have no clearance issues with 285/70/17s. I offroad frequently
  8. Mar 17, 2017 at 10:21 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    2K to install that lift? Ouch. Look elsewhere.
    The_Great_PNW and Jonny22r like this.
  9. Mar 17, 2017 at 10:57 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    What does the OP mean by LCA seizure? Is that the bolt to remove the shock mount from the LCA?
    Planning on doing an install soon and this caught my eye.
  10. Mar 17, 2017 at 11:03 AM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    The 2 main mount bushings typically seize that are attached to the alignment tabs, more so in the upper US region. On a 2015 you shouldn't have a problem.
    Edit: to add, I changed my 2013 suspension 4 times with no issue and once on my 2014. Either way, auto parts store sell fill stock UCA's with bushings and ball joints installed at a pretty reasonable price
    Chase8059[QUOTED] likes this.
  11. Mar 17, 2017 at 11:04 AM
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    If you are getting 3" of lift why are they going with OME 885's, those are designed to get you around 1.5" of lift depending on your truck. Sounds like they are trying to preload up the spring, which is not really a great way of doing it. But maybe I'm missing something here?
    For a full 3" I would assume you would want OME 888's, am I wrong on this?
  12. Mar 17, 2017 at 11:07 AM
    mosquitoTaco
    Anthony
    SouthTennessee
    2nd gen Tacoma 885= 2.5 inches on dcsb
    epluribusunom[QUOTED] likes this.
  13. Mar 17, 2017 at 11:08 AM
    epluribusunom
    Luke
    '16 White SR5 4x4
    Shit, didn't even realize I stumbled back over into the 2nd gen section. Sorry guys, my post is useless!
