One problem with my 01 dcab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tdubliture, Apr 4, 2011.
  1. Apr 4, 2011 at 5:28 PM
    Tdubliture
    Tdubliture [OP] Member
    Tyler
    I have an issue with the rear suspension on my truck. It sits a little lower on the left side then the right. My friends call it the gangster lean!!! Will replacing my leaf packs fix this? Btw I have a 2" lift on the truck. Just the blocks in the back. Any help appreciated.
  2. Apr 4, 2011 at 5:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's actually called Taco Lean.
  3. Apr 4, 2011 at 5:40 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Yup fairly common among tacomas. The battery, gas tank, front drive shaft and tcase, and driver are all on one side. New leafs may help but beefed taco also sells .25", .5", and .75" blocks that are meant to be used ony on the driver side to combat the lean.
  4. Apr 4, 2011 at 5:42 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Where do you live? Anywhere near MA ill trade you my good stock springs for you saggy one's mine wont ever go back on but i want to have spares just incase.
  5. Apr 4, 2011 at 10:54 PM
    Tdubliture
    Tyler
    So what is the best route? Just shim the saggy side?
  6. Apr 4, 2011 at 10:55 PM
    Tdubliture
    Tyler
    Utah sorry kinda far
  7. Apr 4, 2011 at 10:56 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    If it REALLY bothers you that much...yup.
  8. Apr 5, 2011 at 5:02 PM
    Tdubliture
    Tyler
    It just looks really ghetto
