OME Lift Install Tomorrow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Gata, Mar 15, 2013.
  1. Mar 15, 2013 at 4:33 AM
    The Gata
    The Gata [OP] Active Member
    J
    New B, MA
    10 Dbl Cab trd
    Debadged,Leather interior, BFD's w/ Dura Tracs, 3 inch OME w/ 885's and Dakars
    OK guys tomorrow is the big day, after about a year of reading post after post im finally ready to install OME 3 inch lift. 885's with spacers pre assembled, dakars with bushing pre-installed, axle shims, already installed collar pins.... i got a set of LR uca's plan on cutting the long bolt out and installing new from the back. I know i must preload suspension before torquing everything, what did you guys do, put wheels on and set down onto the ground then torque? Do you guys have any advice or tips for me, I mean anything you guys think of would help.
  2. Mar 15, 2013 at 5:27 AM
    Large
    Large Red
    Torque everything except the long UCA bolt, put the truck in its own weight then torque the long UCA bolts on both sides. Getting a torque wrench in there is fun, my 3/8 didn't meet the torque specs so I had to use my 1/2" drive and it was a pita.
  3. Mar 15, 2013 at 5:29 AM
    Large
    Large Red
    And put about 85 ft lbs on the rear u-bolts, I think factory claims 37 which is stupid. Drive for a week & retorque everything again
  4. Mar 15, 2013 at 5:32 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    also dont forget to torque the rear springs(shackles and front hanger) after it is set on the ground as well..... not when it is off the ground.
  5. Mar 15, 2013 at 5:38 AM
    Large
    Large Red
    :facepalm: forgot about that.
  6. Mar 15, 2013 at 5:53 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    When I did mine it was easy to cut the long bolt and put the new one in reverse direction on the passenger side. On the driver side there isn't enough room to remove or install the bolt from the other direction. I had to bend the inner fender to remove and install the bolt. Not sure if they're all like that but mine sure was.
  7. Mar 15, 2013 at 6:48 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    They're all like that. Hell, Toyota's directions for replacing the UCA's states to bend the inner fender to get those bolts out.
  8. Mar 15, 2013 at 6:57 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Did you guys torque down the lower bolt on the coilivers before lowering to the ground, it is a pivot point? For the guys who put both Uca's and coilivers did you have enough room to install the coilivers by just separating the top ball joint or did you have to remove sway bar or lower ball joint.....
  9. Mar 15, 2013 at 7:00 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Remove the sway bar, use an allen key and an open end wrench for the end links. Then take the skid plate off and loosen or remove the mounting bolts and swing it out of the way conpletely. If you do UCAs then you dont need to mess with the LCA or tie rods. I used a spring compressor and tightened the top bolt before installing. Are you using the no spring compressor method?
    Edit: nevermind about the no spring compressor, i see you bought the coilovers pre assembled.
  10. Mar 15, 2013 at 7:02 AM
    evanmb31
    evan
    connecticut
    09 trd off road
  11. Mar 15, 2013 at 7:09 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Spring compressor method? My coilivers are already assembly, had toy tech do it
  12. Mar 15, 2013 at 7:10 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Ya just saw that and edited my post. Good choice having them pre assembled, its worth the money because it is a PITA
  13. Mar 15, 2013 at 7:14 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Yeah def worth it, ok so I'll disconnect the sway bar first, break the upper ball joint, secure spindle, cut off uca bolts and remove uca, install coiliver then uca, sound about right? Easier said than done I'm sure
  14. Mar 15, 2013 at 8:00 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Sounds right to me! Good luck! I did the same install a few months ago, wasnt very hard at all. If you have any questions during the process, post and im sure you will get a quick answer, i did that a few times when i installed mine.
  15. Mar 15, 2013 at 8:11 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    What's your estimate on time for this install, both front and back
  16. Mar 15, 2013 at 8:21 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    It took me 3 days but i worked on it after work, so probably around 10 hours but i also had to assemble to shocks and coils, plus it was my first time doing suspension work so it went slow. Someone who has done it before could probably do it in 4 hours. You should be able to tackle it in a day no problem. Dakars are a little tricky by yourself.
  17. Mar 15, 2013 at 8:55 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Cool, I've never done one but I've worked on quads and dirtbikes, so I think I'll be ok, hopefully I can get a friend or two to give me a hand
  18. Mar 15, 2013 at 10:19 AM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
  19. Mar 15, 2013 at 1:06 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    If i wasnt working tomorrow i would come lend a hand. What other info are you looking for? Just tips an pointers?
  20. Mar 15, 2013 at 1:20 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    This is how I got my drivers side bolt out.
