open door beeper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sr5boy, Sep 3, 2008.
  1. Sep 3, 2008 at 3:14 PM
    sr5boy
    sr5boy [OP] Well-Known Member
    tallahassee florida
    06 tacoma 4x4
    demudflapped, debadged, relocated the 7-pin, 3'' fatbobs garage lift in front
    Anyone know how disable the open door beeper on a 06?
  2. Sep 3, 2008 at 3:16 PM
    natrlyst
    natrlyst Well-Known Member
    close it
  3. Sep 3, 2008 at 3:20 PM
    sr5boy
    tallahassee florida
    06 tacoma 4x4
    i thought about that
  4. Sep 3, 2008 at 3:33 PM
    natrlyst
    sorry i couldnt resist...:)
  5. Sep 3, 2008 at 4:16 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
  6. Sep 3, 2008 at 5:38 PM
    sr5boy
    tallahassee florida
    06 tacoma 4x4
    awsome, have u done this mod?
  7. Sep 3, 2008 at 5:54 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    I have, yes. It was fairly easy. Before you do it, take careful notice of your needle positions.
  8. Sep 3, 2008 at 5:57 PM
    sr5boy
    tallahassee florida
    06 tacoma 4x4
    ha yeah thanks
  9. Sep 7, 2008 at 3:02 PM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    There is a black pressure switch behind the door, on the rear door, or rear of the cab depending which truck you have. I am going to try and post a pic. take a socket and unscrew the bolt that holds it in and then unplug it, and that should take care of it. The pressure switch i am refering to is NOT the switch below the striker plate. Hope this helps. Jason
  10. Jan 6, 2014 at 11:31 PM
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
  11. Mar 13, 2014 at 2:47 PM
    bunkerboy
    bunkerboy Well-Known Member
    Gainesville, FL
    2014 Prerunner
    Thank you, thank you THANK YOU, Toyotamudbogs! Thank you to ToyoBlair, who authored that thread you linked! And THANK YOU TACOMAWORLD!!! Oh, the sweet, sweet sound of silence when I open my door; silence, SILENCE, the most beautiful, wonderful sound in all the WORLD!!!
    To say I "loathe" that MF-ing beeping sound is like saying "the Universe is big." It literally enrages me.
    I disabled my '04 Prerunner's beeper using the door switch, and although the overhead light only worked manually after that, it was well worth it. But on my 2014, that door switch also disables the automatic headlight shutoff! I had to get closer to the source of the problem this time. I also cut the wires to the seat belt buckle weeks ago, but the door beeper was still eating away at my soul.
    THANKS AGAIN!!!
  12. Mar 15, 2014 at 3:42 PM
    Toyotamudbogs
    Devin
    White Springs , FL
    No prob man I know how you feel. I ran 2 wires to the door switch and back to my dash I put a switch . Like you said it would cut the light off . And I had to be jumped off alot . I would forget to flip the switch back and my lights would stay on . So I found this thread and unplugged it. And took out the wires and rewired the switch back. I hates that dingen racket .
