Only 1 Power source in cabin?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Amacdoce, Nov 28, 2016.
  1. Nov 29, 2016 at 1:24 PM
    #41
    Lunabird
    Lunabird Well-Known Member
    Awesome, I'm gonna keep this in mind for future mods.
  2. Nov 29, 2016 at 1:33 PM
    #42
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Now that I think about it.....guess my '09 didn't have a USB port.
    Sig45[QUOTED] likes this.
  3. Nov 29, 2016 at 1:33 PM
    #43
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Ick!
    TXpro4X4[QUOTED] likes this.
  4. Nov 29, 2016 at 1:36 PM
    #44
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    :rofl:
  5. Nov 29, 2016 at 1:55 PM
    #45
    Plain Jane Taco
    USA
    I actually went a slightly different route when I did this mod. Instead or using an actual 12 volt port or a dedicated USB port, I went with a cig lighter with a lighted ring. Then I plugged a dual USB insert into that. This gives me the options of both USBs or a conventional 12v charging source if need be.
    The socket is powered off an existing 12v charging port inside the center console. I tied the lighted ring into the parking lamp circuit...so it only works when the lights are on. Handy at night.
    I chucked the lighter insert onto the garbage.
    I may get around to doing this same mod to the backseat area of the Taco at some point.
    joelt[QUOTED] likes this.
  6. Nov 29, 2016 at 2:45 PM
    #46
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I installed this right in the back of the center console for my backseat passengers: https://www.amazon.com/BlueFire-Charger-Socket-Outlet-Voltmeter/dp/B01F3I117E/
    It has a 5A circuit (inline fuse) powered by a relay in my breakout fuse box (engine compartment) that kicks on if the "INJ" circuit has power, which is tied to the ignition being on.
    This relay is on a 10A fuse and also powers a 12v3A converter (on a separate 5A circuit/inline fuse) that sits in my headliner and powers my dashcam that I have hooked to the gopro mount.
    I just finished this work this weekend but can document / take pictures / brainstorm if desired.
    JrcTacomaG3 and Plain Jane Taco like this.
  7. Nov 29, 2016 at 3:01 PM
    #47
    Plain Jane Taco
    USA
    I nearly went with that. But in the end I wanted the versatility of having both the USB ports and a conventional 12v port. My youngest daughter's Nintendo DS uses the regular port. She can just pull out the USB insert when she needs to use it.
  8. Oct 4, 2017 at 6:04 PM
    #48
    GreyInferno
    GreyInferno Member
    East Bay, California
    2016 Inferno TRD Sport Access Cab
    ARE Z-Series Black Tailgate lettering inserts Dog platform instead of jump seats Glove box decals from TacomaVinylDecals Flowmaster Exhaust LED interior lights
    Sorry to resurrect an old thread, but after some searching and not finding an answer this seemed like a good place to start - given the knowledge of the folks that have posted here.
    Does anyone know if there is a difference between the 12v socket in the dash vs the socket in the center console - AMP-wise? My phone tells me whether it is "Charging Slowly" "Charging" or "Charging Rapidly". I have a 12v to USB adapter that I use in my car, and the other day I noticed that I was "Charging Slowly" with the adapter plugged into the center console socket. I moved the adapter to the front socket and got "Charging"... I tested back and forth and got the same results. so it SEEMS like the center console puts out fewer amps than the front socket - even though they are both labeled 12VDC/120 Watts.
    Before I spend more time on this, or try a different adapter..... do any of you think this makes sense?
    Thanks!
  9. Oct 4, 2017 at 7:09 PM
    #49
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Makes sence in how you describe it, but when I had mine apart the other day I was sure they are wired in parallel, so the exact same wiring harness runs to both of them. That's going by memory, and it wasn't something I was really paying much attention to.
  10. Oct 4, 2017 at 7:11 PM
    #50
    GreyInferno
    GreyInferno Member
    Thanks @mutely It could very well be a quirk of the Anker adapter I have.
  11. Oct 4, 2017 at 7:18 PM
    #51
    mutely
    Those 12v cig adapters are really prone to losing power through bad fitment and dirt/junk in the socket. I'd try cleaning the female part with windex first, then rotating the charger in the socket while looking at the status of your phone before replacing it.
  12. Oct 4, 2017 at 7:25 PM
    #52
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    GreyInferno likes this.
  13. Oct 4, 2017 at 8:31 PM
    #53
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    He also has 5 cup holders, and 8 bottle holders too!
  14. Oct 4, 2017 at 8:34 PM
    #54
    OnHartung'sRoad
  15. Oct 4, 2017 at 10:49 PM
    #55
    jtmiller2011
    jtmiller2011 Well-Known Member
    2016 Toyota Tacoma Sport (Manual)
    Could you do that with a dash cam?
  16. Oct 4, 2017 at 11:04 PM
    #56
    OnHartung'sRoad
    Post #54 just above describes powering a dashcam using the mirror power as a source.
    jtmiller2011[QUOTED] likes this.
  17. Oct 4, 2017 at 11:17 PM
    #57
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Another yes you can. :thumbsup: I use my mirror power for my radar detector and the center console outlet for my dash cam.
  18. Oct 5, 2017 at 6:41 AM
    #58
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'm not sure how I feel about this.
  19. Oct 5, 2017 at 6:51 AM
    #59
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
  20. Oct 5, 2017 at 8:01 AM
    #60
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Most people don't like brcause of Aesthetics.
    I did not install it to look good, I installed it for work purposes.
    It works great for my battery chargers and my laptop and my cell phones and everything else that I plug into the damn thing
