Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 2, 2019 at 9:00 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    You can try to take your vehicle to Toyota dealer, you might be qualified for a brand new frame.
    About overheating your differentials, I can't even imagine what you will need to do with the truck to get it to that point. You must be thinking about transmission overheat, but that's also a rare case. Make sure to drive in 4HI once a month to lubricate all gears, you can just drive around your neighbourhood in straight line for that.
    Do the rear differential mod if you plan on watercrossings: https://www.tacomaworld.com/threads/my-differential-breather-mod-photos.111954/
    Don't forget to lubricate your u-joints (5 in total) and you shall be fine. There are plenty of things on this forum that will teach you how to maintain truck, just keep reading.
  2. Jan 2, 2019 at 9:06 PM
    ToyotaRacingDev
    ToyotaRacingDev 425,000km
    London, Ontario
    2008 Tacoma TRD Sport
    I’ve had it inspected twice by Toyota and denied both times, very disappointing because the frame is the biggest thing holding back the longevity of the truck. They are very strict about that there needs to be penetration. My motor mounts are very rusted out, I have some pics in a thread I made about Toyota denying my frame here
    https://www.tacomaworld.com/threads/toyota-refuses-to-replace-my-frame.581934/
    I was quoted $800+ for someone to sandblast the frame and repaint it. I don’t have the money for that, I’d love to do it myself but I don’t have a garage or the tools for that. It would be a drill wire wheel and spray paint would be the best I could do on my budget
    That’s good advice on lubricating the gears, I will make sure to do that. I’ve started adding small amounts of Lucas oil stabilizer when doing oil changes to try and help out the lubrication of gears in my engine. Do I need to remove the tires to get to the ujoint ? I what should I lubricate with
  3. Jan 2, 2019 at 9:09 PM
    Norilsk
    Eugene
    Ah, damn, bad luck :annoyed:. Well, keep an eye on the frame.
    For the u-joints you will need to purchase grease gun with long extension, no need to take tires off, just crawl under your truck: https://www.tacomaworld.com/threads/check-your-u-joints.409042/
  4. Jan 2, 2019 at 9:14 PM
    ToyotaRacingDev
    London, Ontario
    Thank you very much for the link, I might give it a try tomorrow. Is there any other maintenance you’d recommend on a 300,000km truck
  5. Jan 2, 2019 at 11:04 PM
    Norilsk
    Eugene
    Spark plugs, replace with OEM
    Change Front/Rear/T-Case fluids
    AT transmission flush and refill
    Replace water pump, drain coolant, refill.
    bleed brake fluid, refill
    visually inspect CV shaft for any damage, oil leaks.
    Check your upper/lower control arm bushings
    Check your callipers, all pistons must freely move
    take a look at your break lines, ensure they are not totally rusted
    that' just from the top of my head, there could be more things that needs to be done/checked at this milage, others can chime in.
  6. Jan 3, 2019 at 3:11 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I’ll add the poll
    For the hitch, have you tried a torch and big hammer? I know what you mean about working outside. For the most part I have done most of the work outside in the cold. Don’t know the situation, but sometimes a cheap gazebo from Walmart can atleast keep you out of the rain and what not.
    As long as the frame is solid, you still have anywhere from 100k to another 300k left on that truck if not more.
    As for the rust, if Toyota sprays it with there rubberized coating the frame will eventually fail. With the frame replacement they do go through the truck (since they are literally taking everything off) so they do find some parts for replacing. Some come free. Some on the other hand you have to pay. I know @NeonHeights had a rough go with his, where other have had a smooth swap. All depends on the dealer.
    These links may help https://www.tacomaworld.com/threads/scheduled-maintenance-2nd-gen-30-000-60-000-90-000-miles.30893/
    Manuals and diagrams
    https://www.customtacos.com/tech.old/files/05FSM/repair.html
    For parts (stock replacements)
    https://www.thewrenchmonkey.ca/
    -just be careful for instance as I ordered a rear brake cylinder. Because I ordered the wrong one I would have had to pay the stocking fee which was worth more than the part. Only have had one issue though.
  7. Jan 3, 2019 at 3:26 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I find the RTT a bit over rated. There's pros and cons to it, but there's some 'pros' I always hear that are not pros at all like it's safer from animals.
    You can get to the camp sites up in Ardbeg perry sound area no problem and then do whatever you're comfortable with.
    And you can do these trails stock if you're careful just can't have fun on the off shoots.
    Or just be crazy Russian. @Norilsk is pretty much stock and does a lot
  8. Jan 3, 2019 at 3:28 AM
    Joe23
    You would sooner over heat your transmission than the diff.
    4lo is your friend for keeping stuff cool
  9. Jan 3, 2019 at 4:18 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    OF4WD $100 group charge splitting list-->Just posting this as an easier way for everyone to keep track. You can see if I have gotten the email of your transfer since I won't be accepting them until I get everyones.
    1. @tacoma16- PAID
    2. @Tridet167-->Paid
    3. @llamasmurf-Paid
    4. @weight- PAID
    5. @Toms2Yotas
    6. @TeecoTaco Paid
    7. @Norilsk -PAId (pennies don't count asshole:luvya:)
    8. @pete37-->Paid
    9. @honkonbobo-->PAID
    10. @Atlas86-->PAID
    11. @cwisema-->PAID
    12. @Sloweburn -->Paid
    13. @Taco-Bell-->PAID
    14. @Therby--> PAID
    15. @ODSC1-->PAID
    16. @Shveet -->PAID
    17. @sorgon82-->Paid
    18. @Canadian Joe-->PAID
    19. @Manfred--> PAID
    20 @Lumberjackcoma-->PAID
    21. @Ares
    22. @Zulupapa -->PAID
    23. @Bocsy44-->PAID
    21 paid
    Updated
    For those that are coming in after the 20 people. I am still doing the $5 fee that we all had to pay. What ever money I get over the $100 group charge I will donate towards the OF4WD. Next year when we do this again. We will try and get everyone on board earlier so we can get the biggest discount.
    Hey everyone, Not too worried about a timeline. I know some of you have sent the e-transfer but it hasn't come through on my end yet. Sometimes they take a long time, other times they come right in. I have updated the list. We are almost there. Considering I started collecting yesterday, almost everyone has paid which is awesome and super quick. I understand some banks are slow from the new years and some people are back to work/family stuff. I figured by the weekend we should be all good.
    I have accepted e-transfers. We are all setup so I just have to send an email out once I get the rest of the transfers (we did pretty good for a day).
    Taco-Bell and pete37 like this.
  10. Jan 3, 2019 at 6:30 AM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    I’m down to go to the wing meet if we get a solid when and where. I’m coming from Waterdown area so I’d prefer not to rip far but have wings will travel :rofl:
    Joe23, Shveet and tacoma16[OP] like this.
  11. Jan 3, 2019 at 7:20 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Poll added to the first page for where to have the wing night on the 26 of January
    Taco-Bell likes this.
  12. Jan 3, 2019 at 8:00 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    So I’m a huge idiot lol :facepalm:
    Left my gas cap on the sidestep of my truck while I was filling at a gas station up in Belleville yesterday...
    She not there anymore :rofl:
    Got the old $12 NAPA Pre-Vent special so hopefully it’s good.
    Tridet167 and llamasmurf like this.
  13. Jan 3, 2019 at 8:04 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Taco-Bell[QUOTED] likes this.
  14. Jan 3, 2019 at 8:06 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    gas cap at my work Creditstone Auto Parts 7.73 plus tax in stock
  15. Jan 3, 2019 at 8:26 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    That’s awesome but it won’t work on my first gen cause I got the lock mechanism there. Gonna rig something up to hang it off of with some scrap 1mm sheet metal I have
    Good deal, ran down to my local NAPA and just got the $12 Pre-Vent one. Haven’t had a light yet. Come to think of it I didn’t even throw a code the whole way back from Belleville to Waterdown without a gas cap...
  16. Jan 3, 2019 at 8:42 AM
    llamasmurf
    Wes
    Northern Ontario
    My bad I missed the year of your rig in your info there!
  17. Jan 3, 2019 at 9:28 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    1. @tacoma16- PAID
    3. @llamasmurf-Paid
    4. @weight- PAID
    5. @Toms2Yotas
    6. @TeecoTaco Paid
    8. @pete37-->Paid
    10. @Atlas86-->PAID
    11. @cwisema-->PAID
    14. @Therby--> PAID
    15. @ODSC1-->PAID
    16. @Shveet -->PAID
    21. @Arespaid
    23. @Bocsy44—>Paid
    20 paid
    Updated
  18. Jan 3, 2019 at 11:05 AM
    Zulupapa
    Zulupapa Bah-Weep-Gragnah Weep Ni Ni Bong
    Waterloo Region Canada
    2017 Tacoma TRD Sport Inferno
    No Challenge Coins?? BAH!
    the excellence of Me-So Customs! :)
  19. Jan 3, 2019 at 11:23 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The CEL could require two trips to set, depending on each vehicle's ECM logic.
    Since you have a locking gas door (lower vandalism risk), you can try an InStant-Fill cap with a flapper. No need to remove the cap to refuel at the pump. Remove the cap to use a jerrycan. Been running one on my Subaru for a couple of years, no issues.
  20. Jan 3, 2019 at 11:39 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I redid the poll because I copied and pasted incorrectly.....Cant create polls on your phone very accurately. All fixed.
