OME Dakar Leafs?
Discussion in 'Suspension' started by AllMountainToy, Jan 9, 2013.
  1. Jan 9, 2013 at 2:43 PM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I have ready most if not all the OME lift kit threads and I know there have been a lot of opinions about extending brake lines or not.
    If you actually have these springs on your own 2005+ Tacoma AND rock crawl with it, causing full flex...do you have extended brake lines?
    If not, have you run into problems when you have been fully flexed?
    thanks all!
  2. Jan 9, 2013 at 9:33 PM
    AllMountainToy
    Northern California
  3. Jan 10, 2013 at 5:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm running my normal lines still and I haven't broken em yet. But I would say extended lines won't hurt if you can afford them. I've got a set that I just have to find the time to put on.....
  4. Jan 10, 2013 at 5:23 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    same hear... although I think my shocks are limiting my droop as well
  5. Jan 10, 2013 at 6:05 AM
    WarDamn
    WarDamn Well-Known Member
    Davenport, IA
    07 Tacoma
    I have these. when my truck was on the lift, with full droop, the stock brake lines were stretched to the max . I would recommend adding the extended lines to be safe.. they are only like $60 from toytec.
  6. Jan 10, 2013 at 6:15 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I also have the Dakars and before I got my extended break lines put on I still had a little play in the stock lines at full droop. Only reason I put the extended ones on was because I put the AAL in there.
  7. Jan 10, 2013 at 7:40 AM
    AllMountainToy
    Northern California
    Thanks all! This was extremely helpful. Have a gret day
  8. Jan 10, 2013 at 8:21 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    I wheel the piss out of mine and have not extended lines.
  9. Jan 10, 2013 at 9:28 AM
    AllMountainToy
    Northern California
    thanks Robert!
