OME Full Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nsane1, Mar 19, 2016.
  1. Mar 22, 2016 at 6:56 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    885's and top plate spacer AND 887's will still net you 3" no matter what. I have the 885's and spacer
    ChadsPride likes this.
  2. Mar 29, 2016 at 7:52 AM
    Nsane1
    Nsane1 [OP] Active Member
    I would rather stay away from spacers.
  3. Mar 29, 2016 at 11:15 AM
    Monster1088
    Monster1088 Active Member
    Arizona
    2019 DCSB OR Tacoma
    It comes down to your preference. I went with 887s because why should I spend the money to add on a spacer to achieve the same thing?
  4. Mar 29, 2016 at 11:18 AM
    Monster1088
    Arizona
    2019 DCSB OR Tacoma
  5. Mar 30, 2016 at 5:57 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Would you say the ride quality between the 885s w/ a spacer (¼") and the 887s are about the same. Assuming they're both on 5100s?
  6. Mar 30, 2016 at 6:07 AM
    geekhouse23
    Exactly the same. Zero difference.
  7. Mar 30, 2016 at 6:10 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    oh then absolutely i would go with the 887s. thanks man!
  8. Mar 30, 2016 at 5:49 PM
    Nsane1
    OK, so I called Wheelers. Very helpful guys, told them I was looking at the 887 v 885's. They said there is only a half inch difference and said the 887's are on national back order. So I guess I'll be going with the 885's and if I end up having to I can easily install a top hat spacer if I absolutely have to.
  9. Apr 4, 2016 at 7:12 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    How do the 2885 coils compare to the 885/887?
  10. Apr 5, 2016 at 7:34 AM
    Nsane1
    They're the same spring rate the 887 is just a little taller.
    BraskaTaco likes this.
