OME Lift-Height Statistics (Center-Hub to Fender)
Discussion in 'Suspension' started by Garftore, May 18, 2012.
  1. May 18, 2012 at 1:25 PM
    Garftore
    Garftore [OP] Well-Known Member
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    OME 9000s/ TrimPacker/ 886s/ N182s/ Dakars+AALs+Shims, LR UCAs, BakFlip F1 Bed Cover, AMP MotoXtender, FrontBed OEM Tiedowns, PopLock RearCam Tailgate Latch, RFab Steel Bumpers (Front-Full BrushGuard + mounted Warn x8500i, Rear-OEM style) & Welded Kickout Rails, 16" TRD Wheels, 1.25" SpiderTrax, 285/75 Toyo MTs, Chopped Body Mounts.
    884/5/6s: Passenger Height / Driver Height (TrimPack / no TrimPack)
    Spacers: Yes/No (spacer height)
    Model: DCSB/DCLB/AC/RC
    aftrMrkt: Product/Weight
    Coil Age: Months installed / Mileage
    Dakars: Passenger Height / Driver Height (AALs / no AALs)
    Spacers: Yes/No (block height)
    If anyone's wondering how their OME suspension's holding up, I think this thread would be a good way to compare our setups. Just copy and paste the above info and make adjustments. I feel like mine have sagged a little, but I forgot to take measurements before & after installation.
    I will have approx. 185 lbs of aftermarket equip in the front and 85 lbs in the back very soon, but my measurements as of now are as follows:
    886s: P-23.5" / D-23.25" w/ TrimPak
    Spacers: No
    Model: DCSB
    aftrMrkt: ~165lbs (R-Fab Bumper/Warn x8000i)
    Coil Age: 8 Months / 9,000 mi
    Dakars: P-25.5" / D-25.25" w/ AALs
    Spacers: No
    aftrMrkt: 85lbs (R-Fab Bumper, but minus weight of OEM bumper and Tow Package)
    Coil Age: 8 Months / 9,000 mi (AALs brand new)
  2. May 18, 2012 at 2:56 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  3. May 18, 2012 at 3:03 PM
    TotalBrutal
    TotalBrutal Well-Known Member
    Dan
    Vancouver Island, BC
    2007 V6 4X4
    Front 5100s @ 0, OME 844s, Rear 5100s, AFE pro dry filter
    884s: P-21.75" / D-21.75" - no trim pack
    Spacers: No
    Model: Access cab V6 4x4 6spd
    aftrMrkt: OEM
    Coil Age: 2 Months / 20,000km
    Stock (Canadian 4 leaf): P-23" / D-22.75"
    Spacers: No
    aftrMrkt: OEM
    Coil Age: 5 years / 145,000km
    I love my OME coils, perfect height i was looking for to level out. Seem to be holding up well even after lots of abuse. No noticeable sag
  4. May 18, 2012 at 3:53 PM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
  5. May 18, 2012 at 5:31 PM
    OZ-T
    Peter North
    British Columbia
    That thread is Dakar specific
  6. May 21, 2012 at 12:01 PM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    well I took more accurate measurements and added some leafs, and edited the OP. I guess nobody cares about the height of their front OME suspension.
  7. May 21, 2012 at 12:03 PM
    OZ-T
    Peter North
    British Columbia
    The reason I made the other thread Dakar specific is because lots of guys use other lift components for the front , other than OME
  8. May 22, 2012 at 11:13 AM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    i wanna know how much my coils have sagged, and see how everyone else is running at compared to how high they sit off the ground (OME or any other brand). I want to put 15mm spacers over my 886s, but i keep getting mixed suggestions over it. will they add stress to the LCAs at full extension? it's half of an inch!
  9. May 22, 2012 at 11:37 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Are the spacers 1/2"? You will get twice the thickness of the spacer in lift.
    So 1/4" spacers give 1/2" lift & 1/2" spacers give 1" lift.
  10. May 22, 2012 at 11:43 AM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    Well then i really need to know some specs...i didn't measure my truck correctly when i first lifted it, but it seemed about an inch higher, and rode just fine. If i can get some stats at what people are sitting at compared to their ride performance, then it'll give me a better idea of which spacer to get.
  11. May 22, 2012 at 12:05 PM
    OZ-T
    Peter North
    British Columbia
    You shouldn't use spacers with 886's
    The new OME " x " coils are not supposed to sag , my 885x coils haven't sagged at all in over a year
  12. May 22, 2012 at 12:11 PM
    4Wheelin4Banger
    Randy
    I think you've grown.
    '11 AC 4x4 5 speed 4Banger
    I can't get to the passenger side when it's in the garage but mine is still at 3" front & rear.
    885Xs: D-23.25" w/ TrimPak
    Spacers: No
    Model: AC
    aftrMrkt: none
    Coil Age: 18 Months (10 me & 8 previous owner) / 10,000 miles me & ? previous owner
    Dakars: D-24.25"
    Spacers: No
    aftrMrkt: ?lbs SnugTop Hi-Liner Shell
    Leaf Age: 18 Months (10 me & 8 previous owner) / 10,000 miles me & ? previous owner
  13. May 22, 2012 at 1:30 PM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    OZ-T, please give me some detailed technical speculations on why I shouldn't run them with 886s...i'm always told i can or can't, but with no explanation except for "down-travel issues" or cuz the toytec MFR said "no." how would it mess up the performance? will this put too much pressure on the LCAs during down travel? will there not be enough for up travel in the OME 9000 shocks or something...i know a little, but not enough to understand how bad this will effect my truck's performance. maybe if i drove slower when I off-road, that would compensate for the added stress? I also ask about everyone's lift heights, because i want to know how people perform on a level service with a 24 in hub-fender lift. i wanna know if their CV angles cause vibrations.
    One more question...anyone know the stock height in the front (hub-fender) without TRD suspension?
  14. May 22, 2012 at 1:38 PM
    OZ-T
    Peter North
    British Columbia
    Going over 3" up front with a 4x4 is bad for the CV angles , the 886's should get you 3" on their own
    Even a 1/4" top plate spacer will net you 1/2" of lift , the 3/8 or 10 mm ones will get you 3/4"
    24" hub to fender up front is 3 - 3 1/2" of lift over stock
  15. May 24, 2012 at 11:48 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2015 DCSB TRD OR 4x4
    5100's front & rear , Eibach springs, LR uca,Icon progressive aal
    sam sounds like ypou have same questions as me i m having aliitle rub issue w/my flares when im turnd alittle & i need them for PA laws so im keeping flares & trying to figure out how to get like an 1.5-2 more inches up front back is no problem
  16. May 24, 2012 at 7:20 PM
    Garftore
    Sam
    Oahu, Hawaii
    '11 T|X, BLACK
    Alright, problem solved. i got the 10mm spacers, gonna re-drop my front diff (r-fab's skid plates can fit a drop-diff), already have the center d-shaft dropped, and got axel shims, cuz of the AALs i added to the dakars. this should keep the same CV angles and eliminate vibes n shit
    I dunno, PA...you have a different lift than mine. how much lift do you have, not including the lift given from the drop bracket? everyone says you can't go over 3", and body lifts are iffy.
  17. May 24, 2012 at 8:16 PM
    OZ-T
    Peter North
    British Columbia
    I'm lost , how did you solve the problem ?
    Oh and diff drops do nothing on 2nd Gens
  18. May 24, 2012 at 8:36 PM
    pa blaster
    Scott
    central pa
    :confused:
  19. May 24, 2012 at 8:36 PM
    OZ-T
    Peter North
    British Columbia
    :confused:
  20. May 24, 2012 at 8:47 PM
    pa blaster
    Scott
    central pa
    diff drops do nothing on 2nd gen what do you mean ?
