One Tire Blew - How Many Do I Replace?
Discussion in 'Wheels & Tires' started by rjtoc2, Aug 1, 2010.
  1. Aug 1, 2010 at 7:19 PM
    rjtoc2
    rjtoc2 [OP] Burglar of Turds
    Dallas/Fort Worth
    2008 Double Cab Prerunner SR5 (Super White)
    I have a 2008 Tacoma Double-Cab Prerunner. I have approximately 8000 miles on my truck with the original tires.
    I heard a loud "pop" this morning while driving home. Once I pulled up to my house, I heard a loud hissing sound. I noticed my passenger-side, rear tire was rapidly deflating. I pulled out all of the stuff and changed the tire. Upon inspection, the flat tire has a crack/split approximately one (1) inch in lenght across the top (tread) of the tire almost centerline.
    My question is this: If the tire is not repairable, do I replace the one (1) tire or do I buy at least two (2)? Again, the tires on my Tacoma are the original OEM tires with approximately 8000 miles on them (Dunlop Grandtrek AT-20).
    I've also heard from many people about needing to replace all their OEM tires fairly quickly as most OEM tires these days are brand-new factory rejects.
    Any info would be appreciated.
  2. Aug 1, 2010 at 7:21 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    perfect time to get some 265 75 16's , the Dunlops are garbage .
  3. Aug 1, 2010 at 7:23 PM
    red taco
    red taco Well-Known Member
    Cole
    La Verne, CA
    07 PreRunner Impulse Red Pearl
    If you don't really want to replace all of them right now you could have the spare mounted on the good rim and buy 1 tire that you plan on purchasing as the next set to keep and have as a spare. then when the 4 are ready to be done you can have a new tire already and just buy 3 new ones.
    Just a thought but the OEM tires only lasted about 30k on my truck
  4. Aug 1, 2010 at 7:28 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    This is what happened to me. I took the spare and mounted it on the bad tires rim. Then bought the cheapest tire I could and had it mounted on the spare rim.
  5. Aug 1, 2010 at 7:36 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Great advice...:thumbsup:
  6. Aug 1, 2010 at 7:41 PM
    c2thegreat
    c2thegreat Well-Known Member
    Ol' Virginny
    09 4 banger
    Readylift sst,31in. mts,TRD sport bilstein rear shocks,new head unit,bedlined tool box,fishing rack,35% tint,fogs
    If you are considering new tires nows the time to upgrade if not switching the spare in is your cheapest option.
  7. Aug 2, 2010 at 3:15 PM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    I got less than 10,000 kms on my grandtrek AT20 and a lump has appeared on the firewall on one tire and two have a concave style dent in them.Two or three to be exact.Seeing dealer on Thrusday.
    later tig1:confused:
