OME Dakar leaf packs 3rd leaf remove from top or bottom?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Dec 7, 2016.
  1. Dec 7, 2016 at 8:41 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    when everyone says "3rd leaf removed" is that counting from the top or the bottom? Also is there any trick to getting it out?
    ChadsPride likes this.
  2. Dec 8, 2016 at 3:57 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I removed the 3rd from top of my Dakar leaf pack. You will have to take out the centering pin in order to remove one of the leaves, and you should use a c clamp or similar tool to squeeze the pack while you remove the pin. If not the whole pack may spring apart a bit more violently than you'd like. There is a stickied how-to on installing an Add a Leaf. Give that a look and you should be able to figure out how to get one out.
    757yotas[OP], ChadsPride and DrFunker like this.
  3. Dec 8, 2016 at 4:09 AM
    jjsul
    James
    New Hampshire
    95.5 OME
    1bad2k and ChadsPride like this.
