Opinion of the Bilstein 5100's
Discussion in 'Suspension' started by 4x4x4trd, Mar 18, 2008.
  1. Oct 7, 2008 at 6:21 PM
    #41
    KMADA
    KMADA Well-Known Member
    Long Beach, CA
    08 prerunner trd sport
    15% tint, 6k HIDs, K&N intake
    cuz I had a thought if going with the 5100s at 2.5 with 285s but wasn't sure if it would be high enough.
    I would go ome but money is a factor I'm only 19 savin up my money haha.
  2. Nov 29, 2008 at 8:27 PM
    #42
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Bump for a cause.
    Picked up the 2003 Tacoma and well she rides like shit. I just went through and replaced all the fluids and am going after the shocks next. She has 72000 miles on her and I'm pretty sure the shocks have never been touched.
    I'm looking for little too no lift on her right now and am considering the 5100's as a straight across replacement. Will these work fine with the existing coils at the lowest setting? Or am I looking at potential problems?
    Other option. Original Bilstein replacement's from TRDParts4u.
  3. Nov 29, 2008 at 8:31 PM
    #43
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With 72,000 miles on it, You may way want to consider swaping out the springs, also. I think OME 880's will give a better ride while only provideing minimal lift ( 1" ), and combined with the 5100's, it should ride better than when new.
  4. Nov 29, 2008 at 8:36 PM
    #44
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Thought about the springs as well. I taked to a few people and they said the springs should be good but... Might as well go big. No sense replacing the coils in another 10-20K miles. Well there goes my Xmas present. Between the Amsoil, soon to be shocks and coils, my suspension for the FJ is out the window. Fuggers.
  5. Nov 29, 2008 at 10:10 PM
    #45
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Banshee...........the 5100's ride friggin awesome man. i replaced mine all the way around..................alos went with new wheelers rear leafs and ome 881 coils for a bit of lift. if you really wanted to stay stock height or close to it anyway......you can get a set of wheelers 4 leaf rears.....basically stock height springs, and ome 880 coils like chris mentioned, with billy 5100's all the way around, and you'll have a great ride. and at 72k............i gotta think your whole suspension is pretty worn..............mine only had 46k on it when i got it and everything was shot!!:D
  6. Nov 29, 2008 at 10:27 PM
    #46
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Ok, the leafs are way out of my price range now. I can do the Billie's front and rear with the OME 880's or 881's not but the leafs... Not now.
  7. Nov 29, 2008 at 10:34 PM
    #47
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may wanna stick with the ome 880's then......cause the 881 are gonna give you around 2 inches of lift or so....................thats what they did for my double cab. the rears may not be necessary now, but if you start to have axle wrap and all, if you dont wanna pay for the new springs, you can get some helper springs at autozone for around $25. reason im saying stay with the 880 coils is that with the 881 up front, and no new springs or aal in the rear, the front will sit alot higher.
  8. Nov 29, 2008 at 10:37 PM
    #48
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Interesting. So 5100's with the OME 880's then will work out fine?
  9. Nov 29, 2008 at 10:41 PM
    #49
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, im pretty positive.......just keep the 5100's on the stock setting and you'll be good to go. you could go with 881's if you wanted a little lift, and then run an aal from toytec(wheelers may have one too), but if you are wanting to stay near stock height......880's are the way to go, and the 5100's will be a nice edition.
    nrvfisher likes this.
  10. Nov 29, 2008 at 10:48 PM
    #50
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Good to know. I was going to go with just the stock replacements from TRDParts4U and after talking with the stealerships in the the area... Their shit was way overpriced and I could get the 5100's through Wheelers cheaper than any stealership on the stock's. Going to order them in a few.
  11. Nov 29, 2008 at 10:53 PM
    #51
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Just ordered the 5100's and the OME 880's. Lets see what it does!!!!:D
  12. Nov 29, 2008 at 10:58 PM
    #52
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sweet!!!:D sonny is awesome to deal with man!!! if you ever get stuff from wheelers.......jason is awesome to deal with also!!
  13. Nov 29, 2008 at 11:00 PM
    #53
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Ordered through Wheelers.
  14. Nov 29, 2008 at 11:09 PM
    #54
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    right on man!!!! you gonna do the deckplate mod and the gray wire mod on the "new" first gen???
  15. Nov 29, 2008 at 11:14 PM
    #55
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Are you kidding? I just replaced every fluid in her with Amsoil, ordered Billies and OME's. Replaced the joke of a air filter that was K&N with a Amsoil filter. I need to get her running right before I throw a deckplate her way. But the gray wire is on the list. Going to pull the throttle body and IAC clean the shit out of them ant slap 'em back on. Just need to find the gaskets locally.
  16. Nov 29, 2008 at 11:21 PM
    #56
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah...cool. man, i seafoamed mine, changed all fluids, cleaned the tb, replaced all the filters....transmission included.............had to get mine running back the way it was supposed to. the dude that had it before me musta been a douche...............he did absolutely nothing to it!!!:rolleyes:
    if you can....do you mind posting a pic of the iac................i wanna give mine a new cleaning too man. im about to change my oil again, and im gonna replace the fuel filter again.................when i changed it a couple of months ago, there all kinds of rust and shit coming outta the lines and old filter. its running pretty damn tip top shape now, but while im at it....i definitely wanna clean the iac as well as the tb again....................but im kinda unsure where the iac is exactly.:eek:
  17. Nov 30, 2008 at 8:08 AM
    #57
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    The IAC is attached directly to the underside of the throttle body. Should have 2 coolant hoses running to it IIRC.
  18. Nov 30, 2008 at 8:43 AM
    #58
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok,cool. whats the best way to clean it.....remove it and spray the shit outta it,in thru the nipples with seafoam deep creep, and let it drain??
  19. Dec 5, 2008 at 4:20 PM
    #59
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    What I did was pull it and clean it with throttle body cleaner. q-tips and an old toothbrush. Replace with with new gaskets on the IAC valve and the throttle body.
    Back to the topic on hand. Got the Billies and the OME springs today. Do I absolutely need to replace the top plate and bushing? Or is it fine to use the existing?
    I plan on getting this done this weekend.
  20. Dec 5, 2008 at 4:37 PM
    #60
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    you can use the stock top plate and bushing.
