Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 31, 2020 at 5:25 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    How is the brake fluid level and pedal feels? May be low on actual fluid or still have air in the system. Also check the conditions of the drums/parking brake switch, maybe it’s not fully releasing and parking brake switch that way doesn’t get signal correctly. If you have speed sensor damaged usually you would have abs light on with parking brake light same time.
    llamasmurf and 3JOH22A like this.
  2. Aug 31, 2020 at 6:03 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
  3. Aug 31, 2020 at 6:42 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    little North of Minden if no one knows where it is.
    thanks for the share!
    RoamingGnome and Manfred[QUOTED] like this.
  4. Aug 31, 2020 at 6:42 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Abs is on at all times as I have a kill switch installed. Bled all brake lines. Where is the parking brake switch located? I'll be replacing the speed sensor tonight hopefully.
    llamasmurf and tacoma16[OP] like this.
  5. Aug 31, 2020 at 8:12 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Im thinking he means the adjustment screw in the brake drum? I doubt it would be that though and most likely a sensor as you mentioned.
  6. Aug 31, 2020 at 9:09 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Snail81 likes this.
  7. Aug 31, 2020 at 9:25 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Atlas86 and Manfred like this.
  8. Aug 31, 2020 at 9:40 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    If you havent ordered them yet im in on a 2nd gen kit as well
  9. Aug 31, 2020 at 9:42 AM
    Windigo
    Farook
    '14 Acess Cab
    I messed up hear. o_O
    tacoma16[OP] likes this.
  10. Aug 31, 2020 at 9:46 AM
    Windigo
    Farook
    '14 Acess Cab
  11. Aug 31, 2020 at 10:04 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    cant say for sure but hopefully @Manfred can chime in. This thread discusses it.
    https://www.tacomaworld.com/threads/how-to-snorkel-on-a-budget-tips-and-advice.391755/
    this also may be helpful to determine the proper year hilux and some other odds and ends.
    https://www.tacomaworld.com/threads/snorkel-installation-2nd-gen-ss135mod-1st-gen-ss170hf.141141/
    not sure if you know of a cowling snorkel. Also a good option depending how deep you plan on going.
    https://www.tacomaworld.com/threads/cowl-induction-snorkel.525314/
    Windigo[QUOTED] likes this.
  12. Aug 31, 2020 at 10:14 AM
    Windigo
    Farook
    '14 Acess Cab
    Thank you for the links.
    My internet time is up so tomorrow again I'll revisit this.
    Manfred and tacoma16[QUOTED][OP] like this.
  13. Aug 31, 2020 at 1:06 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Send me a pm I'll be able to help later tonight when I've got some free time
    tacoma16[QUOTED][OP] likes this.
  14. Aug 31, 2020 at 1:11 PM
    Norilsk
    Eugene
    I can’t remember where exactly on second gen with the pedal e-brake, but there is a actual switch that sends signal near there that may be simply stuck
    Thyces and tacoma16[QUOTED][OP] like this.
  15. Aug 31, 2020 at 1:35 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'll do some gooooogler
  16. Aug 31, 2020 at 2:18 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's right behind the pedal (see 04300310.pdf), secured with a single screw. Might be a victim of submersion years earlier. :laugh:
    tacoma16[OP], Norilsk and llamasmurf like this.
  17. Aug 31, 2020 at 3:57 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    Snorkel Air Intake For Toyota HiLux Diesel 1997-2005 165 167 172 Series Right
    Item price C $110.81
    that's the one we got. Bought it sometime last year.
    This should be it.
    https://www.ebay.ca/itm/Snorkel-Kit...-models-LHS-/132841718001?hash=item1eedfbc0f1
  18. Aug 31, 2020 at 4:05 PM
    Atlas86
    Ontario
    Me too! If not too late
  19. Aug 31, 2020 at 5:19 PM
    Norilsk
    Eugene
  20. Aug 31, 2020 at 5:21 PM
    Emanresu
    Emanresu Well-Known Member
    Good to go. Send your info and I can e transfer or whatever.
    Norilsk[QUOTED] likes this.
