Ontario - Sorry aboot the B.S. eh!
Discussion in 'Ontario, Canada' started by bert8, Sep 21, 2015.
  1. Mar 7, 2017 at 6:29 PM
    #541
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    Kemosabe likes this.
  2. Mar 8, 2017 at 2:28 AM
    #542
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Bocsy44[QUOTED] likes this.
  3. Mar 8, 2017 at 2:30 AM
    #543
    Kemosabe
    Louis
    Thanks, The more I read and the more I think ome should be the way to go for me. Were you able to do the install yourself?
  4. Mar 8, 2017 at 3:10 AM
    #544
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Because it was winter, and my garage is not heated I got them to do it. Plus at the time I wasn't too confident in my ability. Did the rear suspension over again in the summer and it wasn't too bad.
    Really the only issue with OME is choosing the proper spring up front. It's hard to plan long term, if the weight on the front end is going to change. I did the front bumper and the lift at the same time for that reason.
  5. Mar 8, 2017 at 6:22 AM
    #545
    Kemosabe
    Louis
    Thanks! I will have to search since I have the 2.7L wich is lighter. And I don't plan a front bumper but we never know... haha
  6. Mar 8, 2017 at 7:36 AM
    #546
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Maybe bilisteins maybe the better option. Can choose a coil and preload down the road if ya need to.
    Kemosabe[QUOTED] likes this.
  7. Mar 8, 2017 at 10:12 AM
    #547
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Almost 40 years ago (I was 7) my fathers company built the water treatment plant in Armstrong. I was the head gopher bringing tools and whatever to the guys. It is a different life up there.
    BohlaaH[QUOTED] likes this.
  8. Mar 8, 2017 at 1:17 PM
    #548
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    joe.trd
  9. Mar 8, 2017 at 1:24 PM
    #549
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Kemosabe and Joe23 like this.
  10. Mar 8, 2017 at 3:02 PM
    #550
    Kemosabe
    Louis
    I'm always debating on full ome or billies in front and dakars in back with whatever the shocks that fit... I want something good that will last, I know I will have my truck for another 3 years, then will have to upgrade for something with 4doors lol, by this time I will know if I am able to have 2 ride (I hope so). If I get something great it could be swap on the futur ride haha
  11. Mar 8, 2017 at 3:06 PM
    #551
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Gotcha. Well the dakars out back are a go regardless. They can be paired with extended billies (if that's the route you want to go) or run with the OME's.
    For the front, either will work. The only reason I didn't go with billies, was I didn't want to preload the shocks with that much weight, as it would affect the ride. Some guys run the billies with the stock shocks preloaded and they are happy. Billies are definitely more flexible in terms of adjustment. OME is a set it and forget it unless you change coils.
  12. Mar 8, 2017 at 3:21 PM
    #552
    Kemosabe
    Louis
    I would rather get the best ride possible with the wanted lift than compressed the coil like I have now (spacer) and feel like in a can lol! I might go with full ome when the time comes. Are you able to give me an average price for the lift without install? Even of I am set on it it might play in the decision lol I already know that bilstein are not cheap here like they are in the USA... so if ome is a little over I'll get it.
    tacoma16[QUOTED] likes this.
  13. Mar 8, 2017 at 3:26 PM
    #553
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Your ride is going to be way better than spacers regardless of what lift, based on what I have read from people going from spacers to either lift.
    I'll have to get back to you on the price, don't recall off hand.
  14. Mar 8, 2017 at 3:29 PM
    #554
    Kemosabe
    Louis
    Thanks! Spacers are a cheap way to lift and to get the look but damn why give a hit like this on the comfort! I still think my taco is comfy but beside others I see that it is not the best lol
  15. Mar 8, 2017 at 4:04 PM
    #555
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Yeah I'm assuming that was when it was a military radar base? It's mostly just a reserve and railway town now. I worked for CN, that's why I was up there. Very interesting to know you've seen it there, most people would have no idea what it's like.
  16. Mar 8, 2017 at 6:38 PM
    #556
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Pm in bound on the price
  17. Mar 8, 2017 at 6:40 PM
    #557
    Kemosabe
    Louis
    Thanks for the info! Were uca really needed for the loft provided by the ome?
  18. Mar 8, 2017 at 6:43 PM
    #558
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Some have gotten away with it, while others needed it for the alignment. I didn't take any chances and got them on a group buy. Figured do it all at once. I went with light racing. Fully sealed ball joint instead of a uniball. Better for our winters but not so me travel in comparison.
  19. Mar 8, 2017 at 7:00 PM
    #559
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    x2 on the LR UCA haha that's what I will be going with for sure, plus the fact they are adjustable is pretty sweet! saw a thread on here with some really good info about it but silly me didn't save the link lol something about adjusting the LCA as much as possible with the UCA set to 2 degrees before making UCA adjustment to maximize tire clearance. something along those lines, even had a nice video of how to adjust them.
    Kemosabe and tacoma16 like this.
  20. Mar 8, 2017 at 7:01 PM
    #560
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    This lol
