OME Lift + 265/70/17 Question....???
Discussion in 'Suspension' started by Eesh, Nov 9, 2010.
  1. Nov 9, 2010 at 1:07 PM
    Eesh
    Eesh [OP] Well-Known Member
    Regina, Sask., Canada
    trd Sport
    Hey guys I know if I use the search I can find out about this but I'd like some advice specific to my needs.
    I have a full OME lift set up (885's, front and rear shocks, and Dakars) that I have yet to install I realize I'm going to have to use either spacers or get new rims. My question is do I need to get aftermarket UCA's if I stick with a 265 sized tire????
  2. Nov 9, 2010 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you want the alignment right, then yes.
  3. Nov 9, 2010 at 1:13 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2
  4. Nov 9, 2010 at 1:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm not so sure.
    OME 885 on a double cab, after it's had a month or so to break in, may only lift your front about 2" - in which case you'll still be able to align the front.
    My 885s whacked my alignment - but I've got a std cab 4 banger 5 speed - it's a lightweight truck.
  5. Nov 9, 2010 at 2:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 885's gave my double cab right at 3" lift....Same with PackerfanXD.
  6. Nov 9, 2010 at 7:45 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Ah. Well then. Munch. Munch. Munch. (Bullwinkle J. Moose cheerfully eats his words...) :D
  7. Nov 9, 2010 at 8:05 PM
    fsbrain03
    fsbrain03 Well-Known Member
    Do you even need that much of a lift for those tires? They aren't too big to put on your truck, stock. Mine came with that size, and I am pretty sure you can still get them stock with that size tire. Why would you need to replace anything with that tire setup? Unless you just wanted to, which is enough reason...
  8. Nov 9, 2010 at 8:12 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    3" in your prerunner , how much do you think it will lift a DC 4x4 ?
  9. Nov 9, 2010 at 8:14 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    pretty sure its the same man...
  10. Nov 9, 2010 at 8:15 PM
    OZ-T
    Peter North
    British Columbia
    No front diff makes no diff ?
  11. Nov 9, 2010 at 8:17 PM
    ColtsTRD
    Scott
    AZ
    Its the same chasis so I would assume some...not 100% though
  12. Nov 9, 2010 at 8:18 PM
    ColtsTRD
    Scott
    AZ
    Like a 4x4 double cab and a trd prerunner double cab should yield the same amount of lift...
  13. Nov 9, 2010 at 8:20 PM
    OZ-T
    Peter North
    British Columbia
    I always thought the extra weight of the front diff on a 4x4 would reduce the amount of lift you would see over a prerunner with the same lift .
  14. Nov 9, 2010 at 8:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    At least 2.5" I would guess. How much more weight is on the front of the 4x4 than the prerunner? Maybe 150#?
  15. Nov 9, 2010 at 8:29 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    nah, it's the doublecab that lowers your lift. i've got a full 3in lift but the same coils on a single cab would give a higher lift.
    anyways..you don't need spacers..just sayin
  16. Nov 9, 2010 at 8:31 PM
    OZ-T
    Peter North
    British Columbia
    That would probably be about right . Much the same as an aftermarket steel bumper .
  17. Nov 9, 2010 at 8:31 PM
    Thomas Lee
    Thomas Lee Shogun
    work truck
    3" lift
    Man if you have the money, Get rims and 33s. I just put 31s on my truck with a 3" lift and am discusted with it. My son is lucky I care bout him cuz if i didnt I would of done exactly what I just told you to do. But its either him or the truck. The wife dont even matter.
    Having said that Ive done my reasearch and no, you just have to put the tires on
    After 265 you have to start doing extras, such as regearing and cutting your front bumper and taking off your mud flaps
    With 265s you dont have to get spacers or rims
