OME Dakar pack uneven
Discussion in '1st Gen. Tacomas (1995-2004)' started by Paulsac, Sep 9, 2017.
  1. Sep 9, 2017 at 2:53 PM
    Paulsac
    Paulsac [OP] Member
    Paul
    2003 Black Tacoma Double Cab TRD Limited
    So I just installed a 3" OME lift from Headstrong with the dakar packs. In the rear the passenger side is about 1.5" higher than the drivers. I DO have the "A" pack on the drivers and the "B" pack on the passenger. I read about that before my install. Both are "+" packs. Both have the 7 leafs. I don't see any other noticeable difference. The front seems fine. I put the coil assembly with the little shim on the drivers. Any ideas?
  2. Sep 9, 2017 at 4:05 PM
    tntacomaguy
    tntacomaguy Well-Known Member
    Smoky Mountains
    2002 Tacoma 4x4 TRD
    OME lift, 285s, ARB bumper
    I have the same issue with mine. It's not that much difference side to side but still not level. Ticks me off after paying good money for it. Hopefully someone will chime in. I've asked before and no answers yet
  3. Sep 9, 2017 at 5:29 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Not positive but I think the stock leafs are uneven due to the additional weight of the fuel cell but the after market leafs are the same so you end up higher on the passenger side.
  4. Sep 9, 2017 at 5:47 PM
    tntacomaguy
    Smoky Mountains
    2002 Tacoma 4x4 TRD
    Dakar is supposed to account for the taco lean by making their leafs side specific.
  5. Sep 9, 2017 at 5:58 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    OME doesn't make them specifically to account for Toyota lean, but they mark them (+) (0) and (-) to represent over, right on and under spec. So you're supposed to put the (+) or (0) on the driver's side and the (-) on the passenger but that's really a guaranteed thing. AFAIK it's up to the distributor or shop to mix them for you since they are sold individually by OME. You'd have to ask Headstrong to be sure about that.
    Mine leans a little even with a (+) and (-) correctly oriented and that has been true of several sets of OME I've had. Part of the lean is that your body mounts sag more on the driver's side so if there's only a little bit of lean your suspension might actually be level.
    One thing to realize is that new springs are usually really tall and will settle quite a bit at first. Although 1.5" is a lot, but mine (CS047R on a 2nd gen) settled a solid 1/2". You might try putting some heavy stuff in the bed and drive it around to get them to settle.
  6. Sep 9, 2017 at 6:15 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Do you have a spacer on the driver side front shock? If not, trust me, you're gonna want that spacer.
  7. Sep 9, 2017 at 6:18 PM
    tntacomaguy
    Smoky Mountains
    2002 Tacoma 4x4 TRD
    They told me to have weight in the bed to help the nearly 4 inches of rake I got from the springs. I realize they will settle after a while, but seems the taco would remain even after settling
  8. Sep 9, 2017 at 6:19 PM
    tntacomaguy
    Smoky Mountains
    2002 Tacoma 4x4 TRD
    I have the trim pack from headstrong
  9. Sep 9, 2017 at 6:21 PM
    Flytmech
    Jase
    Geneva Alabama
    Ah, ok then i got nothing.
  10. Sep 9, 2017 at 6:35 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Not necessarily, it's hard to predict exactly. OME supposedly measures spring rate after they manufacture them and that's where the symbols get put on but they make a fraction of the number that Toyota does and they make tons and tons of different ones for different applications so there's going to be a lot more variance with any particular set compared to OEM.
    I think having a little lean is pretty much inevitable. I've never had Deaver or All-Pro but I've had Northwest Offroad, Toyota and OME and I've never had a perfectly level truck. I adjust my packing to put more heavy stuff on the higher side and I never notice otherwise. I figure it's all good as long I don't look like a gangsta or drive in circles.
  11. Sep 10, 2017 at 10:46 AM
    Paulsac
    Paulsac [OP] Member
    Paul
    I guess I will swap the springs even though I know the "A" is supposed to be on drivers but they are both + packs.
  12. Sep 10, 2017 at 10:50 AM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Yo man that's a lot of work, relax for a second. Drive around for a couple weeks and see if it changes. Put some weight back there, take it over some speed bumps. It's not going to sit exactly level no matter what you do.
  13. Sep 11, 2017 at 12:09 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I'd either return them for another pack or flip them (Both I bet are a pain). But i've rebuilt springs so many times it takes me 45-60 minutes per side..
    I've had two Dakar packs on two separate trucks. They settle after a bit, but 1-1/2 is pretty bad, and reflecting back on older posts with similar Dakar lean that the two sides needed to be flipped.
    Both packs I have experience with were 1/4" to 3/8" higher on the LH side w/o me in the drivers-side front seat...
    Idk man. That's all I got.
  14. Sep 14, 2017 at 9:43 AM
    Paulsac
    Paulsac [OP] Member
    Paul
    After hitting some speed bumps and driving around I rechecked on a flat garage floor. Either it settled a little or the ground before wasnt even enough. I am now a little more than 3/4" higher in the passenger rear but also the drivers front is about 1/4" lower so that may be affecting it too. I am just going to drive for a little while and let everything settle and then make some real thin shims for the front and back to level things off. I bet a 1/8" or thinner front shim and a 1/4" rear shim should level things much better. Just need to bust out the plasma.
  15. Sep 14, 2017 at 10:16 AM
    Catzilla
    Catzilla Well-Known Member
    Adk's
    2010 trd sport
    I have two +'s and two a's. did everyone get an "a" and a "b" ?
  16. Jan 4, 2018 at 6:01 PM
    solarservant
    solarservant Beersquatch
    Zach
    Tucson, AZ
    ICON equipped MGM 2Gen
    ICON Stage 3, Dakar Heavy Pack, CBI Bumpers, RCI skids, Avid sliders, on 33" ST Maxx
    Just got my Dakars installed today, and yup... 1-1/2" higher on the passenger side. I have 2 (+)'s. Have to check tomorrow and make sure there's an A and a B. Damn it!
  17. Jan 16, 2018 at 12:05 PM
    Danjor2
    Danjor2 Well-Known Member
    Daniel
    Riverside
    01 Limited Double Cab Prerunner
    Mine still leans many years later, I just decided to get used to the taco lean
    cruxofthebisquit likes this.
  18. Jan 16, 2018 at 12:49 PM
    solarservant
    Zach
    Tucson, AZ
    Flipped the packs... now the difference is +.75" on the passenger side. That, I can live with. Just loading the truck a little more on that side for extended trips.
    lukester78 likes this.
  19. Jan 16, 2018 at 6:02 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Something to try...measure the front fender clearance on flat ground, lift the rear by the differential just enough for the tires to be off the ground, re-measure the front fender clearance. This will tell you if the front springs are having any effect on body lean.
    solarservant likes this.
