On board air in TRD OR engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anethema, Jan 26, 2012.
  1. Jan 26, 2012 at 9:25 PM
    anethema
    anethema [OP] Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    I am going to put together a dual compressor on board air system. Just wondering if anyone has has any luck mounting 2 smaller compressors in the engine bay? Maybe by relocating stuff?
    Can get an idea of compressor sizes here:
    http://www.smittybilt.com/docs/installation/2780.pdf
    second picture, first is a higher flow model.
  2. Jan 26, 2012 at 10:27 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I've seen one mounted between the ABS module and the intake. If you need more space, look under the front bumper cover.
  3. Jan 26, 2012 at 10:37 PM
    anethema
    J
    Dawson Creek,BC
    Ya saw there. I ordered 2 let's see if I can squeeze 2 in that bay somewhere!
    Was hoping someone had done it.
  4. Jan 26, 2012 at 10:39 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Why two of them?
  5. Jan 26, 2012 at 10:43 PM
    LBPtaco
    LBPtaco Swab
    Winter
    California Maritime Academy
    06 PreRunner TRD
    Total Chaos, SAW, Allied, Light Racing, Dakar, Billstein, Fox, URD, JBA, Demillo, Downey, Cooper, American Racing, B.A.M.F., Alpine, Ghetto Fab...
    Cuz 1 aint enough! I have one mounted under my hood and have been wanting to hook up a second one. I'll try to snap a pic of it this weekend and post it next week.
    Sub'd for now to see how this turns out...
  6. Jan 26, 2012 at 10:46 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Wouldn't it just be easier to get a single higher flowing pump?
  7. Jan 26, 2012 at 10:50 PM
    LBPtaco
    LBPtaco Swab
    Winter
    06 PreRunner TRD
    Yes, but for me I have 1 already, buying a second would be cheap. Ideally I would get a nice fancy ARB compressor and a tank, but for now I run what I got.
  8. Jan 26, 2012 at 10:59 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Gotcha, makes sense. I just wasn't sure if there was an advantage to running two that someone doing it for the first time would yield.
  9. Jan 26, 2012 at 11:29 PM
    anethema
    J
    Dawson Creek,BC
    2 smaller pumps is actually a lot cheaper than a single high flowing pump. They flow faster than even the highest end viair etc.
    If one breaks the other will probably still work.
  10. Jan 26, 2012 at 11:35 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    There's alot of room under the front bumper I put an air horn in there with plenty room to fit a compresser you would probably have to make a mount
  11. Jan 26, 2012 at 11:42 PM
    anethema
    J
    Dawson Creek,BC
    HM I'll have to take a look thanks.
  12. Jul 24, 2012 at 11:43 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    the one thing that kills a compressor is heat. That is why most of them have duty cycle limits. This means mounting the compressor under the hood is not always the best idea. mounting in the bumper away from the engine heat would work, and its still close to the battery. You could run a computer fan for blowing air across the compressor head to keep it cool.
  13. Jul 24, 2012 at 11:55 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Ever get it setup?
  14. Jul 25, 2012 at 9:10 AM
    anethema
    J
    Dawson Creek,BC
    No ended up moving and running out of money from unforseen moving costs before ordering haha. It is put on the backburner until this fall.
    EDIT: Oh, the two I had ordered were on LONG backorder so never ended up getting them either. C'est la vie!
  15. Jul 25, 2012 at 12:25 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    That's the route I'm going, I'm getting the tank as well. How bad was the install?
  16. Jul 25, 2012 at 12:37 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    how loud is that thing? can you post a vid of it running with and without the truck running (hood down). I'm looking at getting one this fall :)
  17. Jul 25, 2012 at 12:43 PM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    Thanks
