OME Vibes, Thoughts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jschwerdtfeger, Nov 18, 2014.
  1. Nov 18, 2014 at 10:44 AM
    jschwerdtfeger
    jschwerdtfeger [OP] Well-Known Member
    Jeff
    Santa Cruz, CA
    2020 Tacoma DLCB TRD Off Road
    Fox 2.5/2.0, Deaver Expo Stage I
    Hey Guys,
    My Rig:
    2001 Tacoma TRD Access Cab MT 140k
    Full Wheelers OME Lift, with Dakars and trim packers.
    Matte Black Procomp 7089s
    So here's the deal, last week I had the fellas at "4x4 and more" in Scotts Valley, Ca, install my OME kit and new wheels + alignment. Since then, when the drivetrain is cold I'll get a vibration/ shutter when coasting down from 10mph to stop. This is with or without applying the breaks. Here's where the plot thickens —*once the drive train warms up, the vibes disappear, only to show back up the next morning.
    Thoughts?
  2. Nov 19, 2014 at 1:15 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    No vibrations when accelerating? Any high speed vibes (60-65 mph)?
    Hard to say what would cause low speed vibrations during cold operation only. I would start with checking the torque on every bolt the shop touched, and then start looking at driveline angles as a possible source, although generally driveline vibrations are consistent throughout operating temperatures.
    If the rear carrier bearing has never been replaced, that is a likely candidate for amplifying the vibrations caused by driveline issues, although I wouldn't change it out until you identify and solve the root problem.
  3. Nov 19, 2014 at 1:35 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    New wheels and new tires? Or just new wheels with your old tires?
    If you have new tires, I would suspect those. Tires sitting overnight can have a flat spot on them until they warm up. Some are worse than others and it has gotten colder at night. :notsure:
  4. Nov 19, 2014 at 1:37 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    When is the last time greased your u-joints? Old, "hard" grease could be causing the vibrations until it loosens up due to the heat.
  5. Nov 21, 2014 at 6:01 AM
    LetsTacoboutit
    LetsTacoboutit Well-Known Member
    SEÑOR MEMBER
    Tejas
    4x4 TRD 6cyl
    yada, yada, yada
    I had the same issue. I had the shop re-torque the bolts after 2 weeks of driving, greased the fittings on the shaft, and installed a street taco drop. No vibrations anymore.:)
  6. Nov 21, 2014 at 6:07 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Carrier bearing is my first thought-2nd-grease ALL the driveline fittings-ESPECIALLY the hidden one near the carrier bearing--there is a fitting(inside) that is missed by most.
  7. Nov 21, 2014 at 7:55 AM
    dispatch55126
    MN
    2004 Xtracab SR5
    Where is the CB zerk? I get the double CV zerks but have never found a CB zerk.
  8. Nov 21, 2014 at 8:24 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Not the carrier--the double CV (that is near the carrier)has a fitting between the obvious two-there are THREE fittings on the double CV
  9. Nov 21, 2014 at 8:27 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  10. Nov 21, 2014 at 9:59 AM
    jschwerdtfeger
    Jeff
    Santa Cruz, CA
    Here an update,
    • Thanks so much for all your responses!
    • Post lift the truck is much louder at 60+ mph with a slight vibration.
    •*CB is new OEM Toyota, thought there is no spacer so it sits on the frame causing a big drop to the rear end. I’ve order a street taco spacer, hopefully it gets here faster than the quoted 4wks!
    • New wheels, old tires (still pretty new) Dueler 2 AT 265/70’s they have a bit of uneven wear, but nothing to merit vibes.
    • U-joints were just grease via the TW article mentioned below :D
    • I’ve also ordered a new R150F from Marlin crawlers, since my has shot synchros and a whining bearings. Should be here next wk.
    • I've also noticed a decrease in MPG from ≈20, down to ≈17 —yikes! That seems wrong from a 3" lift with a stock tire size!
    Thanks again, happy Turkey Day!
  11. Nov 22, 2014 at 1:49 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
