OME questions (want to make sure I order everything needed)
Discussion in 'Suspension' started by cathellsk, Sep 1, 2010.
  1. Sep 1, 2010 at 5:18 PM
    cathellsk
    cathellsk [OP] Active Member
    KY
    2023 Barcelona Red TRD Off-Road
    Minimal
    Little background about me, I'm a former JEEP owner (4 different Wranglers) and OME is highly thought of in that community. I had an OME lift on my last JEEP, an '04 Wrangler Unlimited LJ and LOVED IT.
    Fast forward to now, I'm on my third Tacoma ('10 TRD Sport DC 4x4) and want to get an OME for it. I'm looking at the Toytec website and their OME kit. Because of my DC I'm going with the 885s up front. I don't feel I need the top plate spacers as all I want to do is clear a set of 265/70s.
    I'm going with the AAL w/out TSB springs (dealer is giving me crap about doing the TSB) for now and may update to the DAKAR springs at a later date.
    My questions are:
    1 - How much lift do you net with a V6 DC and 885 coils w/out the top plate spacer? I'm not adding any bumpers, winches, etc.
    2 - Will this set up sit fairly level? I don't mind if the rear is a little higher, used to that look anyway.
    3 - Do I need anything else thats not included in Toytec's kit? I want to place one order for everything.
    I'm not going for a particular height other than to clear the above mentioned tires. I want the OME ride quality that I enjoyed on my LJ.
    Thanks in advance!
  2. Sep 1, 2010 at 7:25 PM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    I'm interested in the responses here. I have OME on my XJ and want it for my 01 DC 2wd V6. Thinking about returning the Bilsteins I bought and getting the OME kit.
  3. Sep 1, 2010 at 7:48 PM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
    1 - How much lift do you net with a V6 DC and 885 coils w/out the top plate spacer? I'm not adding any bumpers, winches, etc. I didn't take any before measurements; but I'm currently at ~ 36.75" in the front with only 885x coils and taco lean spacer on stock size tires (245/75R16). I'm assuming ~ 2.5" of lift.
    2 - Will this set up sit fairly level? I don't mind if the rear is a little higher, used to that look anyway. I have 885 coils w/o top plate spacer & 1.5" tsb aal + tsb leafs and have ~ 1.5-2" of rake.
    3 - Do I need anything else thats not included in Toytec's kit? I want to place one order for everything. Since you have a 4x4, a diff drop is recommended. Might also need axle shims and/or carrier bearing drop depending if your truck develops vibes or not.
  4. Sep 1, 2010 at 7:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    OME is great I have the 885s on my truck and greasable shackles on my jeep.
  5. Sep 1, 2010 at 8:01 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Get 3 deg axel shims....diff drop doesnt really do anything for the new gen tacoma. Not sure about AAL, but if you do go with Dakars, extended rear brake lines will be NICE, but not needed. When I am at full flex, my stock lines are tight, but are not pulling out. Also, I have a 10mm top plate ontop of my 886 for the front to allow her to set level in with Dakars in the rear.
  6. Sep 1, 2010 at 10:51 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Out of curiosity, what don't you like about the Bilsteins?
  7. Sep 1, 2010 at 11:02 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    You don't need a lift to clear 265/70/17 or 265/75/16.
  8. Sep 1, 2010 at 11:07 PM
    HusqyRider
    Adam
    La Mirada, CA
    I have factory Bilsteins (c. 2001) and I don't know the 5100s are the best improvement-to-dollar ratio. I've heard the OME shocks are a better overall ride than the Bilsteins. That's my research, and someone else may jump in and correct me. I don't want to pay 3 bills for a marginal improvement.
  9. Sep 1, 2010 at 11:14 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    well if you're getting OME coils, the OME shocks are better matched..some fancy mombo jumbo that i can't remember, but none the less..
  10. Sep 1, 2010 at 11:23 PM
    cathellsk
    KY
    Minimal
    Negative. I got a set of Nitto Terra Grapplers in that size on a set of 17x9 KMC Revolvers. The only time they don't rub is when I'm going straight down the road. I'm not cutting my inner fender well either.
    I had a Daystar spacer lift installed and that cured the rubbing but the rear end is lower than the front now and I've learned that those kind of lifts aren't the best to have and want to replace it.
    Anything else I do to this truck is going to be done right, hence the OME kit because I know they are GTG.
  11. Sep 1, 2010 at 11:49 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I'm running 265/70/17 MT's no lift , no rub at all .
    Lots of others are running this size tire on stock set ups as well , odd that you are having such big rubbing troubles .
  12. Sep 2, 2010 at 12:21 AM
    cathellsk
    KY
    Minimal
    My '08 didn't but this '10 does. Don't know why, wheels maybe?
  13. Sep 2, 2010 at 5:47 AM
    Jigzor
    Pennsylvania
    Stock wheels you shouldn't have any issue. It could be the aftermarket wheels.
  14. Sep 2, 2010 at 5:54 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Get the trim packer for the left front to counter the taco lean.
    I have this setup with the 1-1/2" AAL, I do not need the axel shims with this setup no low speed vibe.
    You will like it.
  15. Sep 2, 2010 at 8:42 AM
    cathellsk
    KY
    Minimal
    What is that and where can I get it?
  16. Sep 2, 2010 at 8:53 AM
    cathellsk
    KY
    Minimal
    Here's some pics of it with the wheels/tires pre-lift.
    You can see the difference between the two sizes in the last picture. Not much on paper but obviously a big difference.
  17. Sep 2, 2010 at 5:01 PM
    OZ-T
    Peter North
    British Columbia
    Probably this ^^^^^
    I am on stock wheels with no rub , maybe your aftermarket wheels have a different backspacing ?
  18. Sep 8, 2010 at 12:15 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    any body have ride height measurements? IE from ground to center part of fender?
    I have the OME 3in, LR UCA's, with the top plate spacer and 285x75 tires and seem to be really jacked up. I'm about 39 1/4 in.
    The reason I ask is I now seem to have virtually no down travel. I'll go over a bump and bottom out the suspension. I think I might remove the spacers and see if that helps.
    Also not sure how much the lift will settle and how long that will take but hopefully that will help too.
  19. Sep 8, 2010 at 12:27 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Maryland
    18 TRD Offroad
    1. i got a full 3 inches out of my kit but i DID use the top plate
    2. you will sit perfectly level if you use the top plate
    3. i suggest getting rear shock extenders which toytec has, search their site
    i love my lift but you can fit 265/70s on stock suspension. also if i were you i would get the spacer and use it. you might want to think about getting bilstein 5100s
  20. Sep 8, 2010 at 12:28 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    the rear seems fine its the front that seems to have no down travel.
