OME lift questions!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmartin284, Oct 10, 2017.
  1. Oct 10, 2017 at 6:09 AM
    gmartin284
    gmartin284 [OP] Well-Known Member
    Gage
    2008 Tacoma 4x4 double cab
    I currently am running 5100s with oem coils set at 2.5" and hate the ride. so Ive decided to swap out the oem coils for some OME 885s and set the 5100s back at 0" and see where that gets me. My question is do I need to do the carrier bearing drop kit for this lift? and what about the diff drop??
    scottalot likes this.
  2. Oct 10, 2017 at 6:11 AM
    scottalot
    scottalot Meow
    Stockalot
    SC
    1984 Phemail
    Bone stock like Chicken in the Crock Pot .Dakkars,305/70/16 MT's, Extended length Fox Coilovers, Fox RR rear Shocks, Total Chaos UCA's, Dakar Leaf packs, LED Map and Dome, Breather relocate, Slimer from Ghost-busters starut up screen, Vent Visors, LED Pod's on Ditch Brackets soon, Level 8 Strike 6 Wheels, New MT Tars - Fierce Attitude, SOS front bumper -steel, SOS bed rack, LED white marker lights, LED reverse, TRD exhaust, Wheelers Super Bumps up front, SOS sliders bolt on with fill plates, Csjummper2003 White/Amber DTRL and white parking led bulbs, RTT rack basket Sold 2013, sold 2014 Tacoma. All listed stuff was on the '14 Bed Mat, WeatherTech Rain Guards, Ultra Gauge, TW Sticker amongst others, Useless Free OEM Bug Deflector, Flyzeye, OME Kit with 885's and Dakar and Nitro Shocks front and Rear . Tailgate mod, SOS Concepts 1/4" Skid Plate, White LED's interior Dome and Maps, Goodyear Wrangler MTR Kevlar 275/70/17, Wet Okole Seat Covers - full piping in Charcoal Grey, Lamin-X Green Fog light film, 17"x8 -10 offset Level 8 MK6 wheels in Gun Metal Finish, SOS Concepts Sliders W/ Kickout 12/21/14, Stubby antenna, LED reverse lights, lift removed 2/20/15 - making changes and trying to make up my mind
    CB drop is dependent on the vibes and I wouldn't bother with the DD kit :)
    in other words - lift - if you don't have vibes then leave it be, if ya get some try a CB drop kit = they only take about 5 minutes to install so no harm there in the even its needed
  3. Oct 10, 2017 at 6:11 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The carrier bearing drop corrects the rear driveshaft. Are you changing anything in the back?
    I didn't use a diff drop on my lift of about 2" and it looks like to me that it doesn't really help on a 2nd gen like it did on 1st gen Tacoma and the old 86-95 trucks.
  4. Oct 10, 2017 at 6:14 AM
    gmartin284
    Gage
    just an AAL in the rear and the 5100s. No vibes so far but i do have a pretty bad steering wheel shake at 45-55mph im also trying to sort out and hopefully correct while swapping these out. didnt know if it could possibly be from off geometry due to no CB drop or diff drop..
  5. Oct 10, 2017 at 6:21 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    CB drop kit yes. Diff drop kit, no no no no no no no. It's more useful in the trash
  6. Oct 10, 2017 at 6:22 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Got it, you have lifted the rear already. I used the OME carrier drop with my CS047R springs but it's only a slight correction. It's easy to try.
    The diff drop is more of a diff rotation on 2nd gens. You change the CV angle in one plane but change them in another. Plus you change the from driveshaft angles. So from what I read doing it usually eliminates one vibe but introduces another.
  7. Oct 10, 2017 at 6:28 AM
    gmartin284
    Gage
    thanks ill give it a try
  8. Oct 10, 2017 at 6:29 AM
    gmartin284
    Gage
    has anyone else experienced the steering wheel wobble at 45-55 mph? ive had a recent alignment and new wheels and tires. could a wheel bearing be shot or something? Sorry im getting a little off topic from the lift question..
  9. Oct 10, 2017 at 6:35 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    It's so hard to say for sure. Yeah, a wheel bearing could be going. Did the steering wheel shake just start when you lifted the truck? It could be caster angle (still using stock UCAs?), driveshaft u-joints, steering rack bushings, any number of things. I also wouldn't 100% trust a new alignment or wheels/tires. I've had brand new tires that weren't perfectly balanced due to being slightly out of round. A re-balance fixed it in that case for me. You can try rotating the tires front to back to see if helps or changes anything.
  10. Oct 10, 2017 at 7:07 AM
    Pigpen
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    Just a little info on the original question...
    In MY experience, 885 coils lift the front exactly the same amount as stock coils with 5100s set at the 1.75" setting.
    As for your steering wheel wobble...
    I would guess that whoever put the front wheels on last put the first couple lug nuts on too tight and the wheel is a hair off center. Every time the tire shop guys do anything to my truck, I have to go back and loosen all 4 wheels and retighten/ retorque them myself for a smooth ride. Those monkeys shouldn't be allowed to have pneumatic tools (I used to be one of them).
  11. Oct 10, 2017 at 7:19 AM
    gmartin284
    Gage
    thanks ill give that a shot and see if that helps. as for the coil question. if that was the case can i run the 885's with the 5100s on the first setting up? im running 285s so i dont want to do the swap and then be super rubbing and have to go back to the trimming drawing board.
  12. Oct 10, 2017 at 7:20 AM
    geekhouse23
    I thought that when running the OME coils on 5100 shocks, you're not supposed to run them on anything other than the lowest setting :notsure:
  13. Oct 10, 2017 at 7:26 AM
    Pigpen
    Northwest Montana
    True
    Here's a little secret most don't know...
    5100s have a significant amount of up travel engineered into them, under the assumption people will run spacer lifts. You can add up to a 1/2" spacer for an extra 1" of lift and not bottom out the shocks. There's a great thread where a member did the dirty work to figure this out. I'll look for it.
  14. Oct 10, 2017 at 7:29 AM
    Pigpen
    Northwest Montana
  15. Oct 10, 2017 at 7:30 AM
    Pigpen
    Northwest Montana
    You still don't want to go over 3" total for the sake of your CV boots.
  16. Oct 10, 2017 at 7:32 AM
    scottalot
    scottalot Meow
    Stockalot
    SC
    1984 Phemail
    Gotta jump on that Manual locking hub conversion kit bug that's going around
  17. Oct 10, 2017 at 7:34 AM
    Pigpen
    Northwest Montana
    IIRC, that is a fucking expensive mod. I haven't looked into it in awhile though. Now that I have the push button 2wd low range mod, I could care about manual hubs.
  18. Oct 10, 2017 at 7:35 AM
    scottalot
    scottalot Meow
    Stockalot
    SC
    1984 Phemail
    indeed - last I saw was about ~1250.00 for parts :ek:
  19. Oct 10, 2017 at 7:41 AM
    Pigpen
    Northwest Montana
    Mine was $250
    jmaack and scottalot like this.
  20. Oct 10, 2017 at 7:42 AM
    scottalot
    scottalot Meow
    Stockalot
    SC
    1984 Phemail
    :thumbsup:
