OME Suspension?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TGurau, Jun 16, 2010.
  1. Jun 16, 2010 at 10:25 AM
    TGurau
    TGurau [OP] Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    I wanna know your opinion. I have the money to buy this suspension but wanted to make sure that it's a full 3" lift and a good lift to buy. I would get the Toytec ultimate but 1k is just out of my price range. PLEASE, i need your input fast because I'm about to buy it :p
    OME Tacoma suspension:
    Front coil options: 883 coils (Med)
    Front top plate spacers: Add for full 3 inch front lift w/ 881
    Rear lift options: ToyTec 2 inch lift add-a-leafs
    Rear shocks: 60062 (Normal valving)
    Front diff drop kit: Included (4x4 only)
    Front shock Assembly: Assembled with new top plates (+ $100.00)
  2. Jun 16, 2010 at 10:27 AM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    I heard it's a great lift. I'm saving up for it now.
  3. Jun 16, 2010 at 10:51 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    do you know the difference between soft valving and normal valving?
  4. Jun 16, 2010 at 11:18 AM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Who's quoting you $100 to assemble the fronts. There is a vendor here that will do it for $180 so I'm interested since it's a difference of $80.
  5. Jun 16, 2010 at 11:21 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Do it! I have 885's on mine with the ome sport 9000's and it sits at least 2.5", but I've never measured. If you are going for a stiffer but way better ride this is the way to go. I''m not sure you will need a 2" aal becasue I got a 1.5" and it sits nice and level.I also don't have the diff drop and honeslty I don't think its needed, but if you want that good feeling then do it:)
  6. Jun 16, 2010 at 11:35 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    I went to Toyteclifts.com and they offer to assemble it for an extra $100 as part of the package for the OME suspension.
  7. Jun 16, 2010 at 11:37 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Why would you buy something without fully researching it. Impulse purchases tend to be stupid purchases. do your homework. You'll probably get more feedback under the suspension forum.
  8. Jun 16, 2010 at 11:38 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Give me a call and I can get you setup with those parts, and/or other parts you may want or need. OME has very good products.
  9. Jun 16, 2010 at 11:40 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    I've been looking at this lift for over a month, i just wanted input from someone that actually got it or someone that knows someone that got it (if that even makes sense).
  10. Jun 16, 2010 at 11:41 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    i've got it. absolutely love it. firmer than stock but so plush off-road
  11. Jun 16, 2010 at 12:27 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i love mine... sits nice and agressive looking. and off road does great. more flex than you would think.
    and i have the diff drop done, imo every little bit less of cv angle u can get, the better...​
  12. Jun 16, 2010 at 12:40 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  13. Jun 16, 2010 at 12:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  14. Jun 16, 2010 at 5:02 PM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    V6 Factory bumper/ no winch. 32x11.5x15 with the 4runner rims (i don't know what year the 4runner rims are but i would guess late 90's). My rear struts have been leaking for some time now and i really need to replace them because it's a really hard ride.
    It said on the toytec website that the 881's were lows, the 883s were the mids and the 882s were for heavy front ends.
  15. Jun 16, 2010 at 5:09 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Well Wheelers and ARB says the 881s are the mediums, and considering ARB is the manufacturer of OME stuff, I'd go with what they say.
  16. Jun 16, 2010 at 5:22 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have a similar setup and Dan from Wheelers sold it to me. Good stuff and Wheelers was great.
  17. Jun 16, 2010 at 6:22 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I wouldn't go any heavier than 883s in the front. 881s do fine IMO though, I havethem with my ARB bar and it works just great.
  18. Aug 8, 2010 at 8:39 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    881's and 883's are the same length but different spring rate (883's are a bit higher) 882's are the same spring rate as the 881's but about a 1/2 longer. correct me if im wrong but i do believe 883's are recommended for double cabs
  19. Aug 8, 2010 at 9:38 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    got an 03 d/c ome 883 up front dakars out back 5100s all around stock bumper no winch yet rides and handles great feels more balanced than stock front seems to stiffen up and corner better while it actually rides smoother less choppy out back havent had a chance to haul anything too heavy yet but i was suprised how much more it flexes offroad it sits 3 in higher in ft and almost 4 in higher in the rear stock springs seemed pretty roached so im not sure how much lift it will give you if you have any other q's pm me
