Opening overhead switch plate - what are best pry points?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Sep 24, 2017.
  1. Sep 24, 2017 at 2:21 PM
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    (Edit: see my last post on this thread below before taking off the panel, you can get 12v off the plug in the back of the mirror.)
    I want to hard wire in a dashcam and need a 12v overhead power supply for it near the mirror- anyone temporarily remove the overhead switch plate to do this? How do you open it?
    You can see the wire in this photo that I wan to insert under the plate instead of running down to the lighter plug for low wattage 12 volt power. The camera itself uses 5volts, but I have a small variable voltage regulator to use for it to do the same from a 12 volt supply. Thanks!IMG_0866.jpg
  2. Sep 24, 2017 at 2:59 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Subbed because I want to hardwire my dash cam also.
    I believe the whole panel can be pried off.
    I will check later as there are a few posts about this on TW, unless someone answers first.
  3. Sep 24, 2017 at 3:27 PM
    OnHartung'sRoad
    I edited the title because I'm really asking what is the best way to open it safely and where are the best pry points to open it.
    You'd think that Toyota would have provided a USB port or at least a 12v plug for it up there for use with the GoPro mount they stuck on the windshield... I'm still waffling between hard wiring my camera and/or putting in a dash mounted USB plug in the unused switch panel on my overhead unit next to the rear locker switch like this one that also displays line voltage (that would be nice for monitoring the battery): https://www.amazon.com/gp/aw/d/B01F3I117E/ref=ox_sc_saved_image_1?smid=ACKFGXOOEC78X&psc=1
    Vbpiper and boynoyce[QUOTED] like this.
  4. Sep 24, 2017 at 3:33 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Only 4 of the red clips holding it up there. (Top of photo). Easy pulls all around, then once started give it the yank.
    Vbpiper and boynoyce like this.
  5. Sep 24, 2017 at 3:45 PM
    OnHartung'sRoad
  6. Sep 24, 2017 at 3:51 PM
    CZ5ANM Taco
    BC, Canada
    Shape ways for the panel
    Amazon for the USB
    Just got the USB 2 days ago and haven't had time yet to finalize the wires
    tacitos, daohaus and boynoyce like this.
  7. Sep 24, 2017 at 3:54 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    You can get a panel pry bar at your local auto part store. There are two tabs in the front, and two in back. Pretty easy to pry off. I did it to install a homelink mirror.
  8. Sep 24, 2017 at 4:04 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    daohaus and OnHartung'sRoad[OP] like this.
  9. Sep 24, 2017 at 4:25 PM
    CZ5ANM Taco
    BC, Canada
    That's the same panel. Google shapeways promo code for a discount. They always have a code floating around.
    Amazon USB used the seller "All dazzling " however that took about 2 months to get to my house from china. Might want to find a different seller lol. The USB will sit flush once pushed in, just haven't done it yet.
    I'm also waiting for an arb fridge wiring kit to show up, then I'll dig in to the dash finding the passage ways to run the wires from hood to cab.
    OnHartung'sRoad[OP] likes this.
  10. Sep 24, 2017 at 4:36 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    I am not an electrician but I thought my SR5 would have some factory wire harnesses up there not being used by my "base" model that I could tap into for a USB charger.
    Anyone know if this is possible?
  11. Sep 24, 2017 at 4:48 PM
    sandyTrd87
    sandyTrd87 Well-Known Member
    Socal
    Bilstien 5100's x4 Dobinson 448 springs, rear 2inch AAL
    What power source did you tap into for 12V power ?
  12. Sep 24, 2017 at 5:20 PM
    OnHartung'sRoad
    I haven't done the testing yet, but there are probably several places possible there to get 12v - it wouldn't need much amperage, either so some of the accessories wired to turn on with the ignition switch such as the mirror/compass power may work. I'm assuming it's 12v going into them but check it first. There was a member here that sold a jack with power out leads for the mirror plug, apparently not doing it anymore (see next post).
    sandyTrd87 likes this.
  13. Sep 25, 2017 at 9:12 AM
    OnHartung'sRoad
  14. Sep 25, 2017 at 10:49 AM
    OnHartung'sRoad
    Ok, before you pull your overhead panel to get 12volts for your dashcam, check this out. You can easily DIY it or get the needed part for $$$ from https://www.mirrortap.com/. Keep in mind in either way, you will still need a 12v to 5v regulator if your camera uses only USB power, but those are easy to find in Amazon like this one https://www.amazon.com/gp/aw/d/B00O...340_QL65&keywords=12v+to+5v+usb+adapter+cable
    0552D5E2-68BF-44CF-BD0D-44C2BB73FC30-16104-000020E6D1D26D9F.jpg 468A783B-6896-4DFB-AE1E-436E2B13C3FA-16104-000020E6CC6DC41C.jpg
  15. Sep 25, 2017 at 10:54 AM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    That's what I used to hardwire my Valentine one. I ran wire to my fuse panel for my dashcam. Although I do like the USB port idea looks good. Only thing that might about me is unless you get a right angle USB you're going to have that plug kind of sticking down
  16. Sep 25, 2017 at 11:02 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    I slid my fingers under the "back" side (closest to the seats) and pulled down firmly. The whole thing popped right off.
    Vbpiper likes this.
  17. Sep 25, 2017 at 2:57 PM
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    I ran a dedicated 12v power wire up the passenger windshield pillar and through the header. I then installed a 12v to USB converter (5v 3A) that is stickied to the roof above the headliner.
    Granted I have to pull the console out to unplug / plug in anything, I don't normally need to unplug my camera so having the hidden USB and a single wire coming out worked better.
  18. Sep 25, 2017 at 8:48 PM
    OnHartung'sRoad
    Sounds like a clean way to do it, especially if the camera needs 5v - What converter did you use?
  19. Sep 26, 2017 at 10:47 AM
    i8boots
    UT - 801
  20. Sep 28, 2017 at 4:26 PM
    OnHartung'sRoad
    boynoyce likes this.
