Ome spring self install
Discussion in 'Suspension' started by Swampmonkey, Apr 16, 2012.
  1. Apr 16, 2012 at 5:11 PM
    Swampmonkey
    Swampmonkey [OP] Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    Guess I'll rent a spring compressor and put my own ome stuff together. All the tire shops around me are dicks. Anyone else feel my pain.
  2. Apr 16, 2012 at 5:14 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Don't go to a tire shop to have a lift installed. Problem solved.
  3. Apr 16, 2012 at 5:14 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    I just installed mine using this method...I know there are people on here that say it is unsafe, but spring compressors really scare me, so I gave it a go. It was REALLY easy.
    http://youtu.be/vkVLBOnAifc
  4. Apr 16, 2012 at 5:15 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Tire shops do a lot of suspension work ?
  5. Apr 16, 2012 at 5:22 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Not getting tire shop to install lift. Doing that myself. Just trying to save some coin assembling coilovers and struts.
  6. Apr 16, 2012 at 5:29 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Video looks easy enough. Any trouble with the alignment afterwards on this method?
  7. Apr 16, 2012 at 5:37 PM
    creedler
    creedler Well-Known Member
    Max
    Eugene, Oregon
    Stock for now
    Old build in sig
    I rented one of those cheap spring compressors form auto zone. Scared the shit out of me torquing it down/ scratched one of the coilovers up a little but it turned out well.
  8. Apr 16, 2012 at 5:42 PM
    John3
    Maryland
    No problems...just mark the alignment cams with a sharpie, so you can get it semi-aligned to be able to drive to the alignment shop.
  9. Apr 16, 2012 at 5:52 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Anyone got torque specs on lca and steering knuckle?
  10. Apr 16, 2012 at 5:57 PM
    John3
    Maryland
  11. Apr 16, 2012 at 6:10 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Thanks boss.
  12. Apr 16, 2012 at 6:13 PM
    04trd4x4AL
    04trd4x4AL Well-Known Member
    Daniel
    New Market AL
    04trdDBLcab4x4
    Tint , Deck Plate, debadged, Bil 5100's set @ 2.5 up front, Bil 5100 in the rear and AAL. Diff drop. B.A.M.F brake proportioning bracket.
  13. Apr 16, 2012 at 6:31 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Thanks buddy. Think I can handle it. Just like to make sure I got my ducks in a row.
  14. Apr 16, 2012 at 6:41 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    I like it. Looked easy and safe. How did you convince Stephen Hawking to narrate your video? :D
  15. Apr 17, 2012 at 6:03 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Do you just mark the alignment tabs where ever they r pointing at. mine already have some sort of paint mark from the factory.
  16. Apr 17, 2012 at 6:13 PM
    dmb
    dmb Well-Known Member
    Boise, ID
    Mine had some marks from what I assume is the factory or a previous alignment. I just took a sharpie and put a small dot on the tabs so I could get them put back.
  17. Apr 17, 2012 at 6:55 PM
    John3
    Maryland
    ^Exactly. Mark them any way you want, so you can get it back to where it was before you loosened the bolts. Just make sure you mark both cams since they can adjust independently.
  18. Apr 17, 2012 at 7:37 PM
    Swampmonkey
    Wes
    Fairhope, AL
    Thanks guys!
  19. Apr 27, 2012 at 9:45 AM
    Swampmonkey
    Wes
    Fairhope, AL
    Installed 885s and shocks last night using the video method and it went pretty good. Just took a little time getting truck up high enough and had a little trouble compressing passenger side coil to get top bolt on. Ended up having to drive it up on some 6x6s to use the weight of the truck to get enough threads to start bolt but got it done. Looks awesome and glad I didn't get top spacers. Setting a little high right now but I'm stoked. Now just got to get an alignment. Thanks for the knowledge gentlemen.
  20. Apr 27, 2012 at 9:57 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Installed my 885s yesterday too and finally got rid of my 2" spacer lift that was on the truck when I got it. I didn't loosen the alignment bolts and didn't have any trouble getting the lower control arm low enough to remove the old or install the new spring. Just used my pry bar to push the Lower Control Arm down when I needed more droop.
