Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 24, 2021 at 7:37 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    but what rubber do you have? Cooper ST Maxxes, Falcon wildpeaks?
    there really isn't a "cheap" option that i can see that resolves this, but a simple one would be invest into new rims of some sort.
    IIRC these are the 16s i run which are 16x8 with -12mm
    https://www.4wheelparts.ca/p/pro-co...ttern-flat-black-7069-6883/_/R-BKBQ-7069-6883
    and these would be the 17s but are 17x9 with -6mm offset
    https://www.4wheelparts.ca/p/pro-co...ttern-flat-black-7069-7983/_/R-BKBQ-7069-7983 (damn they got pricey... i paid a $130 per rim for mine...)
  2. Aug 24, 2021 at 7:39 AM
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
    I think some 10mm spacers would be cheaper. :rofl:
    somebody likes this.
  3. Aug 24, 2021 at 7:41 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    yeah that'll work too
  4. Aug 24, 2021 at 7:43 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Hell yes! Probably going to go 2.0s 13x650lb with dobinsons leaf packs. really hoping i can stay closer to 1.5-1.75" lift with the setup, maybe remove a leaf if I have to.
    more offset would help for sure. eventually when my winters EOL i will transfer my summers to those rims which are +10. part of me wants to keep the tucked offset for stone chips.
    Snail81 and TacooSaucee[QUOTED] like this.
  5. Aug 24, 2021 at 7:44 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    :bananadance::dancingbacon::broccoli::kona:
  6. Aug 24, 2021 at 7:53 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    running 255/75/17 LT C Firestone Destination XT. They measure 32" bang on. I would not say that the rubbing is a normal use case occurrence as I have never seen this from (many)other times I have bottomed out, just this one occurrence that was severe enough to mess my alignment.
    tacoma16[OP] and Shveet[QUOTED] like this.
  7. Aug 24, 2021 at 7:58 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    It looks like you have lots of clearance as it is though(judging by the pic) so my thoughts would be wheel bearing/ball joint/bushings for your wheel to be able to push in that far to be able to touch
  8. Aug 24, 2021 at 8:01 AM
    Downytide
    Downytide Well-Known Member
    21 Tundra TRD Pro
    LT headers, 5.29s, Magnuson
    All these tires talk make me start browsing again................
    and damn 37s look decent on stock BBS, my spacers just came in today to.
    https://youtu.be/JXobsSYoh9I
  9. Aug 24, 2021 at 8:03 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Its about 1 1/4" clearance. Under the binding loads and fully compressed geo (i believe it goes into -ve camber) of a full hard stop bottom out it seems reasonable that the bushings and other parts would flex enough to allow this.
  10. Aug 24, 2021 at 8:32 AM
    tgelata
    Probably at work.
    Try jacking your truck up and checking clearance lock to lock at full droop.
    somebody[QUOTED] likes this.
  11. Aug 24, 2021 at 8:39 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    The less offset you have the more it pushes the wheel out. So if you go from a 30+ to a 20+ You’ll be gaining 1cm of clearance.
    as you said it will affect stone chips and how dirty everything gets. Running -38 here and the truck gets terrible.
  12. Aug 24, 2021 at 8:49 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    further to add my experience,
    the -12mm i have is still fairly ok in our wheel wells. the tread itself is within the wheel well but with the cooper ST MAXXes, just the sidewall finds itself outside of limits of the truck.
    i dont have that exact angle, but you can see it in the front here; upload_2021-8-24_11-49-33.jpg
    with that said next time i get new rims, i don't see myself getting anything beyond -12. most likely anything between 0 to -10mm
  13. Aug 24, 2021 at 8:51 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Essentially why 255/85r16 is perfect on stock rim
    Snail81, tacoma16[OP] and Shveet like this.
  14. Aug 24, 2021 at 8:52 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  15. Aug 24, 2021 at 8:53 AM
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Shveet[QUOTED] likes this.
  16. Aug 24, 2021 at 8:56 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah and backspacing plays a roll too. 3.5” here
  17. Aug 24, 2021 at 9:22 AM
    tgelata
    Probably at work.
    Trade me. Our tires measure the same anyways
    i want to live that thicc life :drool:
  18. Aug 24, 2021 at 9:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    So stop worrying about it. :)
    As a point of reference, my 265/75-16 Goodyear Duratracs rubbed the paint off the SPC UCAs at some point in the suspension cycle, this is with normal alignment. I had 2nd gen factory TRD OR wheels with +32mm offset. Your 255-wide tires just rubbed slightly less often. The high offset wheels are simply marginal with 32" tires.
    Shveet, Snail81 and somebody[QUOTED] like this.
  19. Aug 24, 2021 at 9:53 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    I was really just surprised rather than worried. wanted to put that data point out there as well.
    3JOH22A[QUOTED] likes this.
  20. Aug 24, 2021 at 10:10 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Lol can’t do it! Even though the dirt sucks, I’m all about that thick life.
    Snail81, Shveet and tgelata[QUOTED] like this.
