OME Dakars 3rd leaf removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoflaco, Jan 30, 2014.
  1. Jan 30, 2014 at 2:52 PM
    tacoflaco
    tacoflaco [OP] Well-Known Member
    Sean
    Bay Area, CA
    2013 ACLB Baja
    SnugTop SuperSport SpiderTrax 1.25" Spacers BAMF Sliders OEM smoked headlamps Pro Grille Paint matched grille surround Tepui RTT
    Just wondering if any members out there have pulled the 3rd leaf out of your OMEs. If so, can you share your hub to fender measurements and thoughts/opinions about ride quality with the 3rd leaf removed.
    I put my lift in about 1,000 miles ago and am getting a little more lift out back than I'd like. I was hoping it would "settle in" but I'm thinking at this point, it has settled as much as it is going to.
    Thanks!
  2. Jan 30, 2014 at 3:00 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    deja vu
  3. Jan 30, 2014 at 3:23 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
    LOL...you had the same issue?
  4. Jan 30, 2014 at 3:33 PM
    OZ-T
    Peter North
    British Columbia
  5. Jan 30, 2014 at 3:36 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
  6. Jan 30, 2014 at 5:39 PM
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    I would take out the 2nd overload spring (with good bump-stops) before I take out a loaded spring. removing a load leaf will put more 'stress' on the rest of the leafs in the pack and less load capacity... up to you...
  7. Jan 30, 2014 at 5:45 PM
    OZ-T
    Peter North
    British Columbia
    The OME / ARB literature says removing the 3rd is fine although it does reduce right height and capacity as you stated
  8. Jan 30, 2014 at 6:10 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
    Ok, so here's a potentially stupid question...how do I tell which leaf is a loaded leaf and which is an overload leaf?
    I will most likely just leave it "as is" because the rake from back to front isn't horrible and I'd rather have rake from back to front than rake from front to back. (is this what is known as "bro-lean?" :confused:)
  9. Jan 30, 2014 at 6:12 PM
    OZ-T
    Peter North
    British Columbia
    You can't mistake them , Dakars have 2 overload leafs at the bottom of the pack , they are noticeably thicker and shorter than all the rest
  10. Jan 30, 2014 at 6:15 PM
    tacoflaco
    Sean
    Bay Area, CA
    2013 ACLB Baja
    Ah, thanks much. You are correct, they are certainly unmistakeable. My Tacoma is the first vehicle I've ever owned with leaf springs....new territory for me and I'm a total noob. (obviously)
