Ome lift with bad ride
Discussion in 'Suspension' started by Ksukosd47, May 26, 2015.
  1. May 26, 2015 at 11:18 AM
    Ksukosd47
    Ksukosd47 [OP] Active Member
    Kenny
    Ohio
    15 4wd 4door sr5
    installed an OME lift complete struts with spacer up front and full leafs in the rear , the ride is kinda rough but the biggest thing bothering me is how violent bumps in the road feel in the steering wheel. If anyone has had this problem and fixed it or knows anything about please help. It's on a 15 double cab with 33" tires. Thanks
  2. May 26, 2015 at 11:19 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  3. May 26, 2015 at 11:26 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    OP - What front coils springs did you go with?
  4. May 26, 2015 at 11:36 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    yeah you might have gone with too stiff of coils, do you have any weight in the front? ex. winch bumper sliders..
  5. May 26, 2015 at 11:37 AM
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    You may need to increase your caster to 2.5-3.0 to fix what is commonly called 'bump steer'.
  6. May 31, 2015 at 1:03 PM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    My coils are 885's and just had it aligned again and he could only get caster to like .5 I'm running 30 psi in my nitto terra grappler g2's
  7. May 31, 2015 at 1:06 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    It's not the suspension, it's the caster. You should find a better alignment shop. With stock UCA's you should still be able to get greater than 0.5 degrees of caster.
  8. May 31, 2015 at 1:30 PM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    Ok I will check around thanks
  9. May 31, 2015 at 1:37 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Tell the alignment shop that you want 0 Toe, 0 Camber, and to max out the caster.
    Ksukosd47[QUOTED][OP] likes this.
  10. May 31, 2015 at 2:06 PM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
  11. May 31, 2015 at 2:14 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Hey at least it looks great. Those don't look like OME shocks though (for your full OME kit). Billies? Fronts set at zero?
  12. May 31, 2015 at 2:42 PM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    The backs are toytec boss shocks because at the time the OME shocks did not fit the 15' mounts. And idk what you mean by fronts set at zero?
  13. Jun 1, 2015 at 3:28 AM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    My front struts aren't adjustable unless there's something hidden in there.
  14. Jun 1, 2015 at 3:39 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    You are correct, they are not. You mentioned spacers up front, i assume you mean OME trim packers and not half inch aluminum spacers up front as well. This is not bump steer and you should get your alignment rechecked for the play in the steering wheel. However, they are linear rate springs and not progressive like your stock coils. 885 are a proper setup for your ride, but they are not plush and there will be some "breaking in." 3k in suspension and tires wont get you a baja style ride so you are getting as advertised. I would recommend selling/swapping for ICON or KINGS if you want that progressive coil feel back on a much nicer custom valved ride. These two struts are digressive and progressive valving respectively to provide softer dampening and stiffer dampening, respectively at speed. The coil only supports the weight and also adding some skid plates or extra weight up front would help as well.
  15. Jun 1, 2015 at 3:56 AM
    Delrivpilot
    Delrivpilot Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    Truck looks awesome! I love the white with black wheels. Looks really good. I hope you work out your ride issues.
  16. Jun 1, 2015 at 3:58 AM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    Thanks for the input, I would definitely like a better ride hopefully I can sell these struts and try some icons or something
  17. Jun 1, 2015 at 4:39 AM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    I agree, ride matters. It's been 6 months I've been waiting for my new frame. I bought the OMU suspension lift from Toytec. 885 coils, aal with spacer up front. They are installing on their dime. Can't wait to get it back. They are saying this month.
  18. Jun 1, 2015 at 7:45 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The OME set up is not adjustable
  19. Jun 1, 2015 at 8:34 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Save your money. You'll have a harsh ride with any coil over with extremely low caster. I ran the OME setup for three years and it did just fine. The issue you do have is stock upper control arms that don't allow enough caster. If you're going to spend any more money buy a set of Light Racing upper control arms. That will allow you to have 2.5 degrees of caster. The truck will drive straight and true and the harshness will go away.
  20. Jun 1, 2015 at 11:44 AM
    Ksukosd47
    Kenny
    Ohio
    15 4wd 4door sr5
    Ordered the light racing uppers I hope it takes care of it.
