Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Nov 6, 2021 at 7:42 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    well with a 3" block lift, why do you want to swap to something 2.5? do you plan on taking it to Ardbef in the spring with us?
    19Canuck[QUOTED] likes this.
  2. Nov 6, 2021 at 7:45 PM
    19Canuck
    19Canuck DILLIGAF specialist
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Running a 265/70/17 on a 0 offset...might want to move to a 275/70 on the same rim...nothing huge.
    I can get away without UCA's as I can drop from 3 to 2.5..fucked up as UCA's are almost the same price as coilovers.
  3. Nov 6, 2021 at 7:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    $45,000 Canuckistikian pesos is aboot $16 U.S.
    Shveet[QUOTED] and 19Canuck like this.
  4. Nov 6, 2021 at 7:48 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    yes I do!
    Shveet[QUOTED] likes this.
  5. Nov 6, 2021 at 7:49 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Aboot! Lmao
    Steves104x4[QUOTED] likes this.
  6. Nov 6, 2021 at 7:49 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  7. Nov 6, 2021 at 7:52 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Im thinking 6112's with some Toytec springs. From the US they are around 7 bucks..900 here... lol.
  8. Nov 6, 2021 at 8:05 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    well you're in luck! I can save you a bunch of money (or spend it depending on damages)
    you can run all of south trail with a stock truck! Trust me we saw 4 Subie foresters do it!
    so you might not need UCAs at all (since all they really are for is to move the tire forward) if you upgrade to 32s.
    you can fit 255/80/17s (33s) on a 0 offset rim IIRC without a CMC. you wont have front mudflaps but it might just touch/ rub the paint.
    Come join the pizza cutter gang!
    https://adventuretaco.com/guide/what-size-tires-fit-my-lifted-tacoma/
    Anyways. with 32s and 33s you'll be banging your pinch weld harder than your ex back in high school. was it necessary? not really, but it really does make a huge difference.
    so that really leaves you to finding something fairly cheap for the front. if you're upgrading from the stock Billies, then *anything* will feel better. I have my foxes because @tacoma16 found them dirt cheap on fartbook and i jumped on the deal :notsure:
    Seriously that was the deciding factor after 6 months of reasearch. dirt cheap? my new best friend is fox.
  9. Nov 6, 2021 at 8:11 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    go for that then!
  10. Nov 6, 2021 at 8:23 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    The 275/70's would be the next set I get..My Dynapro Mt's have tons of meat left on them. Great tire well mannered on the road and great off road. I will buy another set hands down...so that 265/70 size does fantastic right now for me. I have a set of winters so they will last quite a while.
    ontarioyota likes this.
  11. Nov 6, 2021 at 8:34 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    When ever these "shock" disscussions come up I find my self looking for a 5100 upgrade they when I look at the price...... :oops: Oops! what was I thinking :):)
    Shveet and 19Canuck like this.
  12. Nov 6, 2021 at 8:35 PM
    19Canuck
    Richie
    London Ont
    2024 OR DCSB
    ummm .....ya.
    Running 5100's on the rear.
    Shveet likes this.
  13. Nov 6, 2021 at 8:38 PM
    Windigo
    Farook
    '14 Acess Cab
    I beat on them pretty good. There nothing special but available, durable with our winters and the price is good for what it can do.
    Shveet likes this.
  14. Nov 6, 2021 at 8:41 PM
    Windigo
    Farook
    '14 Acess Cab
  15. Nov 6, 2021 at 8:46 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    Shveet likes this.
  16. Nov 7, 2021 at 3:19 AM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I run 6112's and they perform really well. You wouldn't need to get springs unless you wanted to change the spring rate. The spring it comes with is 620lbs if I'm not mistaken. It's the same 2.5 like Fox, etc..., and it's almost half the price. Only drawback is once you set the perch height for the spring you can't change it unless you remove the shock or somehow compress the spring on the vehicle.
    3JOH22A likes this.
  17. Nov 7, 2021 at 6:39 AM
    ODSC1
    London ON
    2017 DCSB Sport MT
    Do you have any problem with rust or salt corrosion on the 6112's? What do you run on the back? 5160's?
    Tridet167[QUOTED] likes this.
  18. Nov 7, 2021 at 6:54 AM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Found some data! CO is the biggest reduction in the second cat. HC (which is the unburnt gas or rotten egg smell) is second in line. This may be noticeable in odour but really have no clue as to what % change would be discernable.
    Source Paper Here
    ToyotaRacingDev and Shveet like this.
  19. Nov 7, 2021 at 7:06 AM
    Tridet167
    Tony
    Toronto, Canada
    ODSC1[QUOTED] likes this.
  20. Nov 7, 2021 at 10:16 AM
    Tridet167
    Tony
    Toronto, Canada
