OME Suspension, lower on left side.
Discussion in 'Suspension' started by EricGagne, Jul 25, 2012.
  1. Jul 25, 2012 at 5:27 PM
    EricGagne
    EricGagne [OP] Well-Known Member
    Eric
    Montreal
    2010 TRD Off Road
    Literider Tonneau Cover, RAM Mount Laptop Support. Uniden CB RTT and awning with self-designed custom rack Dual battery system - National Luna solenoid and monitor, Columbia Overland dual battery tray, 2 Odyssey PC1200 12 circuits Fuse block with 80A macro fuse block "breaker" OME suspension Replaced passenger area with a flat platform for my ARB fridge and camping clothes. Tiregate HG series
    Hi TW.
    I bought a complete OME suspension for my truck and the garage who's installing it just called to tell me it's about 1" lower on the left side.
    Has anyone had or seen this before ? Did they screw up the installation ?
  2. Jul 25, 2012 at 6:09 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    well i know its normal to sag a tiny bit on the drivers side, not a full inch though I dont think
  3. Jul 25, 2012 at 6:10 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    is the collar installed the correct way on the driver side?
  4. Jul 25, 2012 at 6:19 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    you got the trim packer kit when you ordered?
  5. Jul 25, 2012 at 6:20 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Yeah. Did they put one collar on upside down. Take pictures of both sides if need be.
  6. Jul 25, 2012 at 6:20 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    How ate they measuring it? From the center of the hub to fender or ground to fender? Is it both the front and the rear?
  7. Jul 25, 2012 at 6:25 PM
    08pretaco
    Oliver
    az
    post pics of both of the shocks near the bottom of the spring
  8. Jul 25, 2012 at 6:25 PM
    Large
    Large Red
    Are you using 5100s for shocks or the nitros?
  9. Jul 25, 2012 at 6:29 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    I'm running 5100's and OME 886's and no such lean:confused: i have the taco lean but i mean thats normal
  10. Jul 25, 2012 at 6:29 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Taco lean.
  11. Jul 25, 2012 at 6:31 PM
    08pretaco
    Oliver
    az
    not if its an 1"
  12. Jul 25, 2012 at 6:32 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    My taco lean was over an inch lower up front and 3/4 inch in back.
  13. Jul 25, 2012 at 6:37 PM
    EricGagne
    Eric
    Montreal
    2010 TRD Off Road
    I'm getting the truck back tomorrow morning. I'll take pictures and post them but it won't lean as much because the suspension guys are putting a spacer under the leaf spring.
    He said it's the best solution, I thought I might as well do it until I figure out what's wrong.
  14. Jul 25, 2012 at 6:43 PM
    08pretaco
    Oliver
    az
    so is it lower in the front or rear? how is lifting the rear going to level the front?
  15. Jul 25, 2012 at 6:56 PM
    EricGagne
    Eric
    Montreal
    2010 TRD Off Road
    The way I understood it was the whole driver side. I know nothing about mechanic but his spacer thing makes no sense to me.
    For now I just want to get the truck back, figure out if they did anything wrong and if so I'll just take it somewhere else and pay to have done properly.
  16. Jul 25, 2012 at 7:04 PM
    08pretaco
    Oliver
    az
    ya thats weird. so if the whole side is 1" lower that makes it easier for me to believe its just the taco lean BUT makes no sense to add a block to the rear.
    what OME coils did you get, 885?
  17. Jul 25, 2012 at 7:08 PM
    EricGagne
    Eric
    Montreal
    2010 TRD Off Road
    886 + Nitrocharger Sport. I have 2 Odyssey PC1400 under the hood and next week I'm adding a Warn Trans4Mer and Warn M8000 winch.
    The rear is the standard OME kit, Dakkar and N182.
    I've been googling for over and hour and found many things about this lean but no one seems to have it this bad.
  18. Jul 25, 2012 at 7:09 PM
    08pretaco
    Oliver
    az
    did you get the trim kit for the front as well or the toytec top plate spacer?
  19. Jul 25, 2012 at 7:11 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I have the full OME kit with 886's up front and Dakars out back. I do not have the trim packer, but I do have the toytec 1/4" spacer up front on the drivers side. I have about 1/2" of lean to the drivers side. All of these trucks are a little different, go figure.
  20. Jul 25, 2012 at 7:14 PM
    08pretaco
    Oliver
    az
    well if you installed the 1/4" spacer that = 1/2" of lift so I would technically say that your truck and his ARE in fact the same, not different
