OME Front Suspension "Slams" on Extension
Discussion in 'Suspension' started by ExpeditionArctic, Sep 16, 2013.
  1. Sep 18, 2013 at 6:21 PM
    ExpeditionArctic
    ExpeditionArctic [OP] Member
    Vincent
    Penn Valley, CA
    2010 SR5 DBSB 4x4 TRD OR
    ARB Front bumper with winch, undercarriage armor. 3" OME front suspension lift and custom Deaver rear leaf springs w/ 3" inch lift. BajaRack Utility rack and Softopper bed shell.
    do you have your sway bars relocated? Mine are in the stock position. I'm not quite following how your sway bars keeps your shocks from topping out.
  2. Sep 18, 2013 at 6:48 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
  3. Sep 18, 2013 at 7:25 PM
    younglexx
    younglexx Well-Known Member
    Alex
    Bay Area, CA
    4x4 DC TRD Off Road
    stock loacation. it has less travel with the sway bar on, I used to run no sway bar and had more wheel travel
  4. Sep 19, 2013 at 2:50 PM
    ExpeditionArctic
    Vincent
    Penn Valley, CA
  5. Sep 19, 2013 at 7:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine only does it on speed bumps or if I drop into a pothole I didn't see , and curiously I think it's only on the passenger side
  6. Sep 19, 2013 at 7:57 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Mine does the same thing.
    It's the shock.
    You put heavier springs on to carry the weight of your bumper and winch.
    The shock is supposed to dampen both the compression and rebound of the springs but the rebound damping is inadequate for the springs.
    I know this is how things work on a motorcycle.... I'm guessing it's the same on our trucks.
    I suppose it's possible that our shocks do not dampen rebound but only compression. That would really explain it.
  7. Nov 24, 2013 at 12:36 AM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    Just curious, what is the distance between your bump stops in the front?
    Your frame could be bottoming out on the bump stop if the gap is not big enough. If that is the problem, you will need to swap out with a low-profile bump stop or add more preload to increase the distance between the bump stop and frame.
  8. Nov 24, 2013 at 1:04 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    If an 8" travel shock has 4" up and 4" down and you're taking away 3" of down travel due to lift.......1" of down travel makes for a crappy ride.
    It's like a word problem from math class LOL
    Best thing to do is not drive the truck too hard as 1" pot holes and the like are overextending them. Orrrrrr upgrade to ext travel coilovers and UCA's? Another reason why I'm not a fan of preload for the sake of lift/tires. Smallest lift possible with as much travel as possible is best!
  9. Dec 3, 2013 at 1:34 PM
    shibubba
    shibubba Well-Known Member
    Calgary Alberta
    2013 DCSB 6spd. Lotsa stuff.
    Kings Dakars 285/75r16 duratracs CBI rear bumper blah blah
    Mine do the exact same thing. It drives me nuts. I have 7000kms on the suspension now, so I dont think it is going to get any better. I understand that it is a stock length strut with extended length coils...but come on.
    My question is, do ICON, FOX, KING etc do the same thing. Because I am honestly ready to ditch the ome stuff for coilovers if it fixes this noise. I am leaning heavily towards KING extended travel coilovers.
  10. Dec 4, 2013 at 3:41 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    My fox extended travel COs only go clang when I drive too fast over bumps or try to jump the truck :eek: And thats just the bumpstops. Installing sSuperbumps made it better :D
  11. Dec 4, 2013 at 8:54 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    I picked up the Icon Extended Coilovers for $1,200 from Down South Motor Sports here on taco world, great deal! They are easy to deal with and great quality product. I love these coilovers they ride like a dream in most situations :)
  12. Dec 4, 2013 at 9:02 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    No they don't do that.
  13. Dec 15, 2013 at 4:49 PM
    shibubba
    Calgary Alberta
    Good.....
  14. Jan 22, 2014 at 6:08 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Sucks this is happening. I sent an email to ARB asking about the issue, their final word on it is below. The number they are referencing is the downtravel. I don't have the minimum of 2.5".
    Stepping down to a 885 coil spring might fix the issue, but with sway bars removed and the added weight on the front end they aren't stiff enough to maintain that ride I like; especially when cornering.
  15. Jan 27, 2014 at 6:03 PM
    #35
    rruhl48
    rruhl48 Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    You check lower control arm skid plate. I kno alot of the lifts come with plate spacers for that reason
  16. Feb 15, 2014 at 5:22 PM
    #36
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    No clue what you're taking about
  17. Feb 19, 2014 at 7:33 PM
    #37
    Okeetee
    Okeetee I like the Anaheim Ducks
    Kyle
    Huntington Beach, CA
    '11 MGM TRD Sport DCSB 4x4
    OME 887 coil springs, Bilstein 5100s (front/rear), Light Racing UCAs, Wheeler's HD 1.5" AAL, 18x9 Pro Comp series 7032, Toyo Open Country A/T II (LT285/65R18)
    Sorry to hijack the thread, but it seemed the most fitting to the issue I encountered tonight.
    I just got my truck back from the shop with brand new OME 887 coils, Light Racing UCAs and Wheeler's HD 1.5" AAL installed with my current setup of Bilstein 5100s (front/rear) and 265/75/16 Duratracs.
    The problem is, I forgot to tell the guy to reset my front Billies to 0 (boneheaded move on my part), so they're still at 1.75" WITH my 887 coils. Oops.
    Ride seemed okay until I went over a speed bump and felt a big CLUNK in the front suspension. Then I went over another speed bump slow and felt it again, but not to the extent of the first time.
    I'm taking it back to shop on Friday morning, but is it safe to drive tomorrow? I'm hoping nothing got damaged.
  18. Feb 19, 2014 at 7:34 PM
    #38
    OZ-T
    Peter North
    British Columbia
    They managed to align it like that ?
  19. Feb 19, 2014 at 7:39 PM
    #39
    Okeetee
    Kyle
    Yeah they did! I was surprised. The more I read this thread the more I wonder ... will setting it to 0 get rid of this issue? I'm hoping it does.
  20. Feb 19, 2014 at 7:42 PM
    #40
    OZ-T
    Peter North
    British Columbia
    Don't you have like 5" of lift ?
