????? OME Suspension upgrade
Discussion in 'Suspension' started by elwood, Jun 17, 2009.
  1. Jun 17, 2009 at 6:36 PM
    elwood
    elwood [OP] "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Good day to all. Right off the bat I would like to thank you guys and gals for all the extremely helpful info on this site and really appreicate the real world experience.
    I have been contemplating doing a suspension swap for some time. I would like a small amount of lift for looks and more capacity in the rear without sacrficing ride. I am hoping for the next set of tires to be 265 75 16's on stock alloy's and would think a little more height with that tire would look good. I need the truck to remain "sane" and useable as we tow alot. I am really liking the ARB OME 885 suspension kit . Springs and shocks at all four corners.
    My question for the forum would be has anyone had any problems with JUST changing the coils, leafs and four shocks and nothing else?? Do you need to change the control arms? Brake lines ? and is the drive shaft spacer neccesary to combat vibration?:confused:
    With the lift only around 1.75 inches is there a concern about boot tearing in the front? Is the ride going to improve as much as they all say? It would be sweet if a truck had these upgrades and is in southern Ont so I could drive it and feel the difference.
    Up here in the great white north the prices are no were near as cheap as down south so I really research things before commiting the cash.
    We have a few relatives in north Georgia and we visit them once a year so I have toyed with purchasing while on vacation but then if a part is wrong I'm screwed on returning as it is a 13 hour drive back.:eek:
    The best I could get for the whole kit was $1400 Cad at National 4WD in Hamilton Ont. about an hours drive from home.
    Any help is really appreciated.
    Thanks in advance
    Remember for every mile of road there are 2 miles of ditches so use all of them.
  2. Jun 17, 2009 at 6:55 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I think with the Kit your looking @ you should be fine, I would just replace the rear brake lines.
    Also I think www.wheelersoffroad.com has the best price on the OME stuff.
  3. Jun 17, 2009 at 6:57 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I am gonna try to help you out if I can remember all your questions.
    The 885's will give you a minimum of 2" lift probably a little more. From what I have read and heard some guys got up to 2.5" of lift from them. (I just bought a set but the aren't installed yet." I also did a 2.5" AAL in the rear (just bought a new Deaver packs). I HAVE NOT changed my Control Arms and my alignment is dead on, so I have no worries there. I did do a 1" diff drop and a sway bar relocator. (I would recommend the diff drop (cheap and easy to do). Every truck is different so you will have to play it by ear (so to speak). If you get any vibration, then figure out where and fix it. I do not get any vibration now, but I did until I got the tires balanced (again). You can get the lift stuff you want pretty cheap. The OME 885's should be under $200 and the AAL depending on brand for under $150 (Skyjackers are $90 on ebay). Hope this helps.
  4. Jun 17, 2009 at 6:58 PM
    badguybuster
    Michael
    Oh, I tow a horse trailer with mine. On a regular basis, no problems.
  5. Jun 17, 2009 at 7:03 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    What is a diff drop???? and is that the front you are talking about??
    Thanks prez for the website.
  6. Jun 17, 2009 at 7:05 PM
    PrezidentRedz
    Redz
    Owings, MD
    yeah its for the front diff, to help with the CV angles. Check out wheelers they also sell those.:D:D
  7. Jun 17, 2009 at 7:21 PM
    badguybuster
    Michael
    Yep. You can also check Toytec.com
  8. Jun 19, 2009 at 3:51 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    I used to have this very similar kit installed on my truck. It was ok, better than a body lift or a straight spacer lift. I sold mine after putting about 500 miles on it. No defective problems at all just not for me.
  9. Jun 20, 2009 at 9:19 AM
    ryber
    ryber Well-Known Member
    kitchener, ontario
    06 Reg Cab 4X4
    285/75/16 MTZ's.... OME lift(885s)...4:88 gears.... Front and rear ARB.... Homemade skids
    I think 1400 CAD is a decent deal.. www.TRDparts4u.com got it for around 950, but once you convert and add shipping and duty will probably be more then that.. Let me know how much and where from, if you end up getting the kit, been thinking of getting it myself
  10. Jun 24, 2009 at 5:03 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    hey ryber do you have any rubbing or problems with the 265 75 16's on your truck????
    Where in Kitchener are you.
  11. Jun 25, 2009 at 3:19 PM
    ryber
    kitchener, ontario
    06 Reg Cab 4X4
    Very rarely.. but occasionally with wheel fully turned and hitting a bump at the same time I get minimal rubbing. I tracked it down to the inner front fender its not bad so I'm not going to trim it.. I also have bilstein 5100s set with a 1.75 lift up there.
    I live just behind chicopee off of morgan
