OME Lift Install Tomorrow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Gata, Mar 15, 2013.
  1. Mar 15, 2013 at 1:23 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    I did it by myself and it took about 4 hours. its a really straight forward install. Shouldnt be too many surprises.
  2. Mar 15, 2013 at 1:29 PM
    medic2230
    Murph
    Bama! Roll Tide
    I just bent the fender, removed the battery and pulled the UCA bolts out. Put them right back in with the LR UCA's and it wasn't bad at all. Read the install threads on here and take your time and don't be in a rush. Mine was about 10-11 hours with a friend helping and neither of us had installed a lift before.
  3. Mar 15, 2013 at 1:41 PM
    The Gata
    The Gata [OP] Active Member
    J
    New B, MA
    10 Dbl Cab trd
    Debadged,Leather interior, BFD's w/ Dura Tracs, 3 inch OME w/ 885's and Dakars
    Yeah I think u have a pretty good grasp on what to do just looking for anything you guys may have came across that would make life easier
  4. Mar 15, 2013 at 1:42 PM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
  5. Mar 15, 2013 at 1:49 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    An extra set of hands would be nice for doing the UCAs, its tricky getting the inner washers in. One side they slid right in, one side i had to pry the actual UCA apart to squeeze the washer in, at the same time feed the bolt thru, so you can see how it can be hard to do it yourself. A small prying tool will help you manuever the bottom eyes of the shocks into position to get the bolts in.
  6. Mar 15, 2013 at 2:18 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    bullaculla, I tried that way, removing those nuts and others and couldn't get those lines to move enough. I also thought I wouldn't have enough room even with them gone so I gave up and bent the fender.
    Someone mentioned The UCA was easy on one side and difficult on the other. My driver UCA slid right on but I had to use a wedge to spread the passenger side to get the inner washers on. I had synthetic shims for installing doors and windows that worked perfectly.
    It took me 8 hours to do the front by myself. I also removed and greased the alignment cams while I had everything apart.
  7. Mar 15, 2013 at 2:38 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I did mine myself without cutting or bending anything (except the bolt head) And just one month after back fusion surgery. No problems with the washers or UCA being too tight. I guess everybody's trucks really are different.
  8. Mar 15, 2013 at 2:43 PM
    medic2230
    Murph
    Bama! Roll Tide
    Make sure you have a 1-1/4" socket for the UCA and torque to 150 ft lbs.
  9. Mar 15, 2013 at 3:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    * 32mm
  10. Mar 15, 2013 at 3:23 PM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    32mm for top ball joint nut on the LR's correct? 150lbs is serious , you guys rock
  11. Mar 15, 2013 at 4:29 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    See step 16
  12. Mar 15, 2013 at 5:14 PM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Is coil direction an issue if toy tech put the coil overs together
  13. Mar 15, 2013 at 5:55 PM
    splitbolt
    NW Arkansas
    Yes and no.
    Toytec should have oriented the spring/shock combo itself, correctly.
    It's up to you to figure out which one is the driver side and which is passenger side. Look at your truck's strut top plate (3)bolt orientation and the coil perches in Step 16; you'll figure it out.
  14. Mar 15, 2013 at 6:12 PM
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    They are labeled, plus one has the trim spacer for the "taco lean", do the three studs only fit in one way or can you rotate them
  15. Mar 15, 2013 at 6:59 PM
    #35
    evanmb31
    evan
    connecticut
    09 trd off road
    They only fit in one way if the coilover is already assembled. If you assemble them yourself it is possible to put them in backwards.
  16. Mar 15, 2013 at 7:06 PM
    #36
    Large
    Large Red
    Took me 9 hours to do UCAs, front coilovers, rear AAL and rear shocks. I also had to assemble by coils on site. GL, have any questions there are plenty of helpful and knowledgeable people here.
  17. Mar 15, 2013 at 7:13 PM
    #37
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    Sounds good, thanks to all who chimned in here, this forum Is an unbelievable resource, I'll be hard at work tommorow, if I have any questions I'll post them. Keep you guys posted! Sweep the leg
  18. Mar 15, 2013 at 7:16 PM
    #38
    evanmb31
    evan
    connecticut
    09 trd off road
    Take pictures!
  19. Mar 17, 2013 at 8:44 AM
    #39
    The Gata
    J
    New B, MA
    10 Dbl Cab trd
    DONE!!!!!! wasnt as bad as i thought although time consuming took me about 7 hours.... again thanks to everyone who took the time to post and chime in
  20. Mar 17, 2013 at 9:06 AM
    #40
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
