ome lift low on the front end?
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaBug, Jun 22, 2012.
  1. Jun 22, 2012 at 8:17 AM
    YotaBug
    YotaBug [OP] New Member
    Littleton, CO
    02 Tacoma 3.4 TRD
    Hi,
    So I put in a ome suspension lift kit with the 2880 coil springs. It raised my rear 3", now the front only 1.75". Parts rep said it would come close to leveling the truck, but ya not so much. The rep pushed me to get into the 2880 because I don't have a winch or bumper and I would have a softer ride. Now having read spring specs the 2881 free height is 10mm taller than the 2880. All the to say what is the spring solution to leveling the truck with out having a ride that feels like i welded the axle to the frame? I little stiff or rough is fine.
  2. Jun 22, 2012 at 10:01 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    You'll be better with the 881s for sure. Is your truck a single/extra or double cab? If it's a double cab you might even consider the 882s. I have the 882 on my dc and rant it without a bumper/winch for almost a year and it was fine and was closer to the advertised 2.5" of lift. I also have a 10mm trim packer so I've very close to 3" up front but i have a tube bumper now.
    880s are going to be too short. Who did you order from? Personally I think the sales rep misguided you.
  3. Jun 22, 2012 at 11:16 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    X2
  4. Jul 17, 2012 at 11:11 AM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    Not sure if you got this straightened out already but just FYI, I put 881's with 10mm Jk spacer on mine and got 2 3/8" drivers side and 2 1/4" passenger side. It measures 38" from ground to bottom of fender with 265/70-16. Not sure why it's backwards from the common driver side lean but it is. Hope this helps.
  5. Jul 17, 2012 at 12:06 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    This is why I went with Kings. Because all applications differ and some people got theirs to level but some required 10mm spacer and some has trim packer and this and that. I got a headache deciding to get OME or not cause I like my truck to sit leveled. 881 with 10mm and trim pack should get you close to leveled to the OME Dakars IMO.
