open diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtaco, Sep 19, 2008.
  1. Sep 19, 2008 at 8:19 PM
    jtaco
    jtaco [OP] Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    someone please correct me if im wrong. is 4 wheel drive considered open differential?
    see i only have 4 wheel drive. i got stuck the other day, front end just sunk basically, left wheel was in water, and rt wheel was in mud. so ,, the left just spun like crazy and i got no where. would rear limited slip have gotten me out of this or what ? i dont want to go the 800 dollar arb air locker route if i dont have to. why does everyone want limited slip on rear when the front end of these trucks are soo heavy???
  2. Sep 19, 2008 at 8:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Sep 19, 2008 at 8:35 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Damn that was a quick reply. And a very nice explanation.
  4. Sep 19, 2008 at 8:38 PM
    jtaco
    yea rt anyways, ok so what is the difference in open diff and 4wheel drive? wow that link is some deep shit.lol
    so i take it that 4 wheel drive means that both front wheels are spinning at same speed regardless? and open diff, the one that has less tourque slows down and the other one gets more power? if this is the case, then what good is open diff to anyone anywhere anytime?
  5. Sep 19, 2008 at 8:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
  6. Sep 19, 2008 at 8:44 PM
    jtaco
    or that we never came down..lol
  7. Sep 19, 2008 at 8:46 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    jtaco I am not certain about all of our trucks but I would assume that most of the 4x4 come with the LSD rears, however I don't know about the front diff most likely open. I make that assumption because alot of people talk about getting the air lockers. However I may be wrong.
  8. Sep 19, 2008 at 8:49 PM
    jtaco
    yea i just dont want to have to go that mad money route on those arb air lockers.. God this shit gets to be expensive.
    see i found a place that will sell me the whole limited slip diffs with switch and wireing and all for my tacoma for 700 even. then i gotta find someone to install . but is this what i need?
  9. Sep 19, 2008 at 9:02 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    What are your plans for your vehicle? Serious offroading? Mainly road but some trails?
    If you still have a few questions check this out. question about 4x4 and locking differential
    all post are good but I like 16 it gives a good explanation.
  10. Sep 19, 2008 at 9:05 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    The rear limited slip would have helped but hard to say if it would have gotten you out, It may have prevented you from going slow enough to get stuck. The momentum may have carried you through.
  11. Sep 19, 2008 at 9:07 PM
    jtaco
    see i went through it fine first time, but comin back it was to steep. then front end just sunk the more i tried to go through it, it would not back out either and the rear tires where on land, well, damp land and higher then front end. i just go offroading to fish and stuff. i dont go around lookin for mud holes or anything.
    see i was told by terry at allpro that 4 wheel drive means u only have 2 wheels really spinning. like say if 2 wheels are off the ground , then those are the only ones going to spin and u are stuck .but that sounds crazy to me.. the link u posted just takes me to homepg here. but me getting stuck , i put it in low 4, and the left front spun like crazy and the rt did not budge. i dunno if its because rt was too deep in the mud or what is going on here?was terry rt? why wouldnt the rear pull me out back? would lockers on front helped?
  12. Sep 19, 2008 at 9:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have a basic 4x4 and my rear is always posi. I have never had just one tire spin no matter what I have done to her. However I haven't done any thing to the front and assume that it is open. I purchased my truck new and it didn't mention anything about an LSD or locking diff. I would think that for what you do having an LSD rear would be fine just pick good lines and drive smart. It is a lot of money to get the Air locker installed if you will hardly ever need it.
  13. Sep 19, 2008 at 9:18 PM
    jtaco
    yea around 800 then a compressor and whatever else i need to make it work , then labor for someone then that someone that knows what they are doing or is honest when they claim they know what they are doing. so u think our trucks are open in front until switched to 4 wheel drive?well that explains why left spun like crazy then and rt did nothing. that sux cause i had it in low4. what a jipp. i dont understand why everyone wants limited slip on the rear when these trucks are so heavy up front. so u think my best bet would've been to have limited slip in rear , that comes on the trd models? or lockers up front or limited slip up front?
  14. Sep 19, 2008 at 9:24 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    To be honest I am still have questions about that. Here is what I think. When our trucks are in 2wd the front is turning but has no tq applied to it. When we engage 4wd the front end gets 50% of the avaliable power. This is when the front wheels start to pull but is open.
  15. Sep 19, 2008 at 9:28 PM
    jtaco
    well i do know this, if in 4 wheel drive, and i take a sharp turn , the wheel locks up almost and jerks. if it were open it wouldnt do that. but then im confused as to why my trucks rt did not get any power. maybe it was just too stuck. then i've been told by everyone i see, that if u have a 4 wheel drive then something is always turning in there even when 4w4 not engaged.or something like that . and trust me , i picked the best route , any other one and no one else could've had a chance at savin me. shit where i was, i had to get a huge tow truck come as far as he could in the woods, then let out his whole winch then daisy chain a few chain links to reach me.
  16. Sep 19, 2008 at 9:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    If your interested in faster conversation go here it is TW's chat site. Join up we all use our TW screen names. http://www.chatzy.com
    I know what you mean about the front end pulling but being open would still do that. Its jerking because the rear wheels are pushing forward and the front is pulling hard to the right of left and trying not to slide. If you turn hard in the rocks your rear tires will push you forward and you will barley be able to turn.
  17. Sep 19, 2008 at 9:37 PM
    jtaco
    i gotta go now, i will tom , thanks for the insights, i gotta think about this, and see what would be best for me to get. i just cant tell rt now. lockers, limited slip? rear , front or both or what?
  18. Sep 19, 2008 at 9:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    lol I know the feeling take it easy man and good luck. I hate making those kinda decisions.
  19. Sep 20, 2008 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The differentials on the base trucks are open front and rear. When in 4 wheel drive, the transfer case locks the front and rear drive train together, thus the binding when turning in 4x4. Since the front end follows a different arc than the rear when turning. Its not recomended to be in 4x4 when on pavement. Furthermore, when in 4 wheel drive with open diffs, when one tire looses traction, it will spin, and the other tire with traction will loose torque. An open diff only supplies equal power when driveing straight and both tires have equal traction. You can learn to modulate your brakes to get power to all tires when traction is low. This makes you a better driver off road, but takes time to learn. Another option is to have a "lock right" locker installed in your rear diff.
    http://www.4x4wire.com/reviews/d44lockright/
    They are an automatic type locker and work quite well, thought they have some unique street characteristics. They are not recomended for front diff aplications.
  20. Sep 20, 2008 at 6:28 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You worded that so much better than I could. Thanks Chris.
