Ontario Truck Builds/Tech Discussion
Discussion in 'Ontario, Canada' started by tacoma16, Apr 18, 2021.
  1. Jul 28, 2021 at 7:47 AM
    #81
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    No worries.
    https://www.tacomaworld.com/threads...lacement-2005-tacoma-4x4-the-easy-way.437693/
    I have a spare set of lowers if you need more time to do this. Can replace them on my spares instead of having the truck down for so long. I’m sure you have some heavy duty presses at work though. I struggled with my ten ton to press out the rusted bushings on the spare set I had.
    my current spares had the bushings done a while ago so shouldn’t be rusted in too bad.
    Windigo[QUOTED] likes this.
  2. Jul 28, 2021 at 8:10 AM
    #82
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Thank you I'm just gonna order the one from the link
    tacoma16[OP] likes this.
  3. Jul 28, 2021 at 8:31 AM
    #83
    jordi992
    jordi992 Skidplates reduce clearance
    Jordan
    Burlington, ON
    Red truck
    Light bars, no lockers
    +1 for whitelines over the Energy suspension bushings.
    llamasmurf, tacoma16[OP] and Windigo like this.
  4. Jul 28, 2021 at 9:34 AM
    #84
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    llamasmurf and tacoma16[OP] like this.
  5. Jul 28, 2021 at 10:45 AM
    #85
    Windigo
    Farook
    '14 Acess Cab
    tacoma16[QUOTED][OP] likes this.
  6. Jul 28, 2021 at 11:23 AM
    #86
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m just using moog. I know @Norilsk has a better brand which is 868 or something like that.
  7. Jul 28, 2021 at 3:58 PM
    #87
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
  8. Jul 29, 2021 at 8:52 PM
    #88
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Does anyone know if a 2nd Gen topper can be put on a 3rd gen? I'm lookin for a cheap topper (any condition) to start a build.
  9. Jul 30, 2021 at 8:22 AM
    #89
    Downytide
    Downytide Well-Known Member
    21 Tundra TRD Pro
    LT headers, 5.29s, Magnuson
    I recall 3rd gen tailgate height and gap is different, it may bolt on but it will not sit flush.
    on a side note, anyone had used heim join dust boots on Icon billet UCAs?
  10. Jul 30, 2021 at 5:37 PM
    #90
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I will assume other toppers follow the same specs but I know the 2nd gen softopper fits length and width but is taller because the bed sides are shorter.
    tacoma16[OP] and llamasmurf like this.
  11. Aug 2, 2021 at 2:40 PM
    #91
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Gotcha. Bonus height! Lol. It seems impossible to find a used topper regardless.
  12. Aug 2, 2021 at 5:06 PM
    #92
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I used to run a 2nd gen Toyota accessory trifold tonneau converted to fit my 3rd gen.
    • The 2nd gen headboard and tailgate are ~3/4" lower than the bedside caps. If the topper accounts for this using large bulb seals, then you can simply replace the seal with thinner weatherstripping from Amazon. If the topper accounts for this using extra fiberglass in front or longer hatch glass, then it won't be practical to convert. You can remove the square tube on the headboard to get the profile closer to the 2nd gens, but there isn't much you can do at the tailgate.
    • Because the 3rd gen bedsides are higher, the utility rails are farther from the bedside caps, which means you may need new clamps if the existing clamps don't have enough jaw capacity.
    • If the topper roof was designed to be flush with the 2nd gen roof, it will be higher than the 3rd gen roof as Saturnine indicated.
  13. Aug 2, 2021 at 6:05 PM
    #93
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Sweet write up. Thanks!
  14. Aug 7, 2021 at 5:34 PM
    #94
    Windigo
    Farook
    '14 Acess Cab
  15. Aug 10, 2021 at 6:45 AM
    #95
    4runner.mike
    4runner.mike Member
    2016 silver 4runner Sr5
  16. Aug 10, 2021 at 6:52 AM
    #96
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    added!
  17. Aug 10, 2021 at 6:53 AM
    #97
    4runner.mike
    4runner.mike Member
    Thanks
  18. Aug 13, 2021 at 4:17 AM
    #98
    Windigo
    Farook
    '14 Acess Cab
    dose anyone know if the Lower front shock bushing that comes stock with our tacoma's are the same dimensions as the ones that come on the bilstien 5100's.
    edit: there the same bushings according to wheelers offroad.
    Shveet and llamasmurf like this.
  19. Aug 25, 2021 at 11:01 AM
    #99
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Holy shit, I just learned the wait for new TRD PRO ucas (2022). 6-8 months.
    llamasmurf likes this.
  20. Aug 25, 2021 at 11:04 AM
    #100
    Saturnine
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Makes sense. The trucks aren't even out yet.
