OME Lift UCA Touches Coil Spring
Discussion in '1st Gen. Tacomas (1995-2004)' started by JCH, Mar 28, 2013.
  1. Apr 22, 2013 at 10:10 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Huge upgrade in my opinion. That is for the Icons though. Don't have first hand experience for the LRs.
    I've been wheelin' with the same guys for the last few months. One particular area we go, we're bajaing through a dry river bed. Typically I'm falling off the pack, white knuckling the whole time just trying to keep the truck pointed in the right direction. This past run, was hanging with them and having fun at it.
    Other thing I noticed was during the rock crawling, didn't lose traction on the same obstacles like I have in the past. Figured I was seeing the advantage of getting that little extra droop when I was flexing hard.
    I'm still on a high how the truck is handling off-road now. Even one of my friends noted how it felt smoother on pavement.
    Maybe somebody will pipe in with their LR experience.
  2. Apr 23, 2013 at 4:54 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    $499
  3. Apr 24, 2013 at 4:46 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    Fucking SoCal
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I've got LRs and spring contact. The BJ contacts enough to wear a hole in the BJ boot. Replaced the boots once, and while doing so discovered LR puts maybe a marble-sized dab of grease in there -- so I stuffed if full of RedLine (which means I now have RedLine grease all over my upper BJ :rolleyes: ).
    Icon is in the future, but it's gotta wait until I get fully armored first.
  4. Apr 24, 2013 at 10:53 AM
    TacoMX
    Jonathan
    Deltona, Florida
    thats good to know. I almost went the LR UCA route, but I figured I might as well shell out the extra $150 or so for a uniball UCA. Glad I did.
  5. May 2, 2013 at 8:47 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    good info in here! I've got this happening to both sides. so far no damage to the UBJ but I'm sure its only a matter of time. UCAs are in the somewhat near future and I was thinking of going w/ the Camburgs.. any experience with these guys?
  6. May 2, 2013 at 8:02 PM
    TacoMX
    Jonathan
    Deltona, Florida
    All four brands (camburg, icon, all pro, total chaos) of UCAs will be more than sufficient for the average user. I couldn't see anyone having a legitimate complaint as far as quality or performance.
    I chose the APs because they were the cheapest and offered the same features as the rest. Their build quality seems flawless, welds look great, made of chromoly like the rest, the powdercoating is nice, grease zerks and poly bushing and they use FK uniballs, which are known to be very good. Plus their site says they are TIG not MIG welded, so that's a plus. Not sure what the competition uses.
    I couldn't see paying another $200 for icons or total chaos arms when they are pretty much the same thing, minus the bling bling.
    The Camburg arms are priced the same as the APs. So both are fine choices IMO
  7. May 2, 2013 at 9:29 PM
    tomtom
    The Desert SW
    2012 FJ
    Yar, I only went with Icon because I might go full Icon MT setup at some time. I'm all OCD like that. The uniball setup is nice because it doesn't have the huge stud jutting out on top like others do but that is more cosmetic.
    One thing I will warn on the Icons is the ABS sensor wire bracket studs should be torqued no more than 6lb/ft. Don't ask how I know... :eek:
  8. May 3, 2013 at 12:17 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Which coils do you have?
  9. May 3, 2013 at 5:27 AM
    TIPICOTACO
    Tyler
    nw nj
    thanks TacoMX
    I'v got the 881s w/ 10mm enhancer
  10. May 3, 2013 at 10:00 AM
    JCH
    JCH [OP] Well-Known Member
    Justin
    Wyoming
    07 Sport
    -Bilstein 5100, OME 885 springs, 2 10's behind the seat, Hankook Dynapro ATM
    I just ended up taking out the top plate spacer. No more contact now!
  11. May 3, 2013 at 10:55 AM
    ffirg
    mike
    Anchorage, Alaska
    Hm ok. I went with 883s with no top plate. Hopefully I won't have issues.
  12. Jun 29, 2013 at 10:58 AM
    TIPICOTACO
    Tyler
    nw nj
    how have the 883s been for you?? any extra weight up front? I'm sick of hearing the "clunk" every time I hit full droop and new coils would be cheaper than UCAs
  13. Jun 29, 2013 at 7:07 PM
    ffirg
    mike
    Anchorage, Alaska
    Well I've probably put about 1000 miles on them so far. No weight up front. They've settled nicely but I was having some weird noise when going over some larger bumps. As the suspension cycles down. I looked at the coils yesterday and I did notice some chipped paint on them where yours are rubbing. So I might have the same issue. Ill keep an eye on it and see what happens
    Other than that, they ride great. Definitely stiff but I like them. I recently started driving with 30psi instead of 40 in my tires and that makes a huge difference as well. Might cause some uneven wear, but we'll see.
